Ashes of the Singularity Day 1 Benchmark Preview @ [H]
its more about the video card....what dx12 in this game does is even the playing field for weaker cpus. For example my setup is a solid 30% difference over amd weaker cpus but scores exactly same in the benchmark avg fps. This game is almost the exact opposite of games from before it. The cpu used to be a huge performance difference but in this game its really just the video card (in your case that 980ti has twice the video power of mine) in other words if i had your same card we be almost dead even fps
As seen here my cpu is barley stressed in normal play
My brother has a better CPU than you, we are sitting side-by-side, and that is not the case. Windows task manager is not the end all benchmarking tool.
who said it was a bench marking tool? I only showed it to show the cpu usage is nowhere near taxed hard..Me and others with same card but using way different cpus are getting almost exact results. its all i meant
Primetime is right CPU wont matter much. Hell even the 8370 was very close to the 6600k using DX12 whereas it was way behind in DX11. If you are seeing something it is far more likely a difference in Ram or SSD/HDD than your CPUs especially between Intel generations which will likely be a lot more equal in DX12.
CPU makes quite a big difference... Look at fx8350/8150 results posted earlier, and guy with fury X and fx9590
Maybe you should look up the tests done by reviewer which is far better indicator than some random people with vastly different setups ( I dont recall right now which one it was and don't have time to look, gotta get to work).
yea well your more then welcome to post this particular comparison idk..cause i dont recall this post your referring to. well find out soon enough once kyle an company put there next ashes article up
Maybe you should refrain from disagreeing with me before even taking a look at the benchmark data in question.
most review website run their tests on skylake systems, or haswell....
If you look at the top of this page you'll see a fury X user under-performing relative to the [h] review by >10%
This in overclocked FURY X btw, a stock FURY X gets :
That isn't possible as far as I know. VSR gives me:
2048 X 1536 4:3 (Other than DOSBox I don't see a use for this)
2560 X 1600 16:10 (Works perfectly fine from my testing)
3840 X 2400 16:10 (Broken for me)
Even if I add a custom 1080p letterboxed resolution into the driver settings none of the 16:9 resolutions above 1080p showed up ingame. Hm.. I'll try editing the .ini but I doubt that will work.
[edit]
Forcing the resolution in the Ashes .ini let me run it but it was buggy. The screen was not scaled to my native resolution so I was only seeing the upper left 1920x1200 portion. My FPS was actually lower than my 1600p results.:alien:
Version 1.01.18821
04/10/2016 16:26
== Hardware Configuration ================================================
GPU 0: AMD Radeon (TM) R9 Fury Series
CPU: AuthenticAMD
AMD FX(tm)-9590 Eight-Core Processor
Physical Cores: 4
Logical Cores: 8
Physical Memory: 16353 MB
Allocatable Memory: 134217727 MB
== Configuration =========================================================
API: DirectX 12
Quality Preset: Crazy
Resolution: 2560x1440
Fullscreen: True
Bloom Quality: High
PointLight Quality: High
Glare Quality: High
Shading Samples: 16 million
Terrain Shading Samples: 16 million
Shadow Quality: High
Temporal AA Duration: 0
Temporal AA Time Slice: 0
Multisample Anti-Aliasing: 4x
Texture Rank : 1
== Total Avg Results =================================================
Total Time: 60.004818 ms per frame
Avg Framerate: 40.689621 FPS (24.576292 ms)
Weighted Framerate: 40.089016 FPS (24.944489 ms)
CPU frame rate (estimated if not GPU bound): 53.651573 FPS (18.638783 ms)
Percent GPU Bound: 88.498474 %
Driver throughput (Batches per ms): 5269.011230 Batches
Average Batches per frame: 19419.904297 Batches
== Results ===============================================================
BenchMark 0
TestType: Full System Test
== Sub Mark Normal Batch =================================================
Total Time: 70.960732 ms per frame
Avg Framerate: 47.942009 FPS (20.858534 ms)
Weighted Framerate: 46.250038 FPS (21.621603 ms)
CPU frame rate (estimated if not GPU bound): 61.882427 FPS (16.159676 ms)
Percent GPU Bound: 71.403381 %
Driver throughput (Batches per ms): 3978.256836 Batches
Average Batches per frame: 6170.076172 Batches
== Sub Mark Medium Batch =================================================
Total Time: 56.003765 ms per frame
Avg Framerate: 40.890106 FPS (24.455793 ms)
Weighted Framerate: 40.510677 FPS (24.684851 ms)
CPU frame rate (estimated if not GPU bound): 55.228569 FPS (18.106571 ms)
Percent GPU Bound: 97.290962 %
Driver throughput (Batches per ms): 4769.240723 Batches
Average Batches per frame: 13888.426758 Batches
== Sub Mark Heavy Batch =================================================
Total Time: 53.049953 ms per frame
Avg Framerate: 35.193245 FPS (28.414543 ms)
Weighted Framerate: 35.054501 FPS (28.527008 ms)
CPU frame rate (estimated if not GPU bound): 46.189167 FPS (21.650099 ms)
Percent GPU Bound: 96.801071 %
Driver throughput (Batches per ms): 6142.602539 Batches
Average Batches per frame: 38201.207031 Batches
Version 1.01.18821
04/10/2016 14:09
CPU: AuthenticAMD
Physical Cores: 4
Logical Cores: 8
API: DirectX 12
Resolution: 2560x1600
Fullscreen: True
Bloom Quality: High
Glare Quality: High
Texture Rank : 1
Total Time: 60.003891 ms per frame
Avg Framerate: 41.062408 FPS (24.353174 ms)
Weighted Framerate: 40.540997 FPS (24.666389 ms)
CPU frame rate (estimated if not GPU bound): 54.933891 FPS (18.203697 ms)
Percent GPU Bound: 89.356995 %
Driver throughput (Batches per ms): 5125.561035 Batches
Average Batches per frame: 17982.925781 Batches
BenchMark 0
Total Time: 70.996994 ms per frame
Avg Framerate: 47.987946 FPS (20.838566 ms)
Weighted Framerate: 46.802727 FPS (21.366276 ms)
CPU frame rate (estimated if not GPU bound): 62.730457 FPS (15.941219 ms)
Percent GPU Bound: 72.248795 %
Driver throughput (Batches per ms): 3862.102783 Batches
Average Batches per frame: 5742.187012 Batches
Total Time: 55.994751 ms per frame
Avg Framerate: 41.950359 FPS (23.837698 ms)
Weighted Framerate: 41.451916 FPS (24.124338 ms)
CPU frame rate (estimated if not GPU bound): 56.473438 FPS (17.707439 ms)
Percent GPU Bound: 96.401161 %
Driver throughput (Batches per ms): 4723.638184 Batches
Average Batches per frame: 13172.589844 Batches
Total Time: 53.019924 ms per frame
Avg Framerate: 35.232040 FPS (28.383257 ms)
Weighted Framerate: 35.077198 FPS (28.508549 ms)
CPU frame rate (estimated if not GPU bound): 47.704380 FPS (20.962437 ms)
Percent GPU Bound: 99.421021 %
Driver throughput (Batches per ms): 5946.307129 Batches
Average Batches per frame: 35034.000000 Batches
It certainly is CLOSER than the DX11 result, CPU is still a huge bottleneck in this game
Compare to my result
DX12 - CRAZY PRESET - 980Ti @ 1490/8000
API: DirectX 12
Fullscreen: True
Bloom Quality: High
Glare Quality: High
Texture Rank : 1
Total Time: 60.002808 ms per frame
Avg Framerate: 45.875206 FPS (21.798267 ms)
Weighted Framerate: 45.184284 FPS (22.131588 ms)
CPU frame rate (estimated if not GPU bound): 132.483719 FPS (7.548098 ms)
Percent GPU Bound: 99.924889 %
Driver throughput (Batches per ms): 8930.305664 Batches
Average Batches per frame: 17745.410156 Batches
CPU framerate is more than doubled...
ok were seeing 6fps difference here between a heavily overclocked most modern cutting edge cpu made and one thats 8 years old which may even be running stock clocks. Whose point does it prove? Ill give you credit there is some difference but much less than a typical heavy cpu usage game. The point being someone with a 980ti was comparing there results to mine saying how its my cpu holding me back -please! lol in my case Im 100% gpu limited
What is it with people on this forum and percentages...
First of all, the user I quoted has an OVERCLOCKED Fury X.
The [H] results are of a STOCK Fury X.
Let's assume, for the sake of conversation, that he is actually running at stock. That's 15% performance difference, the card in the [H] review is performing 15% better; and it's at STOCK. That's more than the performance gain from async shaders.
An FX9590 isn't an 8 year old cpu, and he is running it at 4.8GHz
You're less likely to be CPU bottlenecked because you have a much less powerful GPU, I don't think I need to point out that CPU bottleneck will be more evident as framerate increases, right ?
TLDR
Mine.
Nitrous engine was designed to scale up to an impressive 16 logical processors cores. So the speed of individual cores has less of an effect on performance since less instructions are packed per core the more cores are available. Still, the less the CPU has to be involved with graphics in DX12, the better.
Yeah it's impressively multithreaded, average load on all my cores is ~70% during the benchmark run. Nonetheless, it's pretty clear from the benchmark results that single thread performance is still hugely important
Just curious,
is it possible to run the benchmarks using the CPUs integrated GPU?
Curious to see how Haswell and Skylake perform with the DX11 and DX12 excluding dGPU.
Cheers
Just curious,
Cheers
Anyone here got a broadwell cpu?
Well is not complicated, if you want to see CPU impact then run the game at same settings except :
Full 16 logical core (LC) CPU speed = X
Then again 16 LC underclocked at speed X/2.
Then again at LC/2 (balancing full and logical cores) @ full speed X.
Then again run at LC/2 & X/2.
Should give you scaling performance as it relates to CPU logical cores use and speed using the same CPU.
What i think would be more interesting is to see the impact of the Async scheduler on/off at 16 LC and see how much work it is actually doing in background.
Just a few frames huh...
Because a 6 fps difference at 30fps is the same as a 6 fps difference at 100fps.
Not going to bother anymore
47 to 52 is 5 frames going from a Celeron to a 6600k (OC) using a FuryX, from a 2 core/thread to a 4 core/8 thread CPU. That is quite pertinent as far as CPU bottlenecking discussions go.
image_resize.php
image_resize.php
CPU doesn't make much of a difference, they said.
5 fps, they said.
~40% increase for Fury X, in heavily gpu bound load, going from fx8370 to 6700k used in original review.
image_resize.php
image_resize.php
5 fps, they said.
I would suggest that you NOT COMPARE THESE AotS RESULTS TO EACH OTHER!!!!!!!!!!!!!!!!
These were NOT done on the same systems, at different clocks, different video cards, different CPUs, different authors, and very likely different drivers, and possibly different game versions. Brent is doing GPU Reviews, I am looking at CPU based benchmarks.
Kyle,
can this game be played with just a CPU without dGPU such as the I7 Intel Haswell (or Broadwell with its EDRAM that may be interesting) and importantly Skylake?
From a CPU perspective such analysis would be very interesting, including with async compute on Skylake.
I appreciate such tests are a lot of work so maybe just quick preview test to see if it makes sense to do a more thorough one.
Thanks
Kyle,
Thanks
I would imagine it would be prohibitively slow, unless async shaders amount to a huge % increase, it will be unnoticeable if it's running at 6 fps :p
Yeah :)
But the lower settings would still be interesting, after all many strategy games are played on laptops, so using I7 Intel CPUs on a desktop should still be interesting, and APU type CPU-GPU will the way forward at the lower end of the gaming industry.
Cheers
My benchmarks were run at 1200-1205 MHz core and 546 MHz VRAM on my Fury X. This is higher than most people will even temporarily clock theirs so it gives a best case scenario for current generation Fiji. Please keep in mind that anything between 0% GPU bound and 100% GPU bound is just an educated guess by the benchmark. It would really have to run through the same thing twice (in a headless mode) to get a more accurate CPU framerate.
With my Fury X overclocked this high my FX-9590 @4.8 GHz is not quite enough to keep up at 1080p/1200p. The framerate at those resolutions is still high enough that the gameplay is smooth, but it could be even better with a faster CPU. There isn't stuttering or anything like that to worry about though. Ashes of the Singularity makes better use of my processor than any game I've seen thus far. (y)
1600p "Crazy" was bottlenecked slightly by the CPU in some sections of the benchmark, but not enough that most players would worry about it. Again, the average framerate is totally playable for a RTS. It's not perfect, but then again dialing the preset back from "Crazy" to "Extreme" (which ONLY reduces the terrain detail in a way I can't be bothered to notice) gives a 25% boost and takes the average framerate from 41.1 to 51.6.
Most of the graph shows the green data points (CPU) being ahead. If you view the full size image the areas I highlighted have a mixture of green and blue dots. In those specific locations the CPU was holding the framerate back slightly.
In the full text log I can see that some of the shots are 100% GPU bound. These are easily identifiable on the graph too, as the green is well above the blue. The troublesome shots I have highlighted on the graph are:
1st
Code:
== Shot Fighters Satellite Chase =========================================
Total Time:                    12.005998 ms per frame
Avg Framerate:                    57.804443 FPS (17.299707 ms)
Weighted Framerate:                57.466988 FPS (17.401295 ms)
CPU frame rate (estimated if not GPU bound):    58.330891 FPS (17.143576 ms)
Percent GPU Bound:                1.823630 %
Driver throughput (Batches per ms):        2799.147705 Batches
Average Batches per frame:            3042.201660 Batches
2nd
Code:
== Shot Bomber Chase Cam =========================================
Total Time:                     7.007321 ms per frame
Avg Framerate:                     48.520676 FPS (20.609770 ms)
Weighted Framerate:                 48.263115 FPS (20.719757 ms)
CPU frame rate (estimated if not GPU bound):     56.911949 FPS (17.571003 ms)
Percent GPU Bound:                 72.059860 %
Driver throughput (Batches per ms):         3704.857422 Batches
Average Batches per frame:             7282.591309 Batches
3rd
Code:
== Shot Fighters Satellite Chase 2 =========================================
Total Time:                     7.003233 ms per frame
Avg Framerate:                     58.401596 FPS (17.122820 ms)
Weighted Framerate:                 57.820675 FPS (17.294851 ms)
CPU frame rate (estimated if not GPU bound):     67.867294 FPS (14.734637 ms)
Percent GPU Bound:                 54.007797 %
Driver throughput (Batches per ms):         3511.778809 Batches
Average Batches per frame:             4266.445313 Batches
== Shot Small Mountain Battle =========================================
Total Time:                     4.974277 ms per frame
Avg Framerate:                     55.686481 FPS (17.957680 ms)
Weighted Framerate:                 55.273125 FPS (18.091974 ms)
CPU frame rate (estimated if not GPU bound):     62.572449 FPS (15.981475 ms)
Percent GPU Bound:                 50.336098 %
Driver throughput (Batches per ms):         3117.406494 Batches
Average Batches per frame:             3230.689453 Batches
Q: What do these all have in common?
A1: Their framerates were well above the overall average the benchmark produced. These are scenes where the gameplay was already smooth (enough for a RTS at least).
A2: Their "Average Batches per frame" while not always the lowest, are all among the bottom. For reference some of the shots have values such as 54219.539063 Batches and 47020.996094 Batches.
A Haswell-E at 4.5GHz makes it really easy to get GPU limited. :) The FX 8370 is probably "half" the CPU that the Haswell is.
1st
Code:
2nd
Code:
3rd
Code:
Please us [ SPOILER] [ /SPOILER] tags , no spaces !
This is at 1600p CRAZY right ?
GPU 0: NVIDIA GeForce GTX 980 Ti
CPU: GenuineIntel
Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz
Physical Cores: 6
Logical Cores: 12
Physical Memory: 32669 MB
API: DirectX 12
Fullscreen: True
Bloom Quality: High
Glare Quality: High
Texture Rank : 1
BenchMark 0
Total Time: 70.992004 ms per frame
Avg Framerate: 50.935314 FPS (19.632744 ms)
Weighted Framerate: 49.348564 FPS (20.264015 ms)
CPU frame rate (estimated if not GPU bound): 161.396637 FPS (6.195916 ms)
Percent GPU Bound: 99.774658 %
Driver throughput (Batches per ms): 6122.466309 Batches
Average Batches per frame: 5970.257813 Batches
Total Time: 56.034210 ms per frame
Avg Framerate: 45.079605 FPS (22.182981 ms)
Weighted Framerate: 44.492123 FPS (22.475889 ms)
CPU frame rate (estimated if not GPU bound): 137.354324 FPS (7.280441 ms)
Percent GPU Bound: 100.000000 %
Driver throughput (Batches per ms): 7487.860840 Batches
Average Batches per frame: 13153.236328 Batches
Total Time: 52.982201 ms per frame
Avg Framerate: 42.410469 FPS (23.579082 ms)
Weighted Framerate: 42.274620 FPS (23.654856 ms)
CPU frame rate (estimated if not GPU bound): 109.075806 FPS (9.167935 ms)
Driver throughput (Batches per ms): 11342.462891 Batches
Average Batches per frame: 34112.734375 Batches
== Shot Mid Artemis Battle Shot =========================================
Total Time: 4.999392 ms per frame
Avg Framerate: 40.604939 FPS (24.627546 ms)
Weighted Framerate: 40.403313 FPS (24.750446 ms)
CPU frame rate (estimated if not GPU bound): 150.209625 FPS (6.657363 ms)
Driver throughput (Batches per ms): 4342.103516 Batches
Average Batches per frame: 4444.147949 Batches
== Shot Far Artemis Battle Shot =========================================
Total Time: 5.017918 ms per frame
Avg Framerate: 41.252171 FPS (24.241150 ms)
Weighted Framerate: 41.058220 FPS (24.355659 ms)
CPU frame rate (estimated if not GPU bound): 128.720459 FPS (7.768773 ms)
Driver throughput (Batches per ms): 6728.504395 Batches
Average Batches per frame: 12478.168945 Batches
== Shot Satellite Shot =========================================
Total Time: 4.980747 ms per frame
Avg Framerate: 40.957714 FPS (24.415426 ms)
Weighted Framerate: 40.881145 FPS (24.461153 ms)
CPU frame rate (estimated if not GPU bound): 105.192322 FPS (9.506397 ms)
Driver throughput (Batches per ms): 11620.995117 Batches
Average Batches per frame: 35920.796875 Batches
Total Time: 12.014034 ms per frame
Avg Framerate: 65.756432 FPS (15.207638 ms)
Weighted Framerate: 65.129066 FPS (15.354128 ms)
CPU frame rate (estimated if not GPU bound): 173.153671 FPS (5.775217 ms)
Percent GPU Bound: 98.668549 %
Driver throughput (Batches per ms): 4855.213867 Batches
Average Batches per frame: 2778.921631 Batches
== Shot Surrounded T3 Shot =========================================
Total Time: 5.004609 ms per frame
Avg Framerate: 27.374767 FPS (36.529991 ms)
Weighted Framerate: 27.057337 FPS (36.958553 ms)
CPU frame rate (estimated if not GPU bound): 126.677727 FPS (7.894048 ms)
Driver throughput (Batches per ms): 5212.238281 Batches
Average Batches per frame: 6811.043945 Batches
== Shot Overhead Top Battle Shot =========================================
Total Time: 4.997733 ms per frame
Avg Framerate: 41.618870 FPS (24.027563 ms)
Weighted Framerate: 41.416904 FPS (24.144730 ms)
CPU frame rate (estimated if not GPU bound): 142.624542 FPS (7.011416 ms)
Driver throughput (Batches per ms): 6394.417480 Batches
Average Batches per frame: 10679.067383 Batches
== Shot Sideline Battle Shot =========================================
Total Time: 4.992622 ms per frame
Avg Framerate: 51.876549 FPS (19.276533 ms)
Weighted Framerate: 51.754726 FPS (19.321907 ms)
CPU frame rate (estimated if not GPU bound): 147.130020 FPS (6.796709 ms)
Driver throughput (Batches per ms): 6556.765137 Batches
Average Batches per frame: 10019.023438 Batches
Total Time: 6.992750 ms per frame
Avg Framerate: 53.483963 FPS (18.697193 ms)
Weighted Framerate: 53.383366 FPS (18.732428 ms)
CPU frame rate (estimated if not GPU bound): 151.763245 FPS (6.589211 ms)
Driver throughput (Batches per ms): 6064.223145 Batches
Average Batches per frame: 7837.157715 Batches
== Shot Long Shot =========================================
Total Time: 10.016864 ms per frame
Avg Framerate: 36.937710 FPS (27.072605 ms)
Weighted Framerate: 36.751846 FPS (27.209517 ms)
CPU frame rate (estimated if not GPU bound): 123.921837 FPS (8.069603 ms)
Driver throughput (Batches per ms): 6471.280273 Batches
Average Batches per frame: 13432.932617 Batches
== Shot Fighters Chase Cam 1 =========================================
Total Time: 14.992627 ms per frame
Avg Framerate: 42.354149 FPS (23.610437 ms)
Weighted Framerate: 42.137146 FPS (23.732029 ms)
CPU frame rate (estimated if not GPU bound): 140.822495 FPS (7.101139 ms)
Driver throughput (Batches per ms): 7079.072266 Batches
Average Batches per frame: 11280.590820 Batches
== Shot Satellite Shot 2 =========================================
Total Time: 7.995595 ms per frame
Avg Framerate: 45.775204 FPS (21.845888 ms)
Weighted Framerate: 45.474567 FPS (21.990314 ms)
CPU frame rate (estimated if not GPU bound): 109.774513 FPS (9.109583 ms)
Driver throughput (Batches per ms): 11933.027344 Batches
Average Batches per frame: 35153.136719 Batches
== Shot Top Battle Shot =========================================
Total Time: 5.008827 ms per frame
Avg Framerate: 43.123867 FPS (23.189016 ms)
Weighted Framerate: 43.033611 FPS (23.237650 ms)
CPU frame rate (estimated if not GPU bound): 123.627357 FPS (8.088824 ms)
Driver throughput (Batches per ms): 8320.115234 Batches
Average Batches per frame: 19431.894531 Batches
== Shot Sideline Battle Shot 2 =========================================
Total Time: 9.992894 ms per frame
Avg Framerate: 41.829723 FPS (23.906445 ms)
Weighted Framerate: 41.789135 FPS (23.929665 ms)
CPU frame rate (estimated if not GPU bound): 118.653755 FPS (8.427883 ms)
Driver throughput (Batches per ms): 9694.016602 Batches
Average Batches per frame: 24669.888672 Batches
== Shot Fighters Chase Cam 2 =========================================
Total Time: 9.995333 ms per frame
Avg Framerate: 46.721809 FPS (21.403280 ms)
Weighted Framerate: 46.494213 FPS (21.508053 ms)
CPU frame rate (estimated if not GPU bound): 155.740112 FPS (6.420954 ms)
Driver throughput (Batches per ms): 5207.829590 Batches
Average Batches per frame: 6087.227051 Batches
== Shot Long Shot 3 =========================================
Total Time: 5.015032 ms per frame
Avg Framerate: 41.475304 FPS (24.110733 ms)
Weighted Framerate: 41.412403 FPS (24.147356 ms)
CPU frame rate (estimated if not GPU bound): 99.816376 FPS (10.018396 ms)
Driver throughput (Batches per ms): 12621.138672 Batches
Average Batches per frame: 43343.062500 Batches
== Shot Mountain Air Battle Shot =========================================
Total Time: 9.999930 ms per frame
Avg Framerate: 46.500320 FPS (21.505228 ms)
Weighted Framerate: 46.453972 FPS (21.526686 ms)
CPU frame rate (estimated if not GPU bound): 162.643326 FPS (6.148423 ms)
Driver throughput (Batches per ms): 9425.477539 Batches
Average Batches per frame: 9075.490234 Batches
== Shot Sideline Battle Shot 3 =========================================
Total Time: 4.994588 ms per frame
Avg Framerate: 50.254391 FPS (19.898760 ms)
Weighted Framerate: 50.188480 FPS (19.924891 ms)
CPU frame rate (estimated if not GPU bound): 151.957596 FPS (6.580783 ms)
Driver throughput (Batches per ms): 7062.313477 Batches
Average Batches per frame: 9804.708984 Batches
== Shot Panoramic Battle Shot =========================================
Total Time: 10.005999 ms per frame
Avg Framerate: 43.074165 FPS (23.215773 ms)
Weighted Framerate: 42.950588 FPS (23.282568 ms)
CPU frame rate (estimated if not GPU bound): 115.201462 FPS (8.680445 ms)
Driver throughput (Batches per ms): 10727.714844 Batches
Average Batches per frame: 30940.857422 Batches
== Shot Mountain Air Battle Shot 2 =========================================
Total Time: 4.995180 ms per frame
Avg Framerate: 48.246510 FPS (20.726887 ms)
Weighted Framerate: 48.160179 FPS (20.764042 ms)
CPU frame rate (estimated if not GPU bound): 150.676651 FPS (6.636728 ms)
Driver throughput (Batches per ms): 13208.301758 Batches
Average Batches per frame: 19063.005859 Batches
== Shot Low Vista =========================================
Total Time: 9.993709 ms per frame
Avg Framerate: 41.826317 FPS (23.908394 ms)
Weighted Framerate: 41.741035 FPS (23.957239 ms)
CPU frame rate (estimated if not GPU bound): 105.504227 FPS (9.478293 ms)
Driver throughput (Batches per ms): 10942.902344 Batches
Average Batches per frame: 34789.183594 Batches
Total Time: 6.996128 ms per frame
Avg Framerate: 56.173935 FPS (17.801851 ms)
Weighted Framerate: 55.987652 FPS (17.861082 ms)
CPU frame rate (estimated if not GPU bound): 188.684982 FPS (5.299839 ms)
Driver throughput (Batches per ms): 7799.212891 Batches
Average Batches per frame: 4830.969238 Batches
== Shot High Vista =========================================
Total Time: 4.998224 ms per frame
Avg Framerate: 40.414356 FPS (24.743681 ms)
Weighted Framerate: 40.349304 FPS (24.783573 ms)
CPU frame rate (estimated if not GPU bound): 100.144882 FPS (9.985533 ms)
Driver throughput (Batches per ms): 13234.747070 Batches
Average Batches per frame: 45805.218750 Batches
Total Time: 4.997542 ms per frame
Avg Framerate: 65.632271 FPS (15.236407 ms)
Weighted Framerate: 64.813210 FPS (15.428953 ms)
CPU frame rate (estimated if not GPU bound): 173.169327 FPS (5.774694 ms)
Driver throughput (Batches per ms): 3628.391113 Batches
Average Batches per frame: 2997.237793 Batches
== Shot End Scene =========================================
Total Time: 11.010176 ms per frame
Avg Framerate: 54.313396 FPS (18.411665 ms)
Weighted Framerate: 54.082642 FPS (18.490221 ms)
CPU frame rate (estimated if not GPU bound): 143.052200 FPS (6.990455 ms)
Driver throughput (Batches per ms): 6946.400391 Batches
Average Batches per frame: 11910.228516 Batches
My reliable tests were at 2560x1600 not 2560x1440. I did 1440 once and it didn't scale right because it's not a supported VSR option with my monitor. I couldn't screenshot the graph at the end because of this. Oh and note that AotS has a bug reporting the resolution as 0x0 randomly in the benchmark graph but the text log always seems to show the resolution properly.
got around to throwing my FX-4100 back into my system. so here's a compairison between a FX-4100 @ 4560 and a FX-8120 @4560
note: do to the glitching with the built-in AA I have it disabled and 2X msaa enabled in Crimson settings for all tests.
FX-4100 DX11 1440p high
GPU 0: AMD Radeon R9 200 Series 280x @ 1175/1750
CPU: AuthenticAMD
AMD FX(tm)-4100 Quad-Core Processor @ 4560
Physical Cores: 2
Logical Cores: 4
Physical Memory: 16300 MB
API: DirectX
Quality Preset: Custom
Fullscreen: True
Bloom Quality: High
Glare Quality: Low
Shading Samples: 8 million
Terrain Shading Samples: 8 million
Shadow Quality: Mid
Multisample Anti-Aliasing: 1x note: 2x enabled in crimson settings
Texture Rank : 1
Total Time: 60.003075 ms per frame
Avg Framerate: 23.357775 FPS (42.812298 ms)
Weighted Framerate: 22.989410 FPS (43.498287 ms)
Average Batches per frame: 12919.730469 Batches
BenchMark 0
Total Time: 70.875992 ms per frame
Avg Framerate: 36.020657 FPS (27.761847 ms)
Weighted Framerate: 35.321518 FPS (28.311354 ms)
Average Batches per frame: 4511.345215 Batches
Total Time: 55.932816 ms per frame
Avg Framerate: 26.513950 FPS (37.715992 ms)
Weighted Framerate: 26.056526 FPS (38.378101 ms)
Average Batches per frame: 9463.808594 Batches
Total Time: 53.200409 ms per frame
Avg Framerate: 15.883338 FPS (62.959061 ms)
Weighted Framerate: 15.672650 FPS (63.805416 ms)
Average Batches per frame: 24784.037109 Batches
FX-4100 DX12 1440p high
CPU: AuthenticAMD
Physical Cores: 2
Logical Cores: 4
API: DirectX 12
Fullscreen: True
Bloom Quality: High
Glare Quality: Low
Shadow Quality: Mid
Texture Rank : 1
Total Time: 60.008785 ms per frame
Avg Framerate: 37.756954 FPS (26.485186 ms)
Weighted Framerate: 37.429989 FPS (26.716545 ms)
CPU frame rate (estimated if not GPU bound): 39.071167 FPS (25.594322 ms)
Percent GPU Bound: 18.742697 %
Driver throughput (Batches per ms): 4707.592773 Batches
Average Batches per frame: 13673.628906 Batches
BenchMark 0
Total Time: 70.924339 ms per frame
Avg Framerate: 41.086037 FPS (24.339169 ms)
Weighted Framerate: 40.758305 FPS (24.534878 ms)
CPU frame rate (estimated if not GPU bound): 42.475876 FPS (23.542774 ms)
Percent GPU Bound: 13.546737 %
Driver throughput (Batches per ms): 3250.619385 Batches
Average Batches per frame: 4897.917480 Batches
Total Time: 56.031715 ms per frame
Avg Framerate: 38.620983 FPS (25.892660 ms)
Weighted Framerate: 38.299553 FPS (26.109966 ms)
CPU frame rate (estimated if not GPU bound): 39.926579 FPS (25.045973 ms)
Percent GPU Bound: 19.844965 %
Driver throughput (Batches per ms): 4441.711914 Batches
Average Batches per frame: 9828.972656 Batches
Total Time: 53.070293 ms per frame
Avg Framerate: 34.218769 FPS (29.223728 ms)
Weighted Framerate: 33.892799 FPS (29.504793 ms)
CPU frame rate (estimated if not GPU bound): 35.468262 FPS (28.194221 ms)
Percent GPU Bound: 22.836386 %
Driver throughput (Batches per ms): 5608.524902 Batches
Average Batches per frame: 26293.996094 Batches
FX-8210 1440p high
CPU: AuthenticAMD
AMD FX(tm)-8120 Eight-Core Processor @ 4560
Physical Cores: 4
Logical Cores: 8
API: DirectX
Fullscreen: True
Bloom Quality: High
Glare Quality: Low
Shadow Quality: Mid
Multisample Anti-Aliasing: 1x 2x enabled in crimson settings
Texture Rank : 1
Total Time: 60.010567 ms per frame
Avg Framerate: 26.606812 FPS (37.584362 ms)
Weighted Framerate: 26.064182 FPS (38.366829 ms)
Average Batches per frame: 12753.724609 Batches
BenchMark 0
Total Time: 70.858635 ms per frame
Avg Framerate: 44.638176 FPS (22.402349 ms)
Weighted Framerate: 43.311378 FPS (23.088621 ms)
Average Batches per frame: 4438.385742 Batches
Total Time: 56.008324 ms per frame
Avg Framerate: 30.709721 FPS (32.562977 ms)
Weighted Framerate: 30.103165 FPS (33.219101 ms)
Average Batches per frame: 9447.793945 Batches
Total Time: 53.164730 ms per frame
Avg Framerate: 17.304707 FPS (57.787746 ms)
Weighted Framerate: 17.008896 FPS (58.792763 ms)
Average Batches per frame: 24374.990234 Batches
FX-8120 DX12 1440p high
CPU: AuthenticAMD
Physical Cores: 4
Logical Cores: 8
API: DirectX 12
Fullscreen: True
Bloom Quality: High
Glare Quality: Low
Shadow Quality: Mid
Texture Rank : 1
Total Time: 60.007462 ms per frame
Avg Framerate: 41.143223 FPS (24.305340 ms)
Weighted Framerate: 40.456188 FPS (24.718096 ms)
CPU frame rate (estimated if not GPU bound): 55.626465 FPS (17.977055 ms)
Percent GPU Bound: 88.015099 %
Driver throughput (Batches per ms): 4276.850586 Batches
Average Batches per frame: 13625.298828 Batches
BenchMark 0
Total Time: 70.998451 ms per frame
Avg Framerate: 48.747543 FPS (20.513855 ms)
Weighted Framerate: 47.691422 FPS (20.968132 ms)
CPU frame rate (estimated if not GPU bound): 62.852825 FPS (15.910184 ms)
Percent GPU Bound: 75.486008 %
Driver throughput (Batches per ms): 3377.241455 Batches
Average Batches per frame: 4823.318359 Batches
Total Time: 55.999081 ms per frame
Avg Framerate: 42.714985 FPS (23.410988 ms)
Weighted Framerate: 41.889503 FPS (23.872330 ms)
CPU frame rate (estimated if not GPU bound): 59.831779 FPS (16.713526 ms)
Percent GPU Bound: 90.587875 %
Driver throughput (Batches per ms): 4247.091797 Batches
Average Batches per frame: 9874.906250 Batches
Total Time: 53.024853 ms per frame
Avg Framerate: 34.493259 FPS (28.991171 ms)
Weighted Framerate: 34.113594 FPS (29.313828 ms)
CPU frame rate (estimated if not GPU bound): 46.931927 FPS (21.307457 ms)
Percent GPU Bound: 97.971405 %
Driver throughput (Batches per ms): 4732.761719 Batches
Average Batches per frame: 26177.669922 Batches
it'll be sweet if this type of improvement can be had in other DX12 games!
CPU: AuthenticAMD
Physical Cores: 2
Logical Cores: 4
API: DirectX
Fullscreen: True
Bloom Quality: High
Glare Quality: Low
Shadow Quality: Mid
Texture Rank : 1
BenchMark 0
CPU: AuthenticAMD
Physical Cores: 2
Logical Cores: 4
API: DirectX 12
Fullscreen: True
Bloom Quality: High
Glare Quality: Low
Shadow Quality: Mid
Texture Rank : 1
BenchMark 0
FX-8210 1440p high
CPU: AuthenticAMD
Physical Cores: 4
Logical Cores: 8
API: DirectX
Fullscreen: True
Bloom Quality: High
Glare Quality: Low
Shadow Quality: Mid
Texture Rank : 1
BenchMark 0
CPU: AuthenticAMD
Physical Cores: 4
Logical Cores: 8
API: DirectX 12
Fullscreen: True
Bloom Quality: High
Glare Quality: Low
Shadow Quality: Mid
Texture Rank : 1
BenchMark 0
Wow! DX12 actually can make use of more cores. Yes I hope more DX12 makes use of the whole cpu. One could argue that it was software holding back AMD cpu's vice just a weak cpu. Weak per core but not weak whole cpu. Except for floating point where AMD just bombs.
System in sig. DX12, dual GPU mode, crazy settings, 3 v 3 online game with me hosting. Flawless performance. No slowdown on my end. Six cores 12 threads. Game did not slowdown once. It never seemed to get quite a crazy as a Supcom game though.
I think it is a worthy benchmark. You a need a good rig for this.
With my Haswell-E 6 core my general impression during actual gameplay is that the game responds better at 4.0GHz than at 3.7. This is the first game where pushing Haswell-E seems to actually make a difference. Just my opinion.
