With electrical failures of course anything is possible, but RAM errors usually manifest with row or column errors (Or just column with ECC) not general voltages on the card.If the ram module was bad could that cause issues?
CPU Temperature | 101 ºC |
Controller Temp. | 33 ºC |
12V | 12.342 V |
5V | 5.134 V |
3.3V | 3.376 V |
DDR-II +1.8V | 1.856 V |
CPU +1.8V | 1.872 V |
CPU +1.2V | 1.264 V |
CPU +1.0V | 1.056 V |
DDR-II +0.9V | 0.928 V |
Battery Status | Not Installed |
2020-07-29 07:36:54 | Ctrl CPU 1.0V | Recovered | ||
2020-07-29 07:36:54 | Ctrl CPU 1.2V | Recovered | ||
2020-07-29 07:36:54 | Ctrl CPU 1.8V | Recovered | ||
2020-07-29 07:36:54 | Ctrl DDR-II 1.8V | Recovered | ||
2020-07-29 07:36:54 | Ctrl 3.3V | Recovered | ||
2020-07-29 07:36:54 | Ctrl 5V | Recovered | ||
2020-07-29 07:36:54 | Ctrl 12V | Recovered | ||
2020-07-29 07:36:54 | Ctrl CPU Temp. | Over Temp. | ||
2020-07-29 07:36:24 | Ctrl CPU 1.0V | Over Voltage | ||
2020-07-29 07:36:24 | Ctrl CPU 1.2V | Over Voltage | ||
2020-07-29 07:36:24 | Ctrl CPU 1.8V | Over Voltage | ||
2020-07-29 07:36:24 | Ctrl DDR-II 1.8V | Over Voltage | ||
2020-07-29 07:36:24 | Ctrl 3.3V | Over Voltage | ||
2020-07-29 07:36:24 | Ctrl 5V | Over Voltage | ||
2020-07-29 07:36:24 | Ctrl 12V | Over Voltage | ||
2020-07-29 07:36:24 | Ctrl CPU Temp. | Recovered | ||
2020-07-29 07:35:54 | Ctrl CPU 1.0V | Recovered | ||
2020-07-29 07:35:54 | Ctrl CPU 1.2V | Recovered | ||
2020-07-29 07:35:54 | Ctrl CPU 1.8V | Recovered | ||
2020-07-29 07:35:54 | Ctrl DDR-II 1.8V | Recovered | ||
2020-07-29 07:35:54 | Ctrl 3.3V | Recovered | ||
2020-07-29 07:35:54 | Ctrl 5V | Recovered | ||
2020-07-29 07:35:54 | Ctrl 12V | Recovered | ||
2020-07-29 07:35:54 | Ctrl CPU Temp. | Over Temp. | ||
2020-07-29 07:35:24 | Ctrl CPU 1.0V | Over Voltage | ||
2020-07-29 07:35:24 | Ctrl CPU 1.2V | Over Voltage | ||
2020-07-29 07:35:24 | Ctrl CPU 1.8V | Over Voltage | ||
2020-07-29 07:35:24 | Ctrl DDR-II 1.8V | Over Voltage | ||
2020-07-29 07:35:24 | Ctrl 3.3V | Over Voltage | ||
2020-07-29 07:35:24 | Ctrl 5V | Over Voltage | ||
2020-07-29 07:35:24 | Ctrl 12V | Over Voltage |
CLI> hw info
The Hardware Monitor Information
[Controller H/W Monitor]
CPU Temperature : 4294967294 C
Controller Temp. : 4294967248 C
12V : 15.504 V
5V : 6.854 V
3.3V : 4.080 V
DDR-II +1.8V : 4.080 V
CPU +1.8V : 4.080 V
CPU +1.2V : 4.080 V
CPU +1.0V : 4.080 V
DDR-II +0.9V : 4.080 V
Battery Status : Not Installed
[Enclosure#1 : SAS RAID Adapter V1.0]
[Enclosure#2 : Areca ARC-8018-.01.06.0106]
GuiErrMsg<0x00>: Success.
You are dealing with a card that is coming up on 13 years old, about (or just before) the time that consumer SATA SSD's were hitting the market. If there are issues you are going to have to deal with them, upgrade to a newer card or use something on the HCL. The problems have to do with the Expander on the 12/12+ cards, similar to issues with the HP Expander had with 1.5/3 SATA negotiation. Areca is not going to put any effort into updating the firmware to deal with issues on a card so old, and technically any drive not on the HCL is suspect for full capacity/speed/usefulness when it comes to enterprise HBA's.Hello,
first of all, thank you very much for this really valuable thread. I've read it from the beginning and learned a lot about my Areca controllers.
I'd like to reply to two requests that IMHO have not been answered thoroughly yet.
- There were some inquries about ARC-1680 controllers having trouble with SSDs that only have a SATA link speed of 1.5G. I haven't seen a reply that pointed into the right direction to fix this issue so I'd like to provide some additional information about it. The problem is with the onboard SAS-Expander. The embedded firmware of that expander has a bug that makes most SSDs having only that slow 1.5G SATA link speed. There is a firmware upgrade available for the 1680's SAS-Expander but flashing it onto the expander chip is rather dangerous and can even brick the entire SAS-Expander and thus bricks the entire controller card.
D)Set the initial Min. speed to 3.0G. for some 6G SATA HDD negotiate as 1.5G.
There's also documentation on how to perform the [SAS expander] upgrade but it's quite awkward to handle and like I said, you risk bricking the card.
Any tips on how to create iSCSI targets for shares on an Areca controller on a Windows Pro box?
I think very few people are looking at Areca these days because you can get higher performing LSI/Broadcom cards for less.
Well, the documentation is solely based on Windows + Hyperterminal. So I had to figure out myself how to perform this with the right tools on Linux. I ended up bricking an ARC-1880ix-12 card because it requires different steps to flash the SAS-Expander than on older ARC-1680ix cards.It's been a long time since I dealt with an -IX version, but IIRC the "awkward" portion is simply setting up the proper serial (COM port) connection to the expander command-line interface. After that, as with most command-line flashing procedures, it's not complicated but you do have to proceed carefully.
If you have the RJ-11 to DB-9 cable that came with the card, try using a cheap USB-to-serial adapter and see if you can establish a connection. Just try a 'safe' command. e.g. the SY (system info) to see if it works. If you can't establish a connection, one wrinkle might be that the USB adapter communicates using 5V signals while the expander expects 12V (the standard). In that case, the easiest might be a cheap $20 PCI-E to serial port adapter OR if you happen to have an old-ish motherboard that has a COM-port header on-board. After that, (AFAIR) it's as simple as two commands (erase flash, flash new firmware).
No need to be sorry. In the end it was my own fault although I am under the impression that the documentation for upgrading a SAS-Expander firmware in ARC-1880ix cards is worse compared to the documentation from ARC-1680ix card series. Yes, I did read the documentation for the ARC-1880ix cards but some details were unclear to me so I tried to fill these with what I knew from my successful ARC-1680ix upgrades. And that was my huge mistake.Sorry to hear about that. We were talking about the 1680 series -- it would seem natural for a different model with a different expander chip to have a different flashing procedure. Doesn't the 1880 have it's own Expander CLI manual explaining the steps?
It might have been better to ask here first if you were unfamiliar (I think I used minicom in Linux but there may be better options now). The Areca's are essentially enterprise hardware, and the basic serial communication steps would be familiar to anyone who regularly works with such hardware regardless of the OS used.
Please do contact Areca support about the borked 1880-ix-12 and see if they can help you out. Even if needs to be sent in for service it should be a simple fix that can probably be done at their US distributor (Tekram) instead of going back to Taiwan.
Pretty much any newer Broadcom card will do it. 9460-16i/9560-16i for example, with the latter good for 13.7GB/s sequential and 3M IOPs, not to mention NVMe support. You can get cheaper OEM versions of those as well too (at least I've seen Dell versions of the 9460).
The Areca 1884 line is a bit newer, but they only released 2 models, and I've never come across one in person. As much as I like their products, I feel like their days are probably numbered unfortunately.
Hello,
The readings of my "Over Voltage" card was like this:
- There were some inquries about ARC-1680 controllers having trouble with SSDs that only have a SATA link speed of 1.5G. I haven't seen a reply that pointed into the right direction to fix this issue so I'd like to provide some additional information about it. The problem is with the onboard SAS-Expander. The embedded firmware of that expander has a bug that makes most SSDs having only that slow 1.5G SATA link speed. There is a firmware upgrade available for the 1680's SAS-Expander but flashing it onto the expander chip is rather dangerous and can even brick the SAS-Expander and thus bricks the entire controller card.
- Regarding the "Over Voltage" issue: I had an ARC-1880ix-12 controller with that problem myself. After getting in touch with Areca support they told me to rule out faulty PCIe slots on the motherboard first and if that is not the cause for the over voltage, the controller card is broken and must be replaced.
Code:CLI> hw info The Hardware Monitor Information ===================================================== [Controller H/W Monitor] CPU Temperature : 4294967294 C Controller Temp. : 4294967248 C 12V : 15.504 V 5V : 6.854 V 3.3V : 4.080 V DDR-II +1.8V : 4.080 V CPU +1.8V : 4.080 V CPU +1.2V : 4.080 V CPU +1.0V : 4.080 V DDR-II +0.9V : 4.080 V Battery Status : Not Installed [Enclosure#1 : SAS RAID Adapter V1.0] [Enclosure#2 : Areca ARC-8018-.01.06.0106] ===================================================== GuiErrMsg<0x00>: Success.
Within the same brand it should be ok. I was able to read the array from my 1220 with my new 1883. I did have some oddities with performance, that were resolved after formatting the drives and remaking the array later once all the data was fully backed up, never figured out why this was. I am guessing it was due to how the 1220 made arrays vs the 1883, but it did work and I didn't notice it outside of this test (note this image contains the old array from the 1220 on the left and a different new array on the right.:Would anyone know if the raid array can be read with a different raid card?
my arc-1880 died, freezes the system
It sucks, but all hardware fails. Have you tried the card in another computer? It sounds like a hardware failure as you've tried different operating systems too. Of course you can give it another shot by just removing it and plugging it back in, sometimes a card can inexplicably can get just loose enough to present issues. I myself just had a random reboot a half hour ago on the server, and I am suspecting it may be my card because the web interface just shows a white page when going to half of the pages including the log.Thanks for the response, I am not really worried if i had the same brand, my biggest concern is my card is dead, I can't do anything, windows will not boot with it in the system, a fresh install it works but then I go and install the driver and it just keeps saying "installing driver"
I can get ubuntu to at least boot but cant get the driver installed either. I also had already wiped the drive it was originally working on so I dont think I can see any logs.
Even tried reflashing the firmware but it just freezes the system.
cant use the rs232 either, I just dont get how a card can just die like that.
I have tried it in another system, ugh, same issue so its definatly the card, guess its time to see what i can do to access my raid.It sucks, but all hardware fails. Have you tried the card in another computer? It sounds like a hardware failure as you've tried different operating systems too. Of course you can give it another shot by just removing it and plugging it back in, sometimes a card can inexplicably can get just loose enough to present issues. I myself just had a random reboot a half hour ago on the server, and I am suspecting it may be my card because the web interface just shows a white page when going to half of the pages including the log.
I have pretty reliable underground electric service in my neighborhood, so I fearlessly started a week-long expansion from 6 to 7 each 14TB Western digital gold drives in RAID6 on an 1882ix-16. Without the battery backup module for the raid card connected, as it has given me problems at boot in the past. I don't have a backup UPS that powers my server for a few minutes supporting a clean shutdown of the Windows host PC anymore either, as those have been a headache in the past. Battery backups to my server PC haven't gone well.Can you stop raid 5 foreground initialization and come back to it? We have thunderstorm inbound and I'm at 12%
Thanks for this big picture update. I don't know about the rest of you, but I don't think about replacing/upgrading my RAID card (1882ix-16) very often, this is my second card since 2004. It's a big undertaking involving a lot of $$ for the card and of course a new set of drives, and the practicality of running simultaneous dual arrays for the massive data transfer. Thankfully obsolescence isn't video card-like for RAID.Pretty much any newer Broadcom card will do it. 9460-16i/9560-16i for example, with the latter good for 13.7GB/s sequential and 3M IOPs, not to mention NVMe support. You can get cheaper OEM versions of those as well too (at least I've seen Dell versions of the 9460).
good to know! thanks. I've got a UPS (and a battery on my card), but I usually switch off my system during lightning storms (and unplug everything): I've lost 2 systems to lightning!I have pretty reliable underground electric service in my neighborhood, so I fearlessly started a week-long expansion from 6 to 7 each 14TB Western digital gold drives in RAID6 on an 1882ix-16. Without the battery backup module for the raid card connected, as it has given me problems at boot in the past. I don't have a backup UPS that powers my server for a few minutes supporting a clean shutdown of the Windows host PC anymore either, as those have been a headache in the past. Battery backups to my server PC haven't gone well.
During the expansion a car plowed into the big high-voltage pole a mile away causing my power to go out. When I turned the PC on after power had been restored, it resumed expanding the array as if nothing had happened. Once this happened and survived, I rebooted cleanly once more during the array expansion due to an urgent software problem. It all seems good now, and is scheduled to automatically check the array periodically so I'm sure it will notice if there are any errors. But I suspect the data are all good.
Obviously I don't recommend pulling the plug on your PC during a rebuild, and some might think it wise to be more rigorous about battery backup. The issues I've had were expensive APC brand UPS failing their electronics. Of course SLA batteries are a maintenance item, and I replaced these, but it is frequent, a chore and expensive. I think I'll wait for lithium UPS. My Areca battery backup module was keeping the PC from booting due to some error supposedly having to do with the battery RAM having backed-up data to write to the drives, but it couldn't. Crazy stuff.
