Hey, I currently have a 2x1.5 TB RAID 0 array on my motherboard's ICH10R controller. I'm looking to expand my array and convert it to RAID 5, but I'd like to use a hardware card instead of my motherboard's ICH10R for expandability (I'd like to be able to expand my new array to 8 HDDs) and performance (I've heard bad things about ICH10R's RAID 5 performance, as it's fakeraid).
I should mention that I'm running Windows 7 Professional x64 on a single 500 GB hard drive, separate from my big media array. I'd like to keep my OS (as well as a SATA CD/DVD burner) running on my motherboard's SATA controller.
My plan is to buy 3 more 1.5 TB HDDs and a RocketRAID card, use the new disks to create a RAID 5 array on the new card, copy my existing data over, and then move the 2 drives on my motherboard's RAID controller to the card.
I've basically found two RocketRAID cards that I am considering. The first is the RocketRAID 2680, which is a PCIe x4 card that doesn't have a built-in processor for parity calculations (but supposedly performs better than the ICH10R, and would provide more expandability anyways). The second is the RocketRAID 4320, which is a PCIe x8 card that does have a built-in processor for parity calculations.
The RocketRAID 2680 is $275, and the RocketRAID 4320 is $400.
(They both have two internal SFF-8087 mini-SAS ports. I've never used SAS before, but I think I can just buy a breakout cable that'll give me 4 SATA ports for each SFF-8087 mini-SAS port - can someone confirm this?)
Now, I have a decent processor (i5 at 3.2 GHz), so I assume the performance gain in getting a truly dedicated card wouldn't be significant (I rarely use much CPU anyways, and I don't plan on reading/writing the array often). At least, not $125 significant.
What I'm mostly concerned about is reliability. Does anyone here use RocketRAID cards? If my card breaks 2-3 years from now, will I be able to buy the current equivalent RocketRAID model and still keep the data on my array?
(Also, will I be able to run RAID on both the card and on my motherboard while I copy my existing data over?)
Thanks in advance for the help!
PS: I'd also like to encrypt my new array with TrueCrypt - I assume it'll work fine, but if someone could confirm this, that'd be great.
