Anything better than Intel's SSD drive
zod96
Suspected BAD TRADER
I've heard that the OCZ vetex 2 is supposed to be faster in both read and writes then the Intel SSD, is this true and are they out yet? Or is Intel still the fastest for both read and writes..
I have Vertex in one computer and Intel in another. In real world they are so fast that speed difference doesn't make a difference. It's like two cars - one has 550 HP and another 575HP......
As of now, there is nothing in the consumer market that is faster than Intel's SSDs. There are some high-performance market related products, but they're all running from the PCI-E slot and are priced considerably higher. As the above poster has stated, as long as you stay with a drive that has a Intel, Indilinx, or Samsung controller, you'll be good. Benchmarks show a difference, but you won't be able to tell during actual usage.
The Vertex 2 aren't out yet, and in all likelihood they'll be more expensive than the current Vertex line (new controller and 34nm flash IIRC), I think they're starting at 120GB as well. They should be faster than Intel's X25-M, or at 'least on par, but AFAIK the only testing out there has been w/pre-release drives (and there's little info on specific dates/prices).
As far as the current Vertex/Agility drives vs Intel's... The X25-M still holds the crown as far as random read/writes (more important than sequential for most purposes), but the Vertex drives are significantly faster at sequential writes ('specially compared to the 80GB X25-M, or the 40GB X25-V which has pretty low sequential write speeds).
Real world the difference is pretty insignificant unless you have some pretty high-end scenarios in mind that could take advantage of the Vertex's sequential write speeds (and a source drive or processing power to saturate it from the other end). There'll be lots of competition for Indillix and Intel this year from SandForce-based drives (e.g. Vertex 2), Micron, and possibly Seagate... But it doesn't look like prices will be dropping too soon.
Demand has kept the price of flash high, more competition = more demand (from manufacturers and consumers).
Yeah, here's to hoping that the 80GB X25-M G2 becomes available for something close to MSRP again before Intel replaces it w/something else... So I can add a second one to my system. :p 160GB total for an additional $200-ish would be perfect, I doubt I'd need to upgrade those puppies for a few years.
