BoostFrenzy
- Nov 22, 2004
They're popping up out there, should have a couple where I work tommorow, going to try one in my IP35
Ditto, I have one ordered for my IP35-E... will update this when I get some results![]()
There are ppl at XS that are getting them from MicroCenter.
-bZj
What's microcenter's return policy on cpu's??![]()
Hey BoostFrenzy, preliminary retail/oem shows that these chips don't overclock as well as expected. Remember that they are 45nm and you cannot pump the same amount of voltage to them as you can with a 65nm. For example, 1.55 through a 45nm chip is the same as 1.65 through a 65nm chip. People at xtremesystems have shown that the maximum attainable OC at safe voltage (1.45) is 3.8 Ghz. It was also revealed that E8400 is not stable at 4 Ghz at any voltage.
For now, as it seems, the early batch of 45nm cpus fell short of expectations.
http://www.hardforum.com/newreply.php?do=newreply&p=1031939977
Wow that is dissapointing.
[/quote]
http://www.ocforums.com/attachment.php?attachmentid=62111&stc=1&d=1200735400
From another forum, and i've seen a few other people with retail chips getting over 4ghz. Whatchu talkin bout willis?
For the people that have one already overclocked to 4ghz + may I ask you to share your experiences with it with real work apps(encoding, winrar). For example on my e6320 overclocked to 3.2ghz it takes me 9-10 secs to unrar a 100mb file and about 4 min to unrar a 5 gb rar file.
Seeing any marginal or greatly increased performance ?
it's 800mhz faster with 2mb more cache, you figure it out by downclocking your chip 800-900mhz and see haha.
At default voltage and speed, after a few hours of Orthos, core 0's temperature is 64c and core 1 is 58c. Isn't this way too hot? Not to mention that I'm using Thermalright Ultra 120 Extreme as well.
There are many ppl going over 4GHxz with them now over at XS. Some reach toward 5GHz. Luck of the draw - give them some time to hit the channels.Hey BoostFrenzy, preliminary retail/oem shows that these chips don't overclock as well as expected. Remember that they are 45nm and you cannot pump the same amount of voltage to them as you can with a 65nm. For example, 1.55 through a 45nm chip is the same as 1.65 through a 65nm chip. People at xtremesystems have shown that the maximum attainable OC at safe voltage (1.45) is 3.8 Ghz. It was also revealed that E8400 is not stable at 4 Ghz at any voltage.
_________
Those are engineering samples cooled with dry ice. You aren't likely to reach the same OC with a retail chip.
Up until last night, I didn't even dream about running a CPU at 4Ghz on air.
I still can't believe, I'm typing this on a 4Ghz system.
As I was paying for this CPU at a local Microcenter, I was telling myself that it was a waste of money. Now I don't regret at all.
This E8400 is doing 4Ghz w/ 1.34V (speedfan reading), and it's been rock solid for almost 12 hours on Prime 95. The maximum temperature it reached was around 54C, and idles at 33C (Core Temp) right now.
The latest Core Temp reading is about 5C higher than that of Speedfan beta 37. Which one is correct?![]()
I am thinking about dropping my B3 Quad for one of these....
Sad.
Does it type fast?
