FC-PGA Ryzen using decade old technology.
Hope you guys dont break off your pins
there is over 1300
Yeah, I got a pair needle nose tweezers and a huge ass magnifying glass for that work.I have successfully fix many cpus with that method but have NEVER successfully fixed bent socket pins on an intel board.
Yes, it is such a difficult operation, that I suggest you never undertake it.Compared to CPU pins it is much harder.
I do not have one to share with you. My sincerest of apologies.So where is your "easy to do" video? You keep linking one from nearly a decade ago regarding pins, make one for socket pins to show how super easy it is.
question....how the fuck do you bend the pins? I have never bent any pins since P3 socket, P4, Athlon barton (or any of the earlier AMD chips...don't even recall the names), athlon X whatever, nahalem and IB laptops CPUs
Are people retarded?
This is like 15ish CPUs I have removed and installed several times.
I have shorted boards before but never bent a pin.
This might change my buying decision
Hopefully with pins on the CPU we won't hear that god awful crunching sound when putting the clamp down like on an Intel LGA processor.
Give me pins over 'oh fuck grid array' any day. Pins are fixable if you're careful, lga has low success rate in this regard...
That said have not had any major issues with each.
I've got no problems with AMD not moving desktop parts to LGA setup just yet, even though they apparently did with the Opterons a while ago. It's less issues they have to deal with when they really need a win right now. I would hate to see their new CPU socket cause headaches for people to ditch AMD altogether.Give me pins over 'oh fuck grid array' any day. Pins are fixable if you're careful, lga has low success rate in this regard...
Oh noes.. pins on a CPU.
Much easier to fix AND see than slightly out of place LGA socket pins.
Why change a good technology intels reasoning was not great for switchingFC-PGA Ryzen using decade old technology.
there is over 1300
Never bent a pin in my life. I have known people who pulled their CPU right out of the socket, HSF attached, and bent pins though. I always use a hair dryer to soften the thermal paste before removing the HSF, on AMD and Intel systems. Especially if you know Arctic Silver x was used as the thermal paste. That stuff bonds like super glue after a few months.
Just to add to my comment, there's a video somewhere of a person using a bank/credit card to straighten pins.
Am I the only one that wipes the bottom contacts of a Intel CPU with isopro before installing it?
