The Yorkfields don't overclock very well compared to Wolfdales. If you're into overclocking.
Nope, will use it as is.
They are more expensive and run at a slower clock speed, stock, than their dual core siblings. But as mentioned, yorkfield quads are just 2 wolfdale duals dropped on one package (same as kentsfield/conroe was).
E8500 costs the same as a Q6600 but has a clockspeed 33% faster. Id say go for the Q6600 and run a 1333 or 1600Mhz FSB, but thats just me.
are the 45nm quad significantly cooler than 65nm quad
Only thing negativ is that there are not 8 cores![]()
There are a few negatives.I'm thinking of getting a 2.4ghz quad, other than apps not taking the fullest advantage of the quad, are there any negatives about it I should know about?
The argument for dual and quad core processors remains relatively unchanged with Vista. For multitaskers and many CPU-intensive workloads, a dual core CPU makes perfect sense. Vista doesn't make the argument for dual or quad core any more compelling than XP in our opinion; the additional background tasks that run in Vista that weren't present in XP don't really eat up that much CPU time to begin with, so dedicating an entire core to them isn't necessary.
The new applications in Vista don't appear to be any more threaded than XP, despite Vista being heralded as the beginning of a highly threaded future. Microsoft Word remains single threaded, although Excel can now take advantage of multiple cores when performing calculations. Windows Movie Maker seems to be optimized for two cores, while importing and attaching files in Photo Gallery is surprisingly single threaded. Dual core still makes a big difference in the overall experience, while quad core still isn't necessary but remains useful for a handful of situations.
1. Lower clock speed. This effects you in several ways. First, considering there is not a single game in existence that properly utilizes 4 cores, you'll be losing performance here. You can either run a game on 3GHZ dual core, or a 2.4GHZ dual core, which is essentially what your getting if you put a quad in a system you game on because games will only use 2 cores.
A couple of things.
They run warmer, so make sure you have good cooling.
They put more stress on the system bus due to having 4 cores so they can be kinda flaky/picky when you overclock them.(More sensitive to stability issues) If that makes sense.
Good things.
4 Cores
4 Cores
4 Cores
4 Cores..........![]()
It depends on the game and resolution you're playing on. Once you start playing at above 1280x1024 or so, you become more GPU limited than CPU limited. In fact at 1680x1050 with most games, you'll see absolutely no difference between the 3GHz E8400 and 2.4Ghz Q6600. Not that many games will see a performance increase with an increase in clock speed. But I will concede that many games will not see a performance increase with an increase in amount of cores.
So if you are playing games at 1024x768, then by all means get the E8400 or dual core CPU. But if you start playing around 1280x1024 and above, neither CPU will have a major advantage over the other in many games.
Proof for my argument:
http://www.guru3d.com/article/cpu-scaling-in-games-with-quad-core-processors/1
Most processors nowadays are so fast in everyday apps, that a quad core like the Q6600 at that speed will be fast enough for anything that you want to do. You are loosing 600MHz compared with the dual core. While this sounds like a lot, in reality, it isn't. Instead, you are getting an extra two cores, which you will find really helpful if you multitask a lot.
Yeah, the 8400 eats less power and has a higher overlcocking potential, but if I'm going to be running COD4 while alt-tabbing out to my email, Excel spreadsheet, several instances of IE and some other junk I'd rather have the quad.
There are 2 exceptions to my remarks though.
1. The new q9650 quad is @ 3ghz and would compare to the e8400/e8500 for everything because even if you only use 1-2 cores, it's still 3ghz and the same core as the fast dual cores. It would be a better chip obviously for the times you do need more than 2 cores. But you're going to pay over $300 for it and it's not even out yet...
Reason I like this is because Hyperthreading is a CPU level threading procedure where no software coding is needed. The cpu itself runs 2 threads on the same core w/o any software telling it to do so. You're going to see big gains from that.
Sarcasm?3.0Ghz x 2 = 6Ghz processing power
2.4Ghz x 4 = 9.6Ghz processing power
Sarcasm?
Each core is clocked at that specific frequency, you can't multiply them together to get a mega frequency.
If the software isn't multithreaded, it'll be the same (more or less) as running it on a single core chip at the same frequency.
