Any Logitech G700 mouse owners?
Anyone go to this from a MX510/518/G400/etc.? Would you say the G700 is smaller or bigger?
What is the closest comparable non gaming mouse to this? Only type of mice I can find locally on display to compare in terms of grip.
This is similar to the G500 but more ergonomic so its more comfortable. I tried the G500 for over a week and could never get comfortable with it. The G9 and Razer DeathAdder fit my hand best but I loved the looks of this thing, the build quality, the precision of the sensor and all the buttons and features so I went with it and it took me a couple days to finally get comfortable with it. If youre coming from a bigger mouse then this one should fit you just right. It might be a little smaller but its very ergonomic and so its not that hard to get comfortable with.
The only downside is the weight when youve got the battery in. You can use it wired but you dont really want to as the cord is pretty heavy and pulls on it. I took a small hook made for picture frame hanging and screwed it into the bottom of my desk and I run the cord thru that which pulls it up and away (my mouse is on a keyboard drawer so it sits lower than the desk). This works very well and now I can use my mouse corded while it charges without much change from the way it feels when its running cordless. Doing this has helped immensely and I use the mouse corded most of the time now.
It might be more ergonomic but the G700 has always felt like it has less pinky/ring finger room to me... At least when I've tried it in stores, could be the store shelf angle is throwing me off. That's actually kept me from buying it for a while now tho.
Thats funny you said that cause that is the exact reason I returned my G500 after a week. No matter how I positioned my hand, I could not get my pinky finger to rest comfortably anywhere either on the mouse or on the pad. I tried for over a week but never could figure it out. The G700 doesnt have that problem. Its short enough that I can rest my pinky on the mouse pad when Im not really moving it like in web surfing but tall enough or at least shaped right to where I can rest my pinky on the side of it when Im gaming.
That's definitely the mouse, not your perception of it....lol.
My problem (still) is the weird random spin outs (for lack of better words) I experience in game. It's starting to wear me down more and more too. I even just got my new G700 in the mail from Logitech a couple days ago and this one does it too. So it's either the mouse pad I'm using or this mouse loses itself here and there every so often.
I'm now hoping it's the mouse pad (here's my current pad) but I can't find one as good, in similar size, yet.
Anyone have any recommendations?
(A small one is no good to me)
Also, this reviewer on newegg says the same exact thing about this mouse pad (Of course I found this after I RMA'd my mouse).
I dont have that problem. Ive got about 100 hours gaming with this thing by now and Ive never noticed the pointer moving anywhere I dont move it myself. The precision and accuracy of this sensor is surgical.
What pad do you use? I have a TV satellite literally right out the window and 100 things plugged in, in my room. Wonder if it's the pad or interference. :(
My old G700 and my new one do it. I mean it's like 3-5 times in a gaming hour so it's not every other minute but it always seems to happen right when I need the most accuracy.
I can even show you in the theater on mw3 where I was 15-0 on seatown and get blasted by a shottie while I'm spinning in circles....lol
Razer Goliathus. Its nothing really special, just a basic mouse pad.
Wonder if it could be your software. When I installed the drivers for my G700, I now have to run it as administrator otherwise it wont open. My G9 software worked perfectly for over 2 years. The software for my G510 is buggy as hell too so it could be your problem. Maybe uninstall it, run Driver Sweeper and use the Windows drivers for a bit and see if that changes anything.
Its worth fixing cause this is an absolutely awesome mouse. Now that Ive figured out the pain in the ass cord problem, Im loving this thing and I didnt think Id ever find a replacement for my DeathAdder.
I'm going to have to try out the Razor Ironclad or the Megasoma because I need something accurate as possible and the mat I have isn't cutting it. When I change up the pad and it goes away, great, love the mouse. However if it's still there after the recent RMA and a $50 mouse pad, the mouse is gone too (shrugs)!
Try the software bug theory too. I wouldnt be surprised if its that. Like I said, my G510 software is buggy and my G700 is screwy. Dont know why Logitech can make such superb hardware, have such great customer service and support and have beautifully laid out and designed software but have so many bugs in it.
It might be interference. Can you try the mouse elsewhere (away from the satellite for instance) and see if the same issues occur?
Are you referring to setting up the mouse than uninstalling the setpoint 6.32 software?
Just want to confirm...
I was just wondering if the software itself could be causing the pointer to jump wildly. I was thinking uninstalling it completely and just letting Windows drivers run it.
Also, if it still jumps around with the cord hooked up then I doubt its interference. When you have the G700 plugged in, its working as a wired mouse and not using the wireless receiver thingy.
Hmm, I don't like placing my finger like that... I have fairly long fingers but I still want them firmly on the mouse, whether on top or around the side. That's weird, when I've tried them in stores the G500 felt like it had a larger RMB or more surface around it. Meh, gonna have to get them side by side sometime.
It does but I couldnt get my finger to rest comfortably on there. The G700's right side is kinda concave I guess would be the best way to describe it. I can rest my pinky on there while moving it around and itll stay put. On the G500 I had to hold it there as opposed to resting it there. Right now while cruising around websites, Ive kinda got my pinky resting mostly on the mouse pad. Now when I fire up Mass Effect 3 in a few minutes, Ill have it resting on the mouse. Ive got weird hands. Theyre wide but my fingers are short and stubby so its hard for me to get them to fit on things. I have to wear XL gloves but my fingers wont go all the way to the ends. If I wear large gloves, they cut the circulation off because theyre so tight around my hands. Ugh. :rolleyes:
Heh, we've got completely opposite hands then, long skinny ass fingers here. I think I understand what you mean about the difference between the mice tho, thanks...
Seems like picking a new mouse will be somewhat problematic due to lack of demo units.
I guess I'll have to make do with trying it out in the cardboard packaging.
Some places have a very generous return policy. Best Buy has a 30 return/exchange policy for their mice and keyboards so give them a try. Check with them though as YMMV depending on your store.
My Razer Imperator seems to have an issue with cloth mousepads; lots of cursor drift.
However, my plastic surface Half-Life 2 mousepad does not cause it. But it might also have to do with the pattern as I get drift on this HL2 pad near the edges, but it happened on every part of the cloth mousepad.
