Another Reason To Secure Your Wireless Connection
HardOCP News
[H] News
If you don’t want to be thrown to the ground and handcuffed while your house is being raided by the authorities…for the love of god, secure your wireless connection.
Deputies arrested Candice Miller only after they raided the wrong house. Investigators busted into the neighbors' house suspecting they were sending child porn. Turns out Miller's neighbors didn't secure their wireless Internet connection.
With at least WPA2.
I live in an apartment complex and at least 100% are secure but 1/2 of them are using WEP. :eek:
At my house, my laptop sees 4 out of the 7 connections as unsecured. Mine being one of the secured. It's pretty bad. It's not as tight as a apartment complex either. The lots are a good size with the houses being pretty far from one another. But seeing this is bad news.
WEP is not secure. You could break 128-bit WEP in 3 minutes with publicly available tools - in 2005. At this point, WEP is about as secure as locking your screen door.
True, but anything is better then nothing and let's be honest would this rocket scientist of a woman be likely to crack any encryption method?
By the way, am I the only one confused by the boyfriend's comment? I mean what does it matter how the FBI got the pictures?
Around my house about 1/2 are WPA, 1/4 WEP, and !/4 unsecured. They can figure out how to change the default SSID from Linksys to xxHOTMAMAxx, but not how to turn on security.:rolleyes:
I hope the cops were able to go door to door and find that pedo!
nope, they could only find bears.
Jesus, do people ever click on the damn links? Yes, she was caught and charged with Child Molestation, Incest, and Sexual Battery....
I don't blame Mr. Davis for his ignorance. I think manufacturers like Linksys, Netgear, Belkin, etc. should take extra steps in initial web redirecting to the router config GUI with radio turned off by default. Then they go through the steps in configuring wireless security.
AND/OR
There should also be a disclaimer stating,
"I understand I do not want to secure my wireless connection and I accept the risk of an unsecured connection."
Check the box and then proceed to the next step to turning the radio on and done. That way it's none of this "I didn't know" bullshit.
With at least WPA2.
I don't know what the difference is. All I know is that either way, signing in requires a password. What is the difference between the two?
WEP authenticates in clear text. So you can do and SSID spoof run a packet capture and get the key.
WPA2 TKIP/AES uses encryption therefore you cannot see the key.
Thing is, WEP is good enough to keep losers like this off your network. WEP with access lists and broadcast turned off is going to keep most anyone off your network unless they're living right next door and happen to be the hacker type. I use WEP because some of my crappy wi-fi devices don't support WPA.
WPA (the first one) is a bit more secured. Atleast your key is encrypted. It's not as strong as WPA2. Also, a firmware update should open WPA. The chip for WEP can run WPA algorithms.
I'm perfectly fine with Mac address filtering. No need for WEP. Tired of entering in passwords all the time.
WEP's a joke, we all know.
What router manufactures should do is have the routers have WPA2 enabled by default (and the passkey is first 10 digits of the serial or factory MAC or something).
Have a pamphlet with the key printed on it again, and have instructions on the back to change it or change the encryption methods.
Easy imo.
Sad sad uneducated people.
First off its MAC, not Mac.
Second MAC filtering is a joke.
1) It encrypts NOTHING. All data is in the open.
2) Its hella easy to see what allowed MAC addresses are by sniffing then spoofing them. As easy, if not easier than cracking WEP.
So the real lesson is here are cops are stupid, kick in an innocents person's house looking for the wrong person. They couldn't knock on the door? I feel like that guys thats rights were violated. I also think no knock warrants should be illegal except for matters of life and death.
Every single wireless connection that is available to me (10+) is secured. I think the manufacturers are doing a good job pressing the need for safety and security, as well as people being more tech savvy.
Sucks these people didn't get the memo though.
Yep, and in this case they blamed the fuckup on the victim. as far as no knock warrants they have there purposes where firearms could be involved, but as with most power its abused whenever possible.(kicking down an innocent families door, shooting the family pet, etc)
+1 Just as bad as running it with no encryption.
Damn i must be the only geek who doesn't know how to crack WEP
No, there's one more...
:rolleyes:
AND/OR
Good idea. Except for the disclaimer.......I betting a lot of people will blow right by it without even reading it.
Overall things are getting better, but it's taken too long for the populous to get on the bandwagon.
So I shouldnt be running wep? I should change to wpa2? Im running a windows 7 machine and my wii off wireless with my main rig right into the router.
Reason I put it there is a CYA clause incase if the router gets compromised they can't point the finger at the manufacturer and sue.
This. MAC filtering is the biggest waste of time there is. They are transferred in plain text even if you do have WEP or WPA or WPA2 on. To run it on an open network is no security at all. :eek:
WEP authenticates in clear text. So you can do an SSID spoof run a packet capture and get the key.
There was a typo in that...
AND/OR
They DO tell people to enable security. Its part of the install process with the software that ships with routers these days. Well at least Cisco does with their Linksys stuff. Problem is, people completely ignore it and skip on past that step like morons. Well that and the so called "people who know stuff about computers" skip it when setting them up for people.
exactly on the pinpoint.
