Another Reason To Secure Your Wireless Connection
I live in an area heavy with tech workers. Almost all APs are locked down. Except for my neighbor who should know better.
right, i understand that, but if they integrated it into their firmware then there's no BS CD. Thus saving money and better advertising on more "secured" devices on the market.
People who "know about computers" would still turn it off. Plus they need the CDs. Do you really think 99% of the people who purchase routers would want to log into them via an IP address? The CDs make it simple and easy to set up a network. Also the Wizard software on the discs tend to be better designed and laid out than the usually utterly terrible web-based utilities. The only way to make it work is to force people to put security on the routers before WiFi is enabled, but there might be backlash on that for some stupid reason or another.
Plus: Router firmware already sucks ass, we really don't need these companies monkeying with it more than they already do.
it would be an HTTP:// auto redirect on initial startup...
You can't miss it unless you check a box that would literally say, "I do not want to secure my router... let me through."
Which a lot of people would still select.
You're missing the point... By making it as a #1 goal for security, by selecting "I don't want security," they have made that choice rather than "not knowing" about it.
How does that help the situation of most routers out there being unsecured though? Or the number of people who supposedly know about computers telling people that they don't need security on their routers. The only way to make security work is to force it.
My belief is, if it YOUR network/system then you administrate it the way you want; make it your rules. If you choose not to secure it or take shortcuts, you accept the reprocussions of failure. In this case, cops come busting your door down because they thought you were a pedophile.
If you consult somebody and say "Hey, You really need to secure this..." and they choose not to and insist on an unsecured network, that is their call. Just be prepared to have a document stating, Joe Smith declines the configuration of this device for security and have joe sign it. Therefore, it's not your ass (or the maufacturer's fault) on the line.
I'm just trying to come up w/ solutions where it's "easier" on the everyday consumer. By having a HTTP redirect, you can't get by it w/o stating "yes, i want security" or "no, I don't want security" the company has made it clear and made the choice up to you and wiping the company's hands clean of the situation. There is nobody to blame except yourself if you chose not to secure your network.
As I said already: They tell you to enable security in the software that comes with routers. Your idea might work, but I wouldn't want to subject most people to the terrible web interfaces for consumer routers.
I think that's what I was trying to get at,
HTTP redirect to Router HTTP based GUI for a step-by-step startup wizard.
lol
That was I was thinking when I first read the article. I don't think kicking in the door and throwing people to the ground is the best way to handle things. I really like how all they have to do is go "oh sorry" and everything is ok.
So the real lesson is here are cops are stupid, kick in an innocents person's house looking for the wrong person. They couldn't knock on the door? I feel like that guys thats rights were violated. I also think no knock warrants should be illegal except for matters of life and death.
Still a good idea. Problem is, if it hasn't been seen and stolen yet, someone might be rolling it out already. I had that happen once with an awesome concept........I worked on it for a bit, and saw it show up on the market while I was still on paper. Oh well.
With at least WPA2.
I live in an apartment complex and at least 100% are secure but 1/2 of them are using WEP. :eek:
Just WPA is fine, hardly any dif between it and WPA2. Just make sure to use a strong key and not some four letter pet name.
Well, not the police's fault for busting down the wrong door. It was the "techie cop" giving the cops the bad intel. If there was one techie cop for every department, they really need to be sent to like some official boot-camp certification class.
WPA2 is better due to it not being widely cracked yet (or possibly even cracked at all, not sure if there was ever proof given that it was).
Around my house about 1/2 are WPA, 1/4 WEP, and !/4 unsecured. They can figure out how to change the default SSID from Linksys to xxHOTMAMAxx, but not how to turn on security.:rolleyes:
Some don't turn it on deliberately and are not that stupid.
WEP authenticates in clear text. So you can do and SSID spoof run a packet capture and get the key.
WPA2 TKIP/AES uses encryption therefore you cannot see the key.
There is also now WEP with encryption. I have a router provided by my ISP and it has WEP key encryption available but WPA uses stronger encryption I believe. It only has WPA though and no WPA2.
my entire neighborhood is secure
I know this because I went door to door and secured everyone :p
Says here WEP has encryption but not end to end encryption.
http://www.webopedia.com/TERM/W/WEP.html
WEP
Short for Wired Equivalent Privacy, a security protocol for wireless local area networks (WLANs) defined in the 802.11b standard. WEP is designed to provide the same level of security as that of a wired LAN. LANs are inherently more secure than WLANs because LANs are somewhat protected by the physicalities of their structure, having some or all part of the network inside a building that can be protected from unauthorized access. WLANs, which are over radio waves, do not have the same physical structure and therefore are more vulnerable to tampering. WEP aims to provide security by encrypting data over radio waves so that it is protected as it is transmitted from one end point to another. However, it has been found that WEP is not as secure as once believed. WEP is used at the two lowest layers of the OSI model - the data link and physical layers; it therefore does not offer end-to-end security.
http://www.wi-fiplanet.com/tutorials/article.php/1368661
What's wrong with WEP?
WEP has been part of the 802.11 standard since initial ratification in September 1999. At that time, the 802.11 committee was aware of some WEP limitations; however, WEP was the best choice to ensure efficient implementations worldwide. Nevertheless, WEP has undergone much scrutiny and criticism over the past couple years.
WEP is vulnerable because of relatively short IVs and keys that remain static. The issues with WEP don't really have much to do with the RC4 encryption algorithm. With only 24 bits, WEP eventually uses the same IV for different data packets. For a large busy network, this reoccurrence of IVs can happen within an hour or so. This results in the transmission of frames having keystreams that are too similar. If a hacker collects enough frames based on the same IV, the individual can determine the shared values among them, i.e., the keystream or the shared secret key. This of course leads to the hacker decrypting any of the 802.11 frames.
The static nature of the shared secret keys emphasizes this problem. 802.11 doesn't provide any functions that support the exchange of keys among stations. As a result, system administrators and users generally use the same keys for weeks, months, and even years. This gives mischievous culprits plenty of time to monitor and hack into WEP-enabled networks. Some vendors deploy dynamic key distribution solutions based on 802.1X, which definitely improves the security of wireless LANs. The problem, however, is that these types of mechanisms won't be part of the 802.11 standard until the end of 2002 at best.
I have Wi-Fi disabled on my router. I prefer using a wired connection for a variety of reasons, this being one of them.
Unless I want to buy a bunch of long Cat5 cables that isn't an option for me. My desktop is hooked up directly but my laptop and PS3 are connected wirelessly. Need to get an adapter for my 360 so that can be wireless too.
This. MAC filtering is the biggest waste of time there is. They are transferred in plain text even if you do have WEP or WPA or WPA2 on. To run it on an open network is no security at all. :eek:
MAC filtering has a purpose. For example, at my university we have two SSIDs. One is WPA encrypted and uses EAP-TLS smart certificates for authentication; the purpose of these features is to keep data secure. The other network, for devices that don't support EAP-TLS, is open, broadcast off, and MAC filtered; the purpose of these features is to prevent townspeople from thinking, "look! free Internets!" Yes, they could crack it if they wanted to, but that would require hacking, which gives people an idea that the network is not for public use (outside the university).
WPA uses TKIP, which is WEP with extra security patched on, which ultimately led to TKIP being crackable because you don't need to brute-force the passkey.
WPA2 introduced AES, which so far can only be brute-forced. That makes WPA2 uncrackable with proper password usage, because of the limited bandwidth of a wireless connection. An ATI 5970 can generate 100,000 passwords a second, but what good does that do you if the wireless connection can't come even close to transmitting that much data?
I'm sorry the innocent guy got his house raided and got slam to the ground. But nowadays with the economy being crap and ID theft on the rise, that alone should make everyone encrypt their wireless connection.
Hardwired is the way to go for me. No wireless devices means no network is even visible. You can't hack what you can't see.
i'm pretty secure through WPA2-PSK but dunno what the psk stands for
Only two wireless networks show up unsecured in my neighborhood. One is the public library and the other is a police officer who lives down the street. Go figure.
He's really farking lucky they didn't simply use the download log from his IP as proof of the pornography. Good thing his neighbor was in the porn images, otherwise he might be getting a trip from Tyrone conductor of the hershey express.
It wasn't bad intel. The intel showed that the internet connection at that location was responsible. They followed the white rabbit. They got the criminal. Good job.
WEP is not secure. You could break 128-bit WEP in 3 minutes with publicly available tools - in 2005. At this point, WEP is about as secure as locking your screen door.
More like just closing the door and not locking it. no security is on the other hand is an open door.
This is what i'm using on my Dlink DGL 4500.
Auto mode switches from WPA to WPA2 and TKIP and AES depending on the client that is connecting.
Uploaded with ImageShack.us
That's not true. WEP is encrypted, it's just a weak algorithm.
Because of the weak algorithm, it's possible to figure out the key by collecting enough packets to see the repeating data. Originally, WEP cracking took a while because you simply had to wait for enough traffic to collect enough repeating data. Other tricks were added later which caused the router to transmit a lot more data, so you'd gather enough data a lot more quickly. WEP can be cracked (including gathering data and actually cracking the encryption) in literally just a few minutes.
If you don't secure your wireless, it's the equivalent of mounting a network jack outside your house. If you're cool with that, fine. Most people probably wouldn't go for that, but that's exactly what you're doing if you're not securing your WiFi. The type of encryption you use is how strong the lockbox is over that external network jack. WEP is like tape and paper over it - someone has to make an effort to get through it, but it's not really secure at all. WPA2 is like a good steel box with a Master lock on it - it will actually take a decent bit of work to get into it.
I like how my wireless teacher describes it: WEP is like using a chain lock on a door. Easy to break open.
I find eight wifi spots in my apartment building secured, but over half of them carry default passwords. It's the thought that counts :3
