another GTX260 w/ 500W PS thread...
freakyhair
Hi All,
I just got a new GTX 260 (55nm), and I have an Antec Smart Power 500w (SP-500) PS
(12V1: 17A, 12V2: 19A). I ran the Antec PS calculator, and it said I need a 303W PS.
Other stuff:
Core2Duo 8400 stock speed
3 SATA drives
1 PCIE 1X raid card
1 DVD RW
2 x 1GB DDR2
The GTX260 says it needs two 18A Rails.
Am I too close to the edge? I don't want a flaky computer. I live in HI, so shipping sucks, and I'd probably get this PS if I need a new one (unless you all think that is a bad idea.): http://www.bestbuy.com/site/olspage.jsp?skuId=8990559&type=product&id=1218007088315
Thanks!
Although your current PSU is probably adequate, it isn't great. I would be more comfortable with a better one, although you should be okay. If you were to purchase a new PSU, I wouldn't recommend that Thermaltake for you since it's expensive and has significantly more power than you need.
I think you are cutting it a little close with the 500w PSU. The 850w Thermaltake is way too much for your needs.A good 650w PSU would suffice if you can find one. Are there no local PC shops that you could pick one up at other than Best Buy? What island you on? If you are on Oahu, there a few places. I remember there was one some where near the Ala Moana mall, not at it though.
My old Antec NeoHE 500W is still going strong. Rig in sig.
To OP: a quality 500W PSU is plenty for a single GTX 260. Although I only have a 1 Sata HDD & 1 Sata Burner right now.
Read my sig.
Also, hmz has a 500W Antec NEO(Triple 12V rails w/ about 50A or so I think). He has a GTX 260 and a few HDD's including a raptor. He notes no probs. :)
Stick to a quality 500-550W Antec/PC-P&C/OCZ, etc. PSU and you'll be fine.
I have an aux box that has a very OC-ed E2160 and a GTX 260.
It is also running a EA500. No problems yet.
I also have another rig running a 260 with a EA430.... that's pushing it I know.... but it's running fine.
(both boxen are folding 24/7 on the GPUs)
Edit, sorry didn't re-read my post, yes the psu are EA series.
I think I'll stick with what I have for now, and let you know if it blows up this weekend!
I am on Oahu, but I haven't seen any shops. There are a ton of little stores selling everything besides electronics, so I'm sure there's a place out there, I just need to look harder.
Just a FYI: The Smartpower line of PSUs are well known for their above average failure rates due to a poor combination of caps choice and cooling design.
Now a good quality 500W PSU would be enough but that Smartpower is NOT a good quality PSU IMO. With a system like yours, I would not be that comfortable using that PSU with that system. See if your Best Buy store has the Antec Earthwatts 500W PSU in stock. Thats enough power for your current system + GTX260 since it has 35A on the +12V rail. Considering that the Corsair PSU finder recommended the Corsair 450VX with its 33A on the +12V rail, that Antec Earthwatts 500W PSU is a good choice.
@ Slyr7.62
The Antec NeoHe 500W only has 38A on the +12V rail. You don't add up the rails to get the total amperage on the +12V rails. You determine the amperage on the +12V rails by first finding out what's the total combined, max load, combined or max wattage aside for the +12V rails/section alone. Then divide that total by 12 and you get how much amps the PSU has on the +12V rail.
In this case, the NeoHe has 456W available on the +12V rail and therefore 38A on the +12V rail which is pretty good for a 500W PSU.
@ Kendrak
Did you mean EA500 and EA430?
@ Slyr7.62
I overshot the Amps in my guess, still plenty for the target system though.
@ Kendrak
I'm sure that's what Kendrak meant, because I have a couple 500W earthwatt PSU's, model is EA.
freakyhair, hopefully when a PSU goes bad it doesnt take anything else w/ it. :eek:
If your 300w calculation is correct your only going to be putting a 60% load on the PSU, I know the cheapest ones usually go up to about 75% load sustained before you run into issues, You should be fine
Thanks for the info. I forgot to mention that I need to to be modular, as I have a pretty tight Microfly case. Really, the newegg option is not out of the question, I guess. BBY has very bloated prices, and I can wait a couple days.
Just don't know if I want to spend more money if I don't have to :confused:
I know...and I hate debugging problems I know I could have avoided, which is why I started this thread...
I'm not sure that Thermaltake would fit in a SFF system. The Thermaltake 750W I had was huge. I would definitely double check the dimensions before buying it.
Does anyone have experience with a 260 gtx core 216 with an Enermax Liberty 500w (12v at 32A)?
I'm running an e6600 @ 3.4 ghz, 1 optical drive, 1 sata drive.
I read that the 36 A min requirement for the 260 overestimates a lot, is this true?
Thanks
Sort of true. A rig with a decent dual-core CPU and a GTX260 really should have at least 25A on the +12V rails, although more is always better and can help the PSU run more efficiently.
