fightingfi
- Oct 9, 2008
Zen 2 isn't until 2019Hope Zen 2 has like 30% more ooomph per clock than current per single core.
Oops I got the two mixed up
Pity the post has got the name wrong, pinnacle is not going to be the brand name for the chips - not after all the money they have just sunk into the Ryzen brand
the writer was referring to the idiots at digitimes trying to call them pinnacle 7 when anyone with half a brain knows they'll be ryzen 3/5/7 2x00.
yay unprovable random image...
http://www.trustedreviews.com/reviews/amd-ryzen-3
571cb @4.1GHz. So 557cb @4.0GHz. The above "random image" is in the expected range (+- 4%). In the other hand, those leaked 885cb @4GHz are fake. Aren't it?
LP (Leading Performance), I would think we will be looking at higher power and somewhat faster chips here in clock speed. Mainly a clock speed bump with a little fine tuning at best. How fast can AMD push Ryzen on the clocks?A node shrink doesn't change the IPC. Moreover, 12LP is not a node shrink, but a marketing shrink.
https://www.globalfoundries.com/new...-technology-for-high-performance-applications
Are we looking at 4ghz with max turbo speed of 4.3ghz? Max OC around 4.5ghz+?
I would like to see a more Intel like flexibility in adjusting individual cores max turbo speed where you can max out the faster cores at higher speeds.
isn't intel getting rid of that option though with their newer processors?
Well, at least Ryzen owners won't have to buy another Motherboard (AFAIK)
http://www.guru3d.com/news-story/amd-preps-agesa-1-7-firmware-to-support-raven-ridge-apus.html
It mentions Pinnacle Ridge as well for the bios update reasons.
