M4000? Shouldn't that be a P4000?Soo... Threadripper, Quadro M4000 64gb DDR4. My build is starting to come together...
AFAIK the current licensing shouldIs Windows gonna play nice with 16 cores as far as licensing goes? Or are they going to start charging extra since this is encroaching on server monies?
Interesting. What do you require ECC RAM and extremely high performing math libraries for? Are you in academia or a business user doing HPC?As someone who might be in the target consumer pool for this cpu, I'll need to see ECC RAM compatibility tests before handing any money over.
I also feel that Intel's math kernel is less easy to give up on than Intel's CPUs...So AMD's support of MKL (or it's own alternative's capability) will be critical.
2.5 billion pounds of shit is generated every day.
...I have a problem. I'd join a support group or something to stop upgrading things I don't need, but I don't want to.
yes and no. I have a 970 right now and when I use it for rendering I often get artifacting and crashing. I have become absolutely paranoid of losing my work from it.
M4000? Shouldn't that be a P4000?![]()
Right but for the wrong reason, which could lead to incorrect subject-verb agreement in the future.This is incorrect. (not "This are incorrect.")
Data is the plural of datum. Use "is" with singular subjects, and "are" with plural ones. But things can be tricky; in the case of this very sentence, I use "is" with the subject "data," as I am referring to this word as a singular term (the one plural form of "datum") rather than data itself.
Mr34727 is correct. The sentence should read, "2.5 quintillion bytes of data are generated every day," as data is plural.
Academia, computational simulations and such.Interesting. What do you require ECC RAM and extremely high performing math libraries for? Are you in academia or a business user doing HPC?
Well, since Minecrap is single threaded.....I just wonder if it can do minecraft.
I won't characterize MKL as "extremely" high performance but it's a big step up over many solutions, the most attractive feature being effective, low-level parallel processing for basic math functions. Building CRAN R with MKL for example, gets you near linear gains for up to ~20 threads on some functions.
I'm actually really interested in this depending on how IPC performance ends up vs Intel and how Intel responds. 64 PCI-E lanes means I can run 2x graphics cards at full speed plus a multitude of PCI-E SSDs. Hnnng.
I would like to see proof that standard DDR4 made in 2017 is more susceptible to any errors in memory or failure compared to ECC in your application. I'm not saying it isn't, I just can't find the data. Everything I find is from very early on, but also showing lower errors year after year up to DDR3. Showing that there was only a .02% difference in failure rates (Not necessarily errors)
Now just put this in a laptop and I'm golden!
AMD will under cut them core for core I bet. I can see their 16 core being priced cheaper then Intel's 12 but I'm still predicting $1200 price tag on their 16 core.Cost is going to be a bitch, but I'd love for them to undercut Intel's latest i9. I think it'd be a kick ass CPU, even with the lower clock speed. May not perform as good as Intel with single core performance, but it still kicks some ass.
16 cores, 32 threads is interesting, but can it run Crysis?
The subject is not data, it's "bytes". The words "of data" are a prepositional phrase used as an adjective to modify bytes. E.g. you could substitute data with a singular word and the sentence wouldn't change, e.g. "2.5 quintillion bytes of pornography are generated every day".
I'm running Win7 Ultimate with dual X5690s now (12c/24t).Is Windows gonna play nice with 16 cores as far as licensing goes? Or are they going to start charging extra since this is encroaching on server monies?
New chips require new Windows 10 which is what I'm curious about.I'm running Win7 Ultimate with dual X5690s now (12c/24t).
Instances! It's all about how many instances you can run!
Hmm... Minecraft VDI Server... I have four kids, they all like an occasional MC play... I should really think about this...
Well, with this chip you'll have enough overhead for eleven more kids![]()
There's nothing required about it. I'm running Win7 on Skylake and Ryzen rigsNew chips require new Windows 10 which is what I'm curious about.
