- May 4, 2006
Update, still stable with the exception of one issue.
Either memory stick in slot 1B will not work when doing a system reboot. A shut down and start up works every time. This was not an issue with the Corsairs and for giggles I swapped them back in and instant errors in OCCT within 7 seconds with no other changes at 6200.
I also noticed another bug with this board, doing a CMOS reset will cause voltages and fans speeds to show incorrectly in HW Monitor section of the bios as well as making the fans run at minimum speeds until the PC is unplugged and plugged back in.
So looks like ill need to get new AMD cert ram, ill see what Micro Center has to go pick up that is also on the QVL list.
EDIT: Might be a winner here: https://www.microcenter.com/product...top-memory-kit-f5-6000j3040g32gx2-tz5nr-black
