AMD Ryzen 9 9950X3D Performance, Overclocking and Cooling Thread
The iGPU in regular Zen 4/5 CPUs is not powerful enough to be used as a 2nd GPU for framegen output.
I'm pretty sure the only iGPUs powerful enough for that on Desktop, would be what's in Arrowlake.
I can confirm that Lossless Scaling runs like garbage on stronger iGPUs like the 5700G. I tried this setup on my itx 5700G running framegen on the iGPU (and display plugged into it) and rendering on a 4060Ti. It was a stuttering mess, even with flowscale turned way down. It is a significantly better experience just running the game natively. I tested RDR2 at 4k which the 4060ti is able to run at 50fps on 'medium'. I ended up just turning the iGPU off.
I did go ahead and turn it off. I was curioius about use cases.
I have heard of this on laptops where to save battery, it can use the iGPU most times, and the GPU when required. Didnt know what a desktop use case would be. More monitors maybe?
Yeah that'll work, but Displayport MST hubs will also allow more monitors too. I have 3 dell monitors for work that have an MST hub built in so you can daisy chain monitors. It tops out at 2 running 1440p 60hz but I'm sure the more recent standards could do better since they support much higher bandwidth (probably) but good luck finding them.
I have a x870e tomahawk It actually just goes to 2x on usb4 and nvme if you ues nvme2 but you can force 4x on the nvme. It's definitely better then x8 on the GPU as how many people ues usb4? So on the MSI you can run 2 gen 5x4 and 2 gen 4x4. Sounds a lot more useful then having a 40g USB port for my phone
the 40g usb is nice for external pcie ssds and direct attached storage boxes.
I wonder if your mb has something wrong with it? Maybe a slightly bent pin that doesn't make good contact? seems suspect to get two bad chips. Did you get them from Amazon by chance? I had two swapped for old CPUs and one obviously returned CPU with bent pins form them over the years.
I used to have problems like this now I order crap from b&h even though they don't ship on jewish holidays. Their customer support is better too and when it's not a jewish holiday and I order before 1 or 2 in the afternoon here in AR it comes in 2 days.
I'm starting to have serious doubts about Buildzoid's 'guaranteed' manual timings. Also, protect your DDR5 modules people, defnitely can't afford to cook them right now.
So anyway, I tried Buildzoid's recommended timings for the 96GB kit I have and it seemed to be fine for quite a while. I can't remember what stability testing I did, but my system just didn't 'feel' right, so I ran an hour OCCT ram test on my system and it failed. I eventually dropped my ram down to 5800MT and it would pass an hour of OCCT. OK fine. I also purchased a Jonsbo ram fan and put it on there for a good 20C drop in ram temps, and bumped all my system fans up a bit to better manage temps.
Cut to yesterday, and I just had a niggling feeling about Buildzoid's timings, so I went back into BIOS and changed everything back to auto and reloaded the EXPO profile, set the recommended RAM voltage and set it back to 6000MT and OCCT passed without any issues. Well shit.
I also have another system I built with 32GB DDR5 and the 7800X3D. I set up this new system with the exact same Buildzoid timings I was using with this same CPU and RAM kit on my current motherboard (which seemingly worked fine, but with system hitching and generally shitty multitasking, especially when playing back multiple videos on multiple monitors, e.g. youtube on one screen, and 9 security cam streams on another screen), and the new build will just power off when I'm not looking. I'm about to do the same thing to see if it's a ram issue. So anyway, be wary of Buildzoid's timing suggestions and keep an eye on those RAM temps, appartently DDR5 is much more sensitive to temps than DDR4.
So, I haven't been using the 'EXPO only' settings for very long, but my system feels way more responsive now. I'm thinking that maybe Buildzoid is overlooking some DDR5 delayed tRFC refresh voodoo that his settings are breaking which results in frequent lockout stalls.
I don't think refresh intervals should be fixed values, you can see this if you set your refresh interval to auto, then check the actual refresh interval after rebooting. I noticed that both systems report a different refresh intyerval than the reported EXPO setting.
My hypothesis is that refresh interval and tRFC changes on the fly depending on how busy the system is. By setting them manually you are introducing something different from the 'expected behaviour', i.e. the CPU is expecting delayed refreshes because "I'm doing something urgent, just wait a few cycles" and the RAM's response is "No, refresh happens now becuase the user said so".
View: https://youtu.be/KKbgulTp3FE
Any chance you're running a newer BIOS where the extra tRFC settings now have an effect (vs setting them to whatever number and it didn't matter in old Buildzoid videos)?
It's why I've yet to update to the latest as I'd have to figure out stability again - and I bet if you used BIOS flashback to the version before they were added in, you'd be fine.
I'm still on bios version F33 which is just over a year old (March 2025). I haven't updated in a while for the same reason.
Hmm, then the only thing that I can think of is you lost the lottery with your RAM. Other than that, there were supposedly differences between the nand dies, and maybe you've got a different type (samsung vs hynix a/m, etc.) that doesn't work well with those particular settings.
Not that it means much, but I got Buildzoid's any 7000 series CPU hynix settings working on both of my RAM kits - the G.Skill 96GB kit for years now, and the Patriot Viper 64GB kit since around August.
I don't know. My original build with the 7800X3D and 32GB A die 'worked'. It passed every stress test I threw at it, but the system just felt like garbage in terms of responsiveness. I upgraded from X99 with an i7-5960X, 1080Ti and 64GB ram and the initial build felt like a whole different world of performance. I then started tweaking with Buildzoid's settings and benchmarking, and saw real results in gaming performance and synthetic benchmarks, but the whole time in general usage it just felt off. I figured I needed more cores and RAM so got the 9950X3D when it came out and 96GB of ram (although it was always my plan to get these upgrades) and yeah, it was a noticable upgrade, but during certain use-cases it just ran like shit. Especially in the last month or so, I've been having mouse hitches. Loading up EXPO and it feels 'normal' now, maybe it's placebo.
Oh, and loading EXPO on the other system has resolved the random power-offs.
