- May 18, 1997
Kyle, please tell us what you meant. I have some purchasing decisions to make that hinge on how this is gonna flush out
What exactly is the question you want answered?
Posted via [H] Mobile Device
How Ati plans on making eyefinity work with 3x DVI monitors
Exactly that is a huge deal for most of us here, that want to use Eyefinity. I am pretty upset after buying my 5870, knowing now, that I MUST have one monitor with Display Port
I currently have my Apple 30" Display with just DVI-D connection, was planning on adding two Dell 2007FP of 1600x1200res monitors but flipped up in Portrait mode so that all three Displays would then have a vertical res of 1600. But none of these monitors have Display Port, so I cant do that now ?
http://hardforum.com/showpost.php?p=1034668445&postcount=410Also, it is my understanding that in the near future you will NOT need an active adapter to output through DP to DVI or HDMI.
I think all three monitors have to be the same configuration and resolution, so you may have screwed yourself twice.
No ? I think the most important thing is all three monitors having the same height or vertical resolution. So my 30" in landscape mode and the two 20" in Portrait mode would all be 1600res in height. As far as I know that would work no problem ? I know the free software program SoftTH has allowed that to work, I never tried it, but have seen it online working, so don't see why Eyefinity couldn't do it better ?
If that doesn't work then I totally had wrong idea and sucks. Then I would need to go out and buy all new monitors which I didn't plan too. Guess I won't be doing Eyefinity like I thought if the above is not possible ?
This combination works according to what I've read. The grouping of monitors needs a final resolution, in your case it would be 4960x1600. You'll need to change the rotation in CCC and then I think it would be ok to group them.
So if you do NOT have a Display Port monitor, but want to run triple screens for gaming Eyefinity style with the new Radeon HD 5870, you MUST have one of these ?
http://accessories.us.dell.com/sna/...x?c=us&l=en&s=dhs&cs=19&sku=330-5521#Overview
Per this forum post;
http://www.widescreengamingforum.com/forum/viewtopic.php?t=16792&postdays=0&postorder=asc&start=225
But I can't say 100% if this really does work, will have to watch those widescreengaming forums this week, few of the guys bought the Dell adapter, so we will know whether or not if it does indeed work ?
geniv2
Posted: Sat Sep 26, 2009 1:07 am
WTFudge..
I hooked up the 3 monitors
DVI -> BenQ moniotr
DVI -> BenQ monitor
DP -> Dell 2408FWP (with a DP cable)
I can only use 2 screen at a time like previously ?!
btw: I got the Asus 5870 card. (but just using the standard CAtalyst control pannel)
XP isn't supported. Someone else even states that like 10 posts down.Somone on another forum reported that they couldn't get Eyefinity to work even though they had a native displayport Dell 2408WFP in the setup. Hmmm? We need answers. [H]ard answers. What's the deal with Eyefinity, ATI?
http://www.widescreengamingforum.co...tart=240&sid=72fefa79dbda8230075687af1d5fbdd4
XP isn't supported. Someone else even states that like 10 posts down.![]()
Ok looks like the problem was the OS. Why is ATI not supporting XP for Eyefinity? Basically anyone running XP won't be able to benefit from a 5000 series card?
Nope, absolutely no benefit at all in any way shape or form using a 5xxx card.
Sorry I am late to the game but can someone confirm if the new Efefinity can support the 3007WFP and 2 X 2007WFP side panels in portrait? I don'e see this configuration in the specs... Everything talks about symmetrical combination but I don't think this qualifies any input appreciated...
Kyle or Brent, on the 5870's that will have 6 dp's, will you be able to use a passive adapter to dvi as I can see a lot of cables running everywhere if not.
Dave Baumann (head of ATi 4000 and 5000 series) stated on WSGF that every card will only have 2 DP+ ports (2 clocks capable of passive legacy adaptors). So 2 with passive and 4 with active adaptors if you want 6 DVI/HDMI.
The cards have timing sources for only 2 displays, so if you want a 3rd (or more, for the six port) display you need either a DP input on the monitor OR an active adaptor for every display beyond 2.While there are Six TMDS/DP transmitters, there are only 2 clock sources on the ASIC. The issue with legacy display is that they all need their own clock generator - as soon as you plug in two DVI/VGA/HDMI you run out of clock sources. DP can time multiple outputs from a single clock generator.
What we do with these boards is add an additional clock source externally from the ASIC that is good for driving DP timing, but unfotunatly not others (the clock source is actually shared for another use, so we can't just arbitarily have any timing).
If you plug in a passive adapter to the DVI+DVI+HDMI+DP design then you it will use an internal clock source, up until you start plugging in other panels......
Including the 6 mini-DP port beast that is yet to be released.
Quote:
What if someone wanted to drive 6 DVI/HDMI panels from the card, 6 active adaptors? Each with their own power supply???
As already posted, 2 can be passive in this scenario.
old OS, Microshop stop giving support, did I say old?
If your writing drivers, you sometimes need to draw a line.
windows xp is a dying OS.
It also dosnt have as good vddm for 3D.
XP is still the most popular OS for gamers. Latest Steam survey shows 52% of gamers are using Windows XP 32 bit.
