Amazon Has Sights Set on Double-Sided Tablet Device
CommanderFrank
Cat Can't Scratch It
Amazon has received a patent on a two-sided tablet joining e-ink and LCD display on opposite sides. Each side of the tablet would have touch sensitivity and front and rear facing cameras to determine screen identification. The device could be used with both screens in unison to make it easier to view certain aspects of a single item, such as web page.
The patent approval comes just days before the company is planning a press event in Los Angeles on Sept. 6, where the company is likely gearing up to launch its next-generation Kindle e-reader and Kindle Fire tablet devices.
I'm actually liking this idea.
eInk is by far the better technology to read on in well lit environments.
LCD is better for graphics, video and when it is dark.
Depending on execution, this could be a really cool device.
This would be very strange, but quite useful. I'm wondering if it would use sensors to determine which side is up (the side you're using) to enable touch for that side.
I'd be okay with Android running only on an e-ink touchscreen and no color LCD at all.
Now I have to buy double the screen protectors. I can also see the case market being unhappy with this, since a lot of people put their tablets in booklet- or envelope-like cases, completely obscuring one side. Putting it on a "hinge" and having both front and back panel articulated increases complexity and thickness of a case quite a lot.
I like the idea, but I feel like my "back" screen (the one I used the least) would get a lot more wear from being set on surfaces or constantly in the back part of a case.
Book. LCD on one side. eInk on the other. Fold to close. Open to read. Fold all the way open to use as tablet. Just making a slab with different displays on each side won't quite work as there will always be issues with light or gyro sensing to determine which way is 'up'... handing a surface that is meant to always sense input when looking at the other side will also have its own share of usability issues and I think a lot of people would enjoy being able to hold an eBook as an actual book instead of just a slab they hold with one hand. (Users of larger eReaders have complained about single hand fatigue.)
So root a nook simple touch.
That's a really good idea. Is there a more modern ROM for it? I think it shipped with something like 2.1 and a quick search doesn't turn up much in the way of custom ROMs like CM being availble.
QFT. I picked up a new one for 79.99 a few weeks back. Can likely get refurb/used cheaper.
That's not too bad. My e-ink Kindle was about $120 including shipping, but I paid extra $$ for the version that doesn't dump ads to the screen when you turn it off. Looking back, I'm not sure it was really worth it to spend the additional monies.
I've considered getting a lightly used Kindle fire on craigslist and rooting it with Jelly Bean.
While I like the eInk screens, I'm not sure I could use it for more than just book-style reading.
I think having the e-ink on the back is stupid. A book is better. e-ink on one side, color on the other. The e-ink side can also double as a keyboard for the color screen, or just be additional screen space. Or, of course, used alone for long battery life and bright-sun reading.
I've thought about this before for cell phones where messaging is more common via text, e-mail, IM, etc. Makes less sense on a tablet in my opinion.
This comes to mind:
http://en.wikipedia.org/wiki/EnTourage_eDGe
well, their pattern says opposite sides, so one will be in front and another one in the back.
but we will need some solid build in cover for it, so it's easier to slide it sideways and flip it to get to other side while keeping the bottom side safe from those touch interfaces (if both are active all the time/we configure it that way) so we don't mess up what we are working on.
I carry the nook e-ink and a refurbished Kindle Fire.
If the coble sider has a micro card slot might be worth while.
It might be like the vita, with the touch device on the back. Would solve the annoying issue with tablets where you have your hands covering your vision all the time (and fingerprints).
I'm thinking from a rooting and custom image perspective...
...how well does Android deal with multiple screens out of the box?
Why? Regular hardcover books are protected front and back too. Just make the hardcover for the Kindle Fire 2 and you're set.
Book is better, you can see both, you can hold it without inadvertently creating an input on the back face, and when you fold it together you protect the screens from being scratched.
Stupid design is stupid.
I don't think gyro sensing for "up" would be a good idea - imagine reading in bed with your pillow under your head and you holding your "book" above your face - which side would be "up" then?
My arms would get tired doing that.
