Hey folks, long time lurker, first time poster!
1) What will you be doing with this PC?
Gaming, 3D Applications (Max/Maya, Zbrush, UE3), Photoshop
2) What's your budget?
$295 shipped
3) Where do you live?
Seattle
4) What exact parts do you need for that budget?
GPU (most important), HDD possible, HSF (using stock atm)
5) If reusing any parts, what parts will you be reusing?
Core I5 - 750, Gigabyte P55-UD3R, Seagate 250gb, 8GB DDR3 1333, Lian Li HPC 500W PSU, Antec 900
6) Will you be overclocking?
Yes, currently at 3.3ghz (65C at load or so)
Gateway 21 (1680x1050) + Samsung 204B (1600x1200)
Anytime but don't mind waiting a couple of weeks or so
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
N/A
10) Do you already have a legit and reusable/transferable OS key/license?
Yes, Vista 64 (open to Windows 7 upgrade)
For the past couple of months, I've been slowly upgrading my computer. It started with one of those awesome Core I5 sales at Frys and has been a work in progress ever since.
I definitely need a new GPU since I am using an 8800GTS 640mb currently. I am looking at 5770s or, if my patience holds up, at the 5830s when they are released. I would like to stick to $150-170 for the GPU and put the rest of the money into HSF, HDD, or wherever. However, if the 5830 is the right price/performance, I may go for that. I am not in the market for a monitor upgrade, however, I will also consider it if the price is right WITH a new GPU.
Thanks for all the help folks! HardOCP has been a great resource for me for many years.
$295 shipped
Seattle
N/A
