isn't this one of three wide-gamut monitors with A-TW and the only one without nasty dithering?
probably U think NEC 2490WUXi is the best but it's just sRGB and have worse contrast ratio so can't really be "the best"
it's worse:
- it have much worse contrast ratio = washedout image at night
- panel without A-TW = IPS glow attacking from every side
- also have annoying green-flickering
- even sRGB mode is worse (more deltaE on colors)
- have "slight operating noise" even when there is usb key in usb port...
LG had only "good" rating because bundled calibrator that is useless for that screen. But what's the problem to buy good calibrator for price difference?
This EIZO is feature-wise on level of NEC PA241W but much more expensive...
Pardon my offtopic in this thread but... you have to take prad "rating" with a grain of salt. You'd better try to take something rational from their reviews than to quote their "ratings" blindly.
Than you need to understand that LG does not produce good monitors.
I wouldn't compare it with the NEC 2490WUXi - different leagues.
If these quite obvious things are not obvious for you - go ahead and buy it.
It will be funny.
