forget my room...the entire country is hot as summer has arrived....34C in summer in india is low given in two weeks the temps will be in higher 30's and next month in the lower 40's till june.even the freakin night time will be hot in lower 30~32 with occasional 26~29
on stock cooling my e4400 idles at 43C....i wanted the TRUE to get the load temps from the 60's to 50's...if that happens i'll be happy.guys doing stable high OC elsewhere should try out in India
.... ur ambient temps would be in 20's which is another 4 to 5 months away.
i think i should migrate ASAP
Your room is just too freaking hot. I wouldn't expect to even idle much below 50C regardless of cooling, save below-ambient solutions (TECs, chilled water, phase).
