At your res it may be fine, but the 8800 GTS 320 is the weakest of the older G80 based cards. It's weaker than the 8800 GT and 9600 GT... but considering what you'd be paying for an 8800 GT ($200 card new, here) and potential budget problems, you might want to go with it. It's not a /bad/ card.
well budget is not a problem anymore ...my CC just got processed and i'll put the purchase on an EMI what ever the amount be....in that case what would be your suggestion?
8800 GT for longevity's sake, and the MSI card for better cooling.
If the warranty is the same just get the less expensive one. Clock speeds aren't worth paying for -- you can always OC yourself.
@kllrnohj
you said something about drivers for the creative 5.1 for Vista at the start of this thread..where to get them?
Check your PM![]()
another friend of mine is now offering his XFX 8800GT 320MB for 186USD....but not sure of buying ....its now two such cards offered to me now...is there a problem with this card?
The problem is that there is no such thing as an 8800GT 320mbI'm guessing you meant GTS 320mb - in which case the card is slower than the 9600GT or 8800GT, and the 320mb of VRAM quickly becomes a limitation. Skip it.
the 8800GS has arrived in India from XFX...
the XFX GF 8800GS (T88S384DF4 - Alpha Dog) edition with 384MB is priced at 44USD lesser than a 512MB 8800GT....
are the 8800GS any good?
The GS is a far inferior card to the GT, especially looking at longevity (the GT has a lot more SPs). I you can swing the extra $44, do so.
i most certainly can....i'm short of dough for the corsair PSU so waiting for my CC so i can order the card next week and also the 9800 series will be out by then right?
i have around 3~4 PSU's lying around but none of them have a good +12V rating...the max is 20A ...maybe i'll keep the case open and connect the spare PSU to the GPU so the GPU can have a full 400W to itself..it will save me the trouble of getting a new PSU but its not the most logical of solutions is it?
The 8800 GT is faster, but not a ton more. Look at some benchmarks and decide for yourself.
ahh i get it...since all the parts involved will be under warranty,i can go ahead with that i think...the DUAL PSU case has cables to connect the 2 PSU internally...It... /should/ be ok. Not the same as "will", but should.
i had planned to get GPU,PSU like u suggested ..then found out that my then cabinet was too small for the GPU so added that to the list...the mobo was the only unplanned buy....next looking to get a TRUE cooler for OC'ing my CPU....now i use Nvidia control panel to control the fan speed...i set it to direct control...but after the restart the fan is under auto control...what am i doing wrong?
also my 3dmarks06 score went from a previous 513 to 9356...not bad right?
TRUE=thermalright ultra extreme?
or
true=good
