What's with the Jan 11 availability? Wonder how inflated that price is, since it is pre-release.
That's probably the MSRP.. lines up based on pricing OCUK gave out earlier.
They can increase the 5870's transistor count by 50% and just reach the size of the 580.
And on that front Nvidia doesn't have anywhere near 50% more memory bandwidth, more like 25% more than the 5870, a gap the 6970 could definitely close.
It confirms what most of us instantly knew since the delay. The 6970 is slightly slower than the 580. If it is within 5% though, $440.00 is a very attractive price.
Except just about everyone knew they wouldn't and they didn't.
Not unless somehow only AMD can run the memory speed 50% faster. But again this isn't happening and NVidia will keep memory bandwidth advantage.
Every single shred of evidence right from the beginning, pointed out that the 580 would be faster than the 6970, and was obvious if people used logic instead of wishful thinking.
But many people didn't want to believe that so we get a lot of rationalizing why the 6970 will somehow defy logic.
There hasn't been jack shit in the way of evidence one way or the other. EVERYTHING is basically wishful thinking at this point. You wishfully think it will be slower, I wishfully think it will be faster.
So you are pretending all the leaks are just made up? I would call that denial.
Then one of you ends up being right, then you nag on the other one for being wrong and not believing you.There are leaks that support both of our statements. The question is which is true. You clearly believe the leaks that support you, and I believe the ones that support me. Until the cards come out, this is all pure speculation.
(this is all pure speculation.)
Yep.. I havn't seen one leak using Cat 10.12
All the leaks that look like official ATI slide deck, support it being a fair bit slower than 580.
All the leaks show it being 256 bus, Nearly same Z-Stencil/Rops as Cypress. None of this indicates a big boost.
That looks like a Vapor Chamber to me...
With the help of the latest build of GPU-Z, the site has revealed that the HD 6970's core will have 1,536 shaders clocked at 880MHz compared to the HD 5870's 1,600 clocked at 850MHz. The 2GB frame buffer will be clocked at 5,500MHz and connected via a 256-bit bus, giving it plenty of bandwidth.
So are these suckers getting released in NA today? Or are we still up in the air about that one too? I've heard everything from 13th to 15th to 13th in NA and 15th in EU.
Wrong, ROPS got doubled up on performance internally. Same count, but twice the power.
ZerazaX said:And the leaks also say 15% faster than the GTX 480 for the 6970 - so that's a "fair bit" slower than the 580?
If these slides are real, it's a big LOL:
That has to be fake, no way they would compare a brand new next generation VideoCard to something like 2 generations ago.
That would be like GM saying, hey look at our brand new 2013 C7 Corvette, it beats the fuck out of the 1985 Ford Mustang![]()
And where are the tests that show that ?
The leaks that say "15% faster" come from supposed AMD marketing slides, which usually have best case scenarios. The actual leaked performance numbers, put it roughly in the GTX 480/GTX 570 territory.
I am seeing far better results than this Powercolor card!
I really hope so.That looks like a Vapor Chamber to me...
