Hi,
I am having sluggish performace in Adobe Lightroom 3. When I am exporting or rendering previews, the computer will lag very badly (2-3 second hangs) if I surf while it renders. It also lags pertty hard with the "loading" message every 10-15 photos when I am sorting even though I have standard size previews built at 25x16. I am working with 21Mpx RAW files from a 5D Mark II and am using the machine in my sig. I run the OS and LR cache on my SSD (which I keep less than 80% full by deleting the cache often). The photos live on my 640GB WD (which is half empty). You can see my CPU spikes to 100 quite often during render.
DO I need to upgrade something?
Ram?
SSD?
2nd SSD?
Disk Array?
Hexacore?
Ram?
SSD?
2nd SSD?
Disk Array?
Hexacore?
