Adapting notebook DVD on desktop
carlmart
Is there any hardware that I can use to adapt a notebook DVD player on a desktop?
Are you trying to use this in a mini or something like that otherwise wouldn't it be cheaper to just buy a $20 dvd burner. Although it would be cost effective if the notebook supported BD.
You may find me stupid or foolish, but I would like to install a DVD unit that lasts longer.
As they are they seem a disposable item, lasting a year at most.
I think units inside laptops last a lot more. Am I wrong?
I usually get around 3 to 5 years from my DVD burners. Even ones that I do 200 burns per year.
I have never seen a laptop burner die. However I have seen probably a half dozen desktop models die between home and work. However this is not exactly a fair comparison (few laptop drives versus 100+ desktop drives) and it totally has no statistical significance (way too small a sample).
It's not going to matter. Just go with a desktop drive and be done with it. I've had Laptop drives die on me, but never had a desktop one die but I've only been able to compare a handful at most. Seems when I was primarily using a notebook, I used it more often to burn DVDs than I have with a desktop unit.
Maybe. There's not enough data to prove or disprove that besides using anecdotal evidence.
In my experience, short of user incompetence, a small case of QA issues, or longevity issues, DVD drives on both desktops and laptops tends to last relatively long.
But honestly, getting a slim laptop DVD burner for a desktop does seem like waste of money considering the costs of DVD burners right now. If using the cheapest slim DVD burner on Newegg right now + the adapters that Old Hippie mentioned, you're looking at a total of $52. Considering that you can get a desktop DVD burner for $18 these days, doesn't make much sense to buy that slim DVD drive for a regular case. You can get three DVD burners for the price of that Slim DVD burner + adapters.
Yep!
I've never seen anything to indicate that the slim drives outlast the regular DVD drives.
Yep!
In fact, the slim DVD drives have their speeds reduced because they tend to heat up faster than standard DVD drives at every given speed.
I was going to mention something about the larger drive dissipating heat more efficiently which will probably extend it's life but I didn't know that drive speed was reduced to achieve the same thing.
I looked at the slim DVD drives: The write AND read speeds of the slim drives is limited to 8x for DVD media whereas those on a desktop DVD drive are at least 16x.
Sounds correct to me.
Heat reducing lifespan is a no-brainer. :)
