Colonel Sanders
- Sep 26, 2001
Wow, this monitor looks fantastic. This is the best monitor experience I've had to date.
Build quality is top notch. It's very pleasing aesthetically as well. The OSD is sensibly laid out (still not as awesome as the Asus joystick but it's OK.)
Colors are nice and certainly appear a bit more vivid than on the Dell, but not a drastic jaw-dropping difference... but it is noticeable. Contrast appears to be about the same as the Dell or other monitors I've recently tried, maybe a bit better (although obviously not as good as the XR3501 that I tried.)
The whole glow issue is nowhere near as bad as I feared. It's about the same or less than on my S2715H. If I sit extremely close to the screen, it might bug me, but at any reasonable distance it's hardly noticeable at all.
165hz is sweet. Pixel response time (ghosting) is very quick. It has more ghosting than on the 144hz TNs but not by much.
Anti-glare coating is perfect - it's just the right blend of anti-reflection while having zero graininess over the image.
I really have nothing but good things to say about it. I don't see a weak spot.
As luck would have it though, mine has a stuck pixel, smack dead center in the screen. In any other position I wouldn't be bothered, but this... this I can't deal with. Ugh.
I got mine yesterday and am not pleased with it. It has the exact same problem that the Asus pg279q had that I returned recently - specifically, the white uniformity, with the screen being yellowish in the top portion of the screen. I think I'm going to return this as well, as whites not being pure whites bugs the hell out of me. It's like looking at a white rug that has turned yellow over time.
I guess I'll stick with my Asus pg278q for now. I know that people have had better luck with this monitor than the Asus one, but the fact that it's still a gamble buying either is completely unacceptable.
How did you manage to find that out?Fixed the glow, turns out if you loosen the screw that is in the case directly behind that area, it goes away. Now I have a perfect monitor.
You don't really fix glow due to loosening the screw. You fix BLB by loosening the screw. The screw is located behind the center of the screen that is usually causing problems for a few people (it is behind the Predator logo).
Here is my monitor in dark. https://www.youtube.com/watch?v=khj48SMuqTc. This is how it should be. I have brightness at 30.
it would be nice if you posted pics.
Will this monitor have additional input lag compared to the XB270HU due to the addition of an HDMI input? Or is that a myth?
271 model predator seems to be discontinued. no longer on website.
I will officially say I believe I've made the best Surround gaming display setup in the world. This thing is just ridiculous in person...
purple on the left, orangy-yellow on the right.
I guess I lost Acer lottery!
So what does it actually look to your eyeballs? Looks like your camera is greatly exaggerating the typical IPS glow. These screens looks like that with exposure high and viewed from the worst possible angle.
Also, you can get rid of the bleed in the bottom center by loosening the screw directly behind that area on the back of the monitor.
I've been waiting on the PG279Qs for a while now. Since they've all disappeared from the stores (I assume Asus pulled them to try to fix QC issues), I was looking around and stumbled on this monitor. It looks SO much nicer than the original one. I'm thinking about ordering three.
Can anybody who owns one tell me how high you can raise the display on the stand? I'm pretty tall, so I need the monitor to be up high. It won't impact my buying decision, but I'm curious.
Since I happen to have a tape measure sitting right next to the monitor, it can be raised 8" from surface to bottom of display.
Just picked one of these up today after going through 4 Asus PG278q's. There is some yellowish bleeding coming from the bottom right and top left. You can only notice it on a black screen. Do you think its worth exchanging it?
Man this screen is way less sparkly then the PG278Q
Probably the only negative so far was how much of a pain in the ass it was to get the monitor out of the box. I tore chunks of the styrofoam on accident while trying to get it pulled.
By the way, I have to report that this monitor plays extremely well with my PS4 hooked via its HDMI input. No other monitor nor any HDTV I have ever used with my PS4 have given me the great color reproduction the Predator gives and the fast response it provides with no visible motion blur. Actually this Predator monitor could be named as the best display to use with your PS4.
