Anything better than this for gaming (in the 24"-27" size range) or is this still as good as it gets?
Still as good as it gets in the 16:9 range. Or trade a bit of color vibrancy for pixel response and zero IPS glow with Dell S2716DG or Asus PG278Q (I believe there is an Acer XB270HU with the TN panel as well, should be the same as the Dell and Asus.)
The color uniformity isn't great on these. The third monitor is the best, but it's also the bluest screen. The other two have pretty pronounced variation in color from left to right. I think it's fine for me as it's really only noticeable on a white screen, and when do you ever have a full white screen?
I've got my first monitor set up (the one I got from Microcenter). I'm pretty happy with it. No dust, stuck or dead pixels. I have very, very little BLB in the lower left corner. It's so minimal that I didn't notice it the first two times I checked it. On a white screen, I have quite bit of blue on the right edge of the screen, especially at the bottom. The biggest flaw in the monitor that I can see is that when there is a color on the screen (as opposed to white), the bottom-right corner appears pale. It looks like what the edges of the TN panel would look like. It kinda looks like glare, but it's not. If I move my head so my eyes are directly in front of that corner of the monitor, it goes away completely.
Overall, I'm very happy with this display.
Now it's time to install my other video card, and set up the other two. Hopefully, they will be as good as this one.
<edit>
The second monitor has the same thing in the lower-right corner. It's got a spot of BLB in the upper-right. The third monitor has BLB in both of the right corners, and another spot in the upper-left. It also has two stuck pixels (red). They're very hard to find. I'll have to test things out in a dark environment to determine if I can live with the BLB. The color uniformity isn't great on these. The third monitor is the best, but it's also the bluest screen. The other two have pretty pronounced variation in color from left to right. I think it's fine for me as it's really only noticeable on a white screen, and when do you ever have a full white screen?
</edit>
what gpu are using with these monitors?
Thinking about getting this monitor but not really sure about the backlight bleed.
Saw a pretty good explanation here that basically this doesn't bug you that much in every day work but I'm fairly picky
Originally I was planning on waiting till Star Citizen to come out to upgrade my GPU and monitor. I had a GTX 770 and Dell 20" Ultrasharp. After playing The Division open beta a couple weeks ago, I knew I couldn't wait.
My plan has been to upgrade to a 1440p gync monitor, but was clueless as to which one given all the problems I've read about with the IPS lottery. I was tempted to settle for a TN monitor like the Dell, but chose to gamble.
After reading that many people are having good luck with the XB271HU, I headed to Microcenter yesterday and picked one up. I have paired it with a GTX 980 Ti and it's glorious.
No dead pixels or dust that I can see. There is some black light bleed, but not significant. If it wasn't for these forums, I'd probably would have never noticed it to begin with.
Going from 1680x1050 to 2560x1440, high refresh rate and gsync is just amazing. The Division goes live in a couple hours and I can't wait.
These monitors are pretty good!
I haven't even calibrated them yet.
OSD:
Contrast: 50
Brightness: 20
Color Mode: User 100/100/100
Gamma 2.2
The uniformity between them all is pretty amazing.
This is one demanding setup. Pascal cannot come soon enough!
In one of the other pictures I think there's some overlap - think like fan blades, each display is not flush with each other.This may be a dumb question, but how did you eliminate the bottom bezels from effecting the multi display portrait setup?
Ugh. One of my monitors went bad last weekend. Windows will stop seeing it every once in a while. It causes all of my screens to go black for about 2 seconds and sometimes they all come back on, sometimes not. I'm talking to the Acer tech on the phone. He wants to know what kind of cable I'm using. He says, "DVI? HDMI? VGA?" I say, "No. I'm using DisplayPort." He doesn't understand, and apparently has never heard of DisplayPort. I had to direct him to Acer's web page on this monitor to get him to understand. LOL.
It never ceases to amaze me that people representing a product have no idea about said product.
