(cf)Eclipse
Freelance Overclocker
- Feb 18, 2003
whew! updated. now i have a reason to find the max stable of my opteron. i think somewhere around 2.9ghz with 1.58v is possible
psst. Must've missed my last post.(cf)Eclipse said:whew! updated. now i have a reason to find the max stable of my opteron. i think somewhere around 2.9ghz with 1.58v is possible![]()
ah, sorry dude, was loading images from my local cache.(cf)Eclipse said:what did i miss? 3091mhz prime stable under phase. you're definitly in there![]()
HybridHB said:I got the X2 3800 today. Its a CBDHE 0532 XPMW. I havent OC'd it yet but ill update this post when i do. For some reason i dont think its ganna do good
*edit* apparentlty the neo2 plat with bios 1.b doesnt like to OC. The voltage adjustments dont work, only the % boost thing does. Sooo thats kind of crappy. Its burning in right now at 10x250 at 1.42v. It is on water too so i think its not doing well at all. My friends does 2.6ghz at 1.42v on air
We'll see in a few days how this does sine the TIM hasnt broken in yet.
Scroatdog said:Well, where did you buy it??? (so I know not to buy it from there)
(cf)Eclipse said:heh, two 146's eh?
remind me of your cooling again asian![]()
I(illa Bee said:San Diego 3700+ e4 im guessing
ADA3700DAA5BN
KABYE 0536GPMW
XXXXXXXXX00075
2.80ghz 255ht x 11
1.53v Read from multimeter
Cooling: Air, XP90 with controlled fan not sure on the CMF at max, its a Dell fan made by Delta and I cant find the specs of it anywhere
*edit2* ARGHH!!!! Stupid Neo2 Plat w/1.B bios... Since the VID adjustments dont work, the max i can set the vcore to is 1.48v. The system booted at 10x280 w/1.48v but it crashes in windows immediatley. I guess ill have to wait for a better bios or new board. Anyone know when the Sapphire or MSI RDX200 boards will come out?
i don't get it, we have the same week though different stepping, and i had to up my voltage to hit 2.5ghz on water...Roberty said:X2 3800+
ADA3800DAA5CD
CCBWE 05355PMW
Running it at 250x10 at stock volts on air - XP-90 @ 29c in normal Windows environment.
running ram 1:1 2-3-3-7 1T 250mhz 2.8v
That's as high as it would go without upping the cpu voltage. Might give it a try when time allows.![]()
System specs in sig.
Elysian said:i don't get it, we have the same week though different stepping, and i had to up my voltage to hit 2.5ghz on water...
and i'm assuming the code on yours is SPMW just like mine, not 5PMW(i don't think thats a code)
Scroatdog said:You have a Manchester. He has a Toledo.
look at the last two letters of the first line of the OPNRoberty said:How can you tell that mine is a Toledo? Also, I thought all of the 3800's were Manchesters.Is mine just a faster Toledo with half the cache disabled and rebinned?
Presto88 said:Have my X2 3800 Toledo running at:
10 X 250 @ 1.4 with stock cooling
I have a big typhoon on the way. This is a preatty darn OC right?
Roberty said:Maybe the difference could be the motherboard ?I'm running an Ultra-D and your running a Epox. Maybe that's the difference.
Your right about mine being SPMW so I changed it in my above post. My eyes aren't what they used to be.![]()
