Your i7 is considerably faster at folding than a Core 2 Quad CPU. You can't compare your frame times to people who are running C2Qs.I don't know how you guys get more than 5 minutes per frame for a quad-core. My i7 gets around 3 minutes per frame.
I doubt it's twice as fast. Your Q9550 is actually clocked higher than my i7, and I take almost half as long to do a frame. Hyperthreading isn't supposed to make a difference; so what does? I don't really think the nehalem architecture is that much better than the Core 2 architecture.Your i7 is considerably faster at folding than a Core 2 Quad CPU. You can't compare your frame times to people who are running C2Qs.
You'd be wrong about that. Nehalem-based CPUs do considerably better than Core 2 CPUs at folding, especially with the A3 core. 10k PPD is pretty common with overclocked i5 CPUs, and 14-15k with overclocked i7 CPUs.I don't really think the nehalem architecture is that much better than the Core 2 architecture.
Memory subsytem. If the A3 core is more memory intensive, that would explain the difference. I don't know the technical differences between the A1/A2 cores versus the A3 to be absolutely certain.I doubt it's twice as fast. Your Q9550 is actually clocked higher than my i7, and I take almost half as long to do a frame. Hyperthreading isn't supposed to make a difference; so what does?.
You should be getting at least 4-5k PPD.Based on the info out there, what SHOULD I be getting on my QX9300?
Given that the other laptop mentioned above I getting higher PpD I have to assume something is wrong.
Other Specs: 4GB RAM, Win7 Ultimate x64. I left it alone for an hour and frame times did NOT improve
Yes. If that 1.3K PpD is being reported by HFM.net and you have it configured to calculate bonus points then something is wrong.so my Q9550 at 1.3K PPD is severly under than?!?
You'll probably need to use a priority-changing program to decrease the SMP client's priority, but aside from that you're golden.OK, just to be sure, is the new SMP GPU friendly yet? Im running 4 GPUs on this rig and thats the bulk of my points until I get bigadv going. I'd be adding a stock Q66, but if its not worth it ill let it wait
If it's any consolation, you're not the only one. I have 3 SMP2 clients and all of them are under 1500 PPD, sometimes under 1000 PPD. The weird thing about it is they're all very different hardware configurations. The only thing they have in common is XP as an OS and they all run at least 2 GPU clients. I'm going to be stopping at least two of these clients and either reverting to the original SMP client, running uniprocessor clients instead (not much difference in PPD) or shutting down the systems altogether. It just doesn't make sense to run them any more because the new bonus scheme indicates to me that they're not adequately productive.so my Q9550 at 1.3K PPD is severly under than?!?
It might be indeed and sometimes I also see high strangeness with FahSpy compared to HFM.net. But, most of the times both monitors aren't too far off, so I think what I'm seeing is probably the weird bonus calculations that amplify like crazy under a certain threshold in TPF. With GPU clients consuming CPU ccles like there's no tomorrow, your SMP clients get starved and exceed that magic TPF threshold, losing out on the majority of the bonus. It is biased towards very new architectures and low resource consuming machines, ie., the less GPU clients, the better.that 965 was getting 6k ppd with notfreds, i'm just hoping fahspy is just wacked
You can't. A3 is for SMP2 clients only.How do you setup a GPU to do A3??
AMD 965 @ 3.6Ghz 1k ppd (WTF!! core GRO-A3 pulling 5 min frames)that 965 was getting 6k ppd with notfreds, i'm just hoping fahspy is just wacked
I I'm going to be stopping at least two of these clients and either reverting to the original SMP client, running uniprocessor clients instead (not much difference in PPD)
@ Vaulter. Make sure you get the version 2.15 a3 core. 2.14 is not very sociable with GPUs and I couldn't get it to respond to any priority changing either.
Something is wrong with your point per day calcuations.
Sounds right to me.My main rig i5-750 @3.8 9600 ppd with a gtx260 getting 8500 ppd soo around 18,000 a day does this sound about right. the gpu takes about 4% of the cpu.
That is honestly very bizarre. I don't know why you would see that kind of performance.I am defnitely not getting this and have never even come close
I may need to go back to Linux VMs on this box as the PpD loss isn't worth it.
Wow, really? Even with the environment variables my GPU takes about 25% of the ppd of the SMP client.My main rig i5-750 @3.8 9600 ppd with a gtx260 getting 8500 ppd soo around 18,000 a day does this sound about right. the gpu takes about 4% of the cpu.
He's also using a GTX260, not an ATI card.Wow, really? Even with the environment variables my GPU takes about 25% of the ppd of the SMP client.
The environment variables are the fix. I presume he's already using them since he mentioned it in his post.does that ATI fix still work? would that help?
I don't see an option to enable or disable CPUs in the BIOS unless I overlooked it somewhere.Wow.... Your sure you don't have 1 CPU option enabled in the bios?
Which benchmark do you recommend? I could try anyone's suggestions.Have you run some benchmarks on it? Is it just folding that it sucks at?
3DMark, PCMark, SuperPi, wPrime. Most benchmarking sites and archives will have lists according to benchmark, architecture, and clock speed, so it should be easy to figure out whether something's wrong. Most of these benchmarks are pretty quick - 3DMark benches are only 5-10 minutes long at most, and everything else is much shorter - the SuperPi 1M benchmark should only take 5-10 seconds.Which benchmark do you recommend? I could try anyone's suggestions.
