I run so many different clients, it's hard to tell by looking at the stats. I usually have 4 to 8 WUs per update.Are you guys seeing the same credit from Stanford that HFM is showing?
Remember that you have to complete 10 units with your passkey before you qualify for the bonus. Until that happens, you will only receive the base points value for each workunit you submit.Are you guys seeing the same credit from Stanford that HFM is showing?
I had a 6012 unit going that finished this afternoon that was showing like 2500 points in HFM but it looks like I only got credit for 469 for some reason. Would it have anything to do with the system freeze I had today?
I've been looking forward to a big update all day and that's all I got. Here's hoping things pick up.![]()
Good point. 6012 is worth 470 points so this is clearly what happened OvrrDrive.Remember that you have to complete 10 units with your passkey before you qualify for the bonus. Until that happens, you will only receive the base points value for each workunit you submit.
cmd crashes everytime I change a setting! Very odd!
Although several guides state to rename the client .exe, it has been known to cause strange glitches like this but good to hear rebooting got it working again.Yes, changed it to fah6. I got it working now, I rebooted the system to give it a fresh start.
Regular clients do not count. They have to be 10 SMP WUs from either A2 or A3 cores or a mix of the two.Hmm... I have over 30 Wu with this passkey. I wonder why I'm not seeing the bonus. I'm running a classic client on an old machine, my PS3 and the smp client on my main rig. Out of the 67 wu's I have credit for under my name at least 30 are from the regular clients.
Honestly, Kendrak, I don't know what's up with this system. There are two CPUs installed and I get 8 cores detected in both Windows and Linux, but it's like there's only 2 cores performing out of the 8 since I got the board. If anyone has good benchmarking or hardware testing utilities to recommend, please feel free to mention them. I'd really appreciate all the help I can get to finally resolve the issue with this system after a year of disappointment. The A3 WUs convinced me there is something very wrong.Wow.... Your sure you don't have 1 CPU option enabled in the bios?
Have you run some benchmarks on it? Is it just folding that it sucks at?
anyone got an estimate for a dual opteron (8347's at 1.9ghz) ? Its 8 real cores
as I was alluding to yesterday, put the name of the executable back to its original name. As odd as this may sound, there have been some, albeit rare, similar issues like you are experiencing and it was related to the renaming of the executable.So I got my Win 7 going on my i7 and my AMD. Now cmd is crashing in XP 32bit on my Q9550. It crashed at different time of the config.
It's always after I change a setting though.
I see there are a number of users who PPD has jumped with SMP2.
Gotta keep EVGA back any way we can.
# Windows CPU Console Edition #################################################
Folding@Home Client Version 6.29
http://folding.stanford.edu
Launch directory: C:\Program Files\Folding@Home Windows SMP Client V1.01
Executable: C:\Program Files\Folding@Home Windows SMP Client V1.01\Folding@home-Win32-x86.exe
[18:30:30] - Ask before connecting: No
[18:30:30] - User name: 404_-_File_not_found (Team 33)
[18:30:30] - User ID: 680978A6606E4631
[18:30:30] - Machine ID: 1
[18:30:30]
[18:30:30] Loaded queue successfully.
[18:30:30] - Preparing to get new work unit...
[18:30:30] Cleaning up work directory
[18:30:30] + Attempting to get work packet
[18:30:30] - Connecting to assignment server
[18:30:31] + No appropriate work server was available; will try again in a bit.
[18:30:31] + Couldn't get work instructions.
[18:30:31] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[18:30:39] + Attempting to get work packet
[18:30:39] - Connecting to assignment server
[18:30:40] + No appropriate work server was available; will try again in a bit.
[18:30:40] + Couldn't get work instructions.
[19:14:22] + Attempting to get work packet
[19:14:22] - Connecting to assignment server
[19:14:23] + No appropriate work server was available; will try again in a bit.
[19:14:23] + Couldn't get work instructions.
[19:14:23] - Attempt #10 to get work failed, and no other work to do.
[19:57:10] + Attempting to get work packet
[19:57:10] - Connecting to assignment server
[19:57:10] - Successful: assigned to (171.64.65.60).
[19:57:10] + News From Folding@Home: Welcome to Folding@Home
[19:57:11] Loaded queue successfully.
[19:57:15] + Closed connections
[19:57:15]
[19:57:15] + Processing work unit
[19:57:15] Core required: FahCore_78.exe
[19:57:15] Core not found.
[19:57:15] - Core is not present or corrupted.
[19:57:15] - Attempting to download new core...
[19:57:15] + Downloading new core: FahCore_78.exe
Arguments: -advmethods -smp 8 <- They should show up there
You don't have to add the -advmethods flag as an additional parameter since there is a configuration option to always include it if you indicate yes. I really do have A3 cores (3 different clients), but fahmon must need an update or something since it isn't indicating a very high ppd (it also has a message about unknown core). At least it isn't crashing!
Do you need to specify the number of cores like " -SMP #" or can you just include "-SMP"? I just did it as "-SMP" and the computer indicates all four cores of the Q6600 are going but fahmon (2.3.99.1) shows an anemic 950 ppd compared to about 4500 ppd with an A2 core in a notfred VM.
Fahmon does not calculate bonus points. You will need to use HFM.NET or Fahspy if you want to know your true PPD. Also, don't forget that you need to use a passkey and you need to have completed 10 workunits with it in order to qualify for the bonus.You don't have to add the -advmethods flag as an additional parameter since there is a configuration option to always include it if you indicate yes. I really do have A3 cores (3 different clients), but fahmon must need an update or something since it isn't indicating a very high ppd (it also has a message about unknown core). At least it isn't crashing!
I have the arguments loading now, ran the install.bat, but I am now getting a1.. and it's interfering with the gpus! lol. But anyway it doesn't matter, I won't be running smp2 on that machine (I read that dual cores running smp2 a3 get less points than a2).
My E2140 gets less PPD compared to the A2 core, and I've seen similar results from other people folding on dual-core CPUs. I also tried it for a bit on my laptop but I stopped it once I saw that I was only getting about 300PPD from it. The conclusion is that SMP2 is only really advantageous for CPUs with 4 cores or more, but below that it puts out worse PPD. I suspect that this is largely due to the bonus.My Core 2 Duo processors are getting more PPD with SMP2 then SMP1 ever did.
Core 2 Duo T9300 (45nm) 2.5Ghz: 2000 PPD on projects 6012, 6014, 6015
Core 2 Duo Xeon 3075 (65nm) 2.67 Ghz: 1950 PPD on projects 6012, 6014, 6015
Project ID: 6015
Core: GRO-A3
Credit: 484
Frames: 100
Name: ganymede - SMP2
Path: C:\fah\smp2\
Number of Frames Observed: 600
Min. Time / Frame : 00:02:56 - 18,686.7 PPD
Avg. Time / Frame : 00:03:18 - 15,660.4 PPD
--- Opening Log file [January 27 01:18:21 UTC]
# Windows SMP Console Edition #################################################
Launch directory: c:\Folding\SMP0
Service: c:\Folding\SMP0\fah6
Arguments: -svcstart -d c:\Folding\SMP0 -smp 8 -verbosity 9 -d "C:\Folding\SMP0"
Launched as a service.
Could not enter c:\Folding\SMP0! Working in launch directory.
[01:18:21] - Ask before connecting: No
[01:18:21] - User name: Nitrobass24 (Team 33)
[01:18:21] - User ID: 232E22C456A7A67F
[01:18:21] - Machine ID: 10
[01:18:21]
[01:18:21] Loaded queue successfully.
[01:18:21]
[01:18:21] + Processing work unit
[01:18:21] Core required: FahCore_a3.exe
[01:18:21] - Autosending finished units... [January 27 01:18:21 UTC]
[01:18:21] Trying to send all finished work units
[01:18:21] + No unsent completed units remaining.
[01:18:21] - Autosend completed
[01:18:21] Core found.
[01:18:21] Working on queue slot 06 [January 27 01:18:21 UTC]
[01:18:21] + Working ...
[01:18:21] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 06 -np 8 -checkpoint 15 -service -verbose -lifeline 5144 -version 629'
[01:18:21]
[01:18:21] *------------------------------*
[01:18:21] Folding@Home Gromacs SMP Core
[01:18:21] Version 2.14 (Dec 16, 2009)
[01:18:21]
[01:18:21] Preparing to commence simulation
[01:18:21] - Looking at optimizations...
[01:18:21] - Files status OK
[01:18:21] - Expanded 1799773 -> 2392545 (decompressed 132.9 percent)
[01:18:21] Called DecompressByteArray: compressed_data_size=1799773 data_size=2392545, decompressed_data_size=2392545 diff=0
[01:18:21] - Digital signature verified
[01:18:21]
[01:18:21] Project: 6015 (Run 0, Clone 121, Gen 1)
[01:18:21]
[01:18:21] Assembly optimizations on if available.
[01:18:21] Entering M.D.
[01:18:27] Using Gromacs checkpoints
[01:18:28] Resuming from checkpoint
[01:18:28] Verified work/wudata_06.log
[01:18:28] Verified work/wudata_06.trr
[01:18:28] Verified work/wudata_06.edr
[01:18:28] Completed 300 out of 500000 steps (0%)
[01:21:51] Completed 5000 out of 500000 steps (1%)
[01:26:42] Completed 10000 out of 500000 steps (2%)
[01:30:19] Completed 15000 out of 500000 steps (3%)
[01:33:58] Completed 20000 out of 500000 steps (4%)
[01:37:31] Completed 25000 out of 500000 steps (5%)
[01:40:54] Completed 30000 out of 500000 steps (6%)
[01:44:20] Completed 35000 out of 500000 steps (7%)
[01:47:44] Completed 40000 out of 500000 steps (8%)
[01:51:06] Completed 45000 out of 500000 steps (9%)
[01:54:34] Completed 50000 out of 500000 steps (10%)
[01:57:58] Completed 55000 out of 500000 steps (11%)
[02:01:21] Completed 60000 out of 500000 steps (12%)
[02:04:46] Completed 65000 out of 500000 steps (13%)
[02:08:10] Completed 70000 out of 500000 steps (14%)
[02:11:34] Completed 75000 out of 500000 steps (15%)
[02:14:58] Completed 80000 out of 500000 steps (16%)
[02:18:21] Completed 85000 out of 500000 steps (17%)
[02:21:47] Completed 90000 out of 500000 steps (18%)
[02:25:09] Completed 95000 out of 500000 steps (19%)
[02:28:34] Completed 100000 out of 500000 steps (20%)
[02:32:07] Completed 105000 out of 500000 steps (21%)
[02:35:50] Completed 110000 out of 500000 steps (22%)
[02:39:18] Completed 115000 out of 500000 steps (23%)
[02:42:43] Completed 120000 out of 500000 steps (24%)
[02:46:06] Completed 125000 out of 500000 steps (25%)
[02:49:31] Completed 130000 out of 500000 steps (26%)
[02:53:02] Completed 135000 out of 500000 steps (27%)
[02:56:30] Completed 140000 out of 500000 steps (28%)
[02:59:55] Completed 145000 out of 500000 steps (29%)
[03:03:29] Completed 150000 out of 500000 steps (30%)
[03:06:55] Completed 155000 out of 500000 steps (31%)
[03:10:23] Completed 160000 out of 500000 steps (32%)
[03:13:57] Completed 165000 out of 500000 steps (33%)
[03:17:42] Completed 170000 out of 500000 steps (34%)
[03:21:16] Completed 175000 out of 500000 steps (35%)
[03:24:48] Completed 180000 out of 500000 steps (36%)
[03:28:38] Completed 185000 out of 500000 steps (37%)
[03:32:13] Completed 190000 out of 500000 steps (38%)
[03:35:49] Completed 195000 out of 500000 steps (39%)
[03:39:23] Completed 200000 out of 500000 steps (40%)
[03:43:04] Completed 205000 out of 500000 steps (41%)
[03:46:42] Completed 210000 out of 500000 steps (42%)
[03:50:20] Completed 215000 out of 500000 steps (43%)
[03:54:01] Completed 220000 out of 500000 steps (44%)
[03:57:39] Completed 225000 out of 500000 steps (45%)
[04:01:14] Completed 230000 out of 500000 steps (46%)
[04:04:47] Completed 235000 out of 500000 steps (47%)
[04:08:16] Completed 240000 out of 500000 steps (48%)
[04:11:45] Completed 245000 out of 500000 steps (49%)
[04:15:18] Completed 250000 out of 500000 steps (50%)
[04:18:46] Completed 255000 out of 500000 steps (51%)
[04:22:16] Completed 260000 out of 500000 steps (52%)
[04:25:44] Completed 265000 out of 500000 steps (53%)
[04:29:13] Completed 270000 out of 500000 steps (54%)
[04:32:43] Completed 275000 out of 500000 steps (55%)
