Fantasysage
- Mar 29, 2010
What the hell can I do with this?
http://i.imgur.com/UqqmM.jpg
My case is far too small for what is in it. The CPU is fine, but those GPU's can get uncomfortably toasty. I upgraded the intake and exhaust fans with Sythe Slipstream 1900rpm fans. And took one of the old crap fans, and use automotive double stick tape to put it over the VGA port as an intake. I also keep both 280's fans on 100% 24/7 otherwise they idle at 70c and load at 95+. With the addition of the side fan and keeping them at 100% they sit at 55 idle and 75-80 load. Cable management is for naught, I have nowhere to route those suckers.
And the kicker I cannot upgrade my case. If my old man find out I just dropped an extra $1,100 on PC parts I am a dead man.
