You're right. Nobody else on the internet has any idea what they are doing and is just making up stories about the heat output of a 9900k at 5Ghz, especially under AVX loads. I don't know why Intel doesn't just contract with CM to throw in some 212 Evo's because that's all you'd need anyway.
/s
The footprint of the die is smaller, it is harder to remove the same energy from a smaller space.I’ve seen a lot of people on the interwebs bemoaning the heat produced by a well overclocked 9900k.
Please remember that in reality, a 5ghz overclock on a 9900k will hit about 185w.
A few years ago 6 core cpus were in that range, at much slower clocks.
Most midrange coolers these days will happily handle 200w, especially if it is transient.
This “issue” has been blown way out of proportion
I actually found the 9700k hotter (temperature wise) than the 9900k. Maybe I got a golden sample?
I guess you’ve probably missed the latest trend in computing in the last decade. Efficiency. Intel has proven time and again slight, very slight clock and Ipc increases are the most attention the architecture will get, compared to their focus on efficiency.I’ve seen a lot of people on the interwebs bemoaning the heat produced by a well overclocked 9900k.
years ago the 6core chips had larger dies as well, which is better for heat transfer.
Thermal dissipation is about more than the TDP. Die and node size are big contributors. If the CPU is using 20W less power, but there is only half the surface area that can make contact with a thermal dissipation device, then it's going to be harder to keep the CPU cool. But go ahead and dismiss the experiences expressed by not only thousands of random internet posters, but many reputable review sources as well. Myself, I had to switch out a 280mm radiator for a 360mm one just to make the heat more manageable.I’ve seen a lot of people on the interwebs bemoaning the heat produced by a well overclocked 9900k.
