I just overnighted the Gigabyte model from Newegg, then remembered there's no Win10 driver.
I hope they have one soon....
The non-reference cards could have custom power phases and vBIOS that would allow for higher overclocking. The vBIOS is easy for the user to customize, though, so the main attraction is for the aftermarket components.Any reason to spend more for one of the non-reference cards if immediately slapping on a G10 bracket + AIO cooler from current card?
The reference temp and noise actually look pretty good this time... But I really should just wait a few more weeks.
Sorry its so big. Pulled from evga thread.
1 month.Have any estimated release dates been posted?
I'm in the Step-up queue!
+1
Can't believe I'm gonna get these babies for $80 per card. I had 8 days left on my step up too!
Just pulled the trigger the EVGA version on Newegg.![]()
It's my first EVGA card and first Nvidia card in years 7+ years, upgrade from a OC'd 290x. I just couldn't wait any longer had to scratch the itch.![]()
Congrats. You won't have to wear earplugs anymore while gaming.
Did anyone read in a review whether these support HDMI 2.0 like the 970/980? I only ask because apparently the Titan X had issues with this. I'm using a UHD TV with HDMI 2.0 input for 60hz with 4:4:4 chroma.
According to the Guru3d review I read, it says HDMI 2.0
So from all non reference solutions which one do you guys think it will dump less heat inside the case ?(minus the hybrid one ofc)
Leaning towards the hybrid but would prefer to avoid water in my pc..
this one for example, doesn't even have a rear vent: http://www.overclock3d.net/gfx/articles/2015/06/01062943969l.jpg
So is this going to be a full 6gbs or 5.5gbs of vram ?
I already tried non reference design with the 970s. Even with 970s being extremely cool running cards the heat inside my case was causing my processor to heat up to 80 C.
To avoid this in the future, this cycle I have opted for blower coolers. My only question is will there be new and faster NVidia cards released by end of this year? If that happens, I will be one pissed puppy.
I can go up to 1450 MHz Boost (+150 core in MSi AB on EVGA SC) with the reference cooler on my Titan X at 100% fan speed. Card will get up to 82-85C living in a hot climate. I have to play with my headphones on, though, because the fan spins up to nearly 5000 RPM and it's quite noisy. I'm replacing the reference blower with the ACX 2.0+ cooler from EVGA today. If I had the room for another radiator in my case I would have gone with the Hybrid cooler instead. The card needs more voltage to go higher, and I'm definitely not comfortable bumping the voltage with the reference cooler.I'm also concerned about cooling this card. The reference cooler really doesn't seem capable of handling much of an overclock at reasonable noise levels after looking at reviews. Any OG Titan, 780 Ti, or Titan X owners living with the reference cooler and a nice OC?
I currently have an eVGA ACX 2.0 cooler in a FT02 without any issues -- there's no problem pushing hot air out the top even with this type of cooler, but little maxwell has less heat to dissipate. The hybrid coolers seem to have a significant advantage at this power point, and they seem to be a decent value compared to buying a bracket and a separate AIO cooler.
I can go up to 1450 MHz with the reference cooler on my Titan X at 100% fan speed. Card will get up to 82-85C living in a hot climate. I have to play with my headphones on, though, because the fan spins up to nearly 5000 RPM and it's quite noisy. I'm replacing the reference blower with the ACX 2.0+ cooler from EVGA today. If I had the room for another radiator in my case I would have gone with the Hybrid cooler instead.
