The AW3420DW is fine don’t listen to the pro gamer and his tiny 240hz monitor. Enjoy your setup and maybe wait for the next Intel or AMD chip.No, it's not worth it. Next gen from Intel will be a worthy upgrade. Get 9900k and call it quits if you are bored. You should get a better monitor since AW3420DW has terrible g-sync implementation and is only 120hz. I used it as side monitor next to aw2721d.
LOL my monitor is fine..No, it's not worth it. Next gen from Intel will be a worthy upgrade. Get 9900k and call it quits if you are bored. You should get a better monitor since AW3420DW has terrible g-sync implementation and is only 120hz. I used it as side monitor next to aw2721d.
Your money. Your rig...got an upgrade itch and wondering if i should scratch it..currently running 9700k and was toying the idea of going with 12700kF and upgrade my ssds to gen4 to pair with my RTX3080. but get a z690 board that supports DDR4.
worth it?
The only tiny thing here is your small e-peenie.The AW3420DW is fine don’t listen to the pro gamer and his tiny 240hz monitor. Enjoy your setup and maybe wait for the next Intel or AMD chip.
Did read what you wrote and still stand by what I said to you. Horrible advice.The only tiny thing here is your small e-peenie.You really need to reread what I wrote.
Not sure it’s even worth charging the CPU to the 9900k. Check out the video below that puts them side by side. Very close in gaming and sometimes even faster than the 9900k.
If you game at 1080p or 1440p, you should get an Alderlake. Your 3080 won't fully stretch its legs at those resolutions, with a 9700k.got an upgrade itch and wondering if i should scratch it..currently running 9700k and was toying the idea of going with 12700kF and upgrade my ssds to gen4 to pair with my RTX3080. but get a z690 board that supports DDR4.
worth it?
I agree. I've been battling the upgrade bug as well. If I didn't game at 4K I probably would have upgraded by now, but I don't think I would see much of a difference upgrading from my 10850K.The question you should be asking is whether or not your current rig is performing well enough. If you're satisfied with it, then save yourself the several hundred dollars you'd spend upgrading it for when something comes out that is actually better for you. Only you can make that determination, but if you were me and that was my gaming rig, I'm not bothering to upgrade it at this time.
Please do report back.I'm upgrading exactly as you described above except I have a 3090. I should know by Sunday if it's worth it.
Its also a hobby for most. Plus we’re all a little sick. LOLI'm kind of surprised that people upgrade such small jumps if they are not playing high competitive or at pro level, considering you are all playing with higher resolution with graphics maxed.
I understand if you do anything work related that's CPU intensive, but for gaming? I don't get it.
Well, they are "influencers" or simply streamers with hardly any knowledge, which isn't something new.several of those pro gamers have little to no idea how to tweak their hardware, software, or almost anything outside of setting up their streaming gear and following the settings of other streamers. I've spent a bit of time around them (through Dota, Tarkov, and CoD), most are not hobby enthusiasts but just average people wanting to make money from gaming following the hivethink of hardware/software/find sponsor and putting on an attitude to appeal to an audience. Their focused on pushing frames and thats all.
Some of us, many of us here, are hobby enthusiasts. We like to upgrade, tinker, get more out of our hardware and software, and we get excited for new things to tinker with. Its a hobby not a job.
I could make due with my office system circa 2014, it runs everything i need and want to with only a few issues in newer and cpu intensive titles, but I still rock a newer system and am putting together an I9-12800k w/3090 while eagerly awaiting the new amd cpus.
