$902.49 setup. good??
chris22
case: centurion 5
mobo: ASUS A8N-SLI Premium Socket 939 NVIDIA nForce4 SLI ATX AMD Motherboard
vid card: eVGA 256-P2-N386 Geforce 6800GS 256MB GDDR3 PCI Express x16 Video Card
ram: CORSAIR ValueSelect 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model VS1GBKIT400
processor: AMD Athlon 64 3500+ Venice 1GHz FSB Socket 939 Processor Model ADA3500BPBOX
hard drive: Maxtor QuickView 6L100M0 100GB 7200 RPM Serial ATA150 Hard Drive
power supply: ATRIX PSCI-480 ATX 480W Power Supply 115/230 V UL, CE, CB, FCC
any advise or comments would be grately appreciated along with any ideas etc... thanks!
power supply: Antec TRUEPOWERII TPII-480 BLUE ATX12V 480W Power Supply
i wanna try to run like cod2 quake 4 and cs source do u think i can handle it??
oops i didnt add the power supply to the description
I'd spend an extra $20-$40 and double (or almost triple) your HD size with a Seagate Barracuda.
i dont think so im looking on a site called ibuypower.com i might just buy 2x 6600gts is that a good combo or should i go 7800 gt??
Price/performance wise - yes
Benchmarking - no
Real world gaming - yes and no depends on game
Go one 7800GT then upgrade later, trust me, right now ONE 7800GT is good enough to play at high iq and at decent framerates. Add another 7800GT later, omg, :p
stay the hell away from ibuypower.com, their systems are great, but their parts system is terrible! It took over a month for me to get my RMA back! And that's only because they got sick of my calling them!
ok so here is what i have check this out i just ditched the whole try to be cheap thing and came up with this!
Case: ASPIRE X-Superalien
PSU: Antec TruePower 2.0 550W Power Supply
Motherboard: Asus A8N-SLI Premium
Processor: AMD Athlon 64 X2 4200+ Manchester 1GHz FSB Socket 939 Dual Core
Video Card: BFG Tech Geforce 6800GT 256MB
RAM: CORSAIR XMS 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit
HDD: Western Digital Caviar SE WD2500JS 250GB 7200 RPM SATA 3.0Gb/s
Sound Card: Creative Sound Blaster X-Fi XtremeMusic 8 (7.1) Channels
OS: Windows XP SP2 Home Edition OEM
This should equal $1660 with about $100 shipping.
if i wanted to play like quake 4 can i with good frame rates and everything on that 6800 gt??
A 6800GT AGP or PCI-E can handle any game you throw at it. Just OC it a bit, is my suggestion. Most all GTs oc' to 6800 Ultra speeds easily, so it wouldnt be a bad processor to go with. Although, the 7800GT/X has 24 pixel pipelines instead of 16, and all the other things that make it a much better processor than the 6800 GT. SLI? I dont think so, at least not yet. I havent come across ONE game that even my single AGP 6800 GT cant handle, I really dont think SLI will be necessary with something as powerful as a 7800GT/X.
Just my personal opinion, but ditch the maxtor HDD.
I work with these little buggers everyday, they are very suseptable to heat and die quite readily. The HDD checking tools are the worst I have encountered.
I'm sure many people love them, and a lot of folks save cash buying a cheap HDD but my advice is stay away.
I've had great luck with Maxtor drives, but I do recommend something bigger than that 100 gigger.
Western Digital is very good too. Seagate drives have a good rep for running cool and quiet, but are finicky when it comes to how you set them up sometimes.
truth, go with Seagate/Hitachi/WD
Finicky? It's simple, no slave = no problem :)
Don't run slave drives anyhow, they kill your performance :D
updated list
HDD: Seagate Barracuda 7200.8 ST3250823AS 250GB 7200 RPM Serial ATA150 Hard Drive
Heh, when you have two optical drives, two hard drives, and two IDE channels you sort of have to...
chris22 said:
updated list
Drop the Corsair XMS for some G.Skill value, drop the 4200+ to a 3800+, drop the SLi motherboard for an A8N-E, and get the 7800GT and an XP-90 and overclock your cpu past 4200+ speeds.
sorry im not interested in overclocking right now :( :( :(
but thank you for your input
chris22 said:
updated list
Looking good. Excellent HD choice. Drop the 6800GT and get the 6800GS. It's a little more powerful and'll actually save you a good $50-$75.
Actually, the there have been many 7200.8's reported to have failed recently.
7800GT ftw...or at least get a 6800GS if you don't want to spend the money. The 6800GT is overpriced.
Woah this $900 rig has shot up in price.
I would expect a very good system to cost about $1200-1300, but $1600? Damn that's too much of a price increase from the original $900.
Your money, but if you originally wanted to spent $900 I would try and trim the fat a little. You just got to figure out the "opportunity cost" of the current extra $700.
Good luck with the rig, glad you dropped the Maxtor.
I would try to find an Opteron 165 or 170 instead of the X2. Might have a lower stock clock speed, but double the cache. You cant make up for cache by OC'ing, and you'll be able to get 2.4-2.5, and probably as high as 2.6-2.8. The 165 would be harder to take up to 2.8 (provided both cores are stable at that speed) because you'd need to hit at least 300htt.
Also, consider getting a WD or Maxtor 16mb cache hdd instead of the Seagate.
get the 7800gt....do not get the 6800gt/gs....my freinds 6800ultra is playing games quite slowly even though his is heavily oc'ed...you wont see the age on the 7800gt for a long time, and trust me youll need it for FEAR and Quake 4 and Cod 2 etc etc etc
it costs too much now, 1600$ hell, i could build to computers with it. i second the above to trim the price a little.
time to upgrade to bigger drives! Don't want to run ATA33 for the rest of your life, do you?
I am going to toss an extra ATA controller card into a spare slot and move some of the drives over to it I think. I want to add another 650 or so gigs of storage anyway, so that I can reorganize my files, start getting more into my anime addiction, and play around with linux more.
so what do u guys sugjest that i can do to cut down on price but still have a reall good gaming pc
