- Oct 29, 2000
So I ordered one of those Gigabyte triple fan 7970 OC cards.
First thing I always do when I get a new video card is to test baseline temps etc.
So at stock speeds (for this OC card that's 1000Mhz core) I turn the fans up to 100% manually and check how hot it gets in Furmark.
I immediately noticed that the GPU was throttling itself. So i went to CCC and altered the Power Control Settings to +20%, leaving voltage and core frequency at their stock 1000Mhz.
With all three fans pinned at 100% I restarted Furmark.
The line chart in Furmark shows the GPU getting hotter and hotter and its increasing at about a 45 degree angle. I expect it to eventually taper off (like it has with every other video card I've ever owned) but it never does. Last temp I see is 98C, then the computer crashes.
My philosophy has always been to never overclock past where Furmark temps are safe. With this video card Furmark temps aren't even safe at stock...
So either this Gigabyte 7970 can't even handle Furmark at it's stock settings, even with its big ass cooler, or I have a defective board.
Which is it? Opinions?
