inglewood78
- Aug 25, 2004
Out with the old, in with the new.
![photo-4.jpg](http://i821.photobucket.com/albums/zz133/Inglewood78/photo-4.jpg)
![photo1.jpg](http://i821.photobucket.com/albums/zz133/Inglewood78/photo1.jpg)
You got it!
I call it, "The AcryliCruncher".
3930k w/ Apogee HD
Rampage IV Extreme
Ripjawz (Gskill) 1600 4 x 4GB
3930k w/ EK Block
Seagate 1TB
Black Ice II 240 w/ AP 15's
Using right now in the Prime Grid Year of the Dragon Challenge
I busted all those asshats with the presidents masks back in '91
Ill be running benches after I get done with Prime Grid. I ran Furmark and had no problems at 1200 and stock @ 1.174 volts. Amazing. Can't wait to see what happens with some more juice.
Agent Utah, out.
I am wanting to get a 7970 with a water block now as opposed to having the air cooled custom ones. But I cant decide.
1x Black Ice GTS 360 Radiator | 2 x Swiftech 320 QP Radiator | 1x Swiftech 220 QP Radiator
if you already have a water setup it's a no-brainer.
Yea but 550+130 for a water block. 680 for 1 videocard. Thats really pushing it lol.
Or you could get a much cheaper Antec Kuhler 620/920 or a Corsair H70 and mod your card with it like this:
Links:
http://www.corsair.com/blog/using-a-hydro-series-h70-on-a-nvidia-geforce-gtx480/
http://www.overclock.net/t/1140299/gtx-480-sli-antec-620s-mod
http://www.overclock.net/t/1086286/complete-build-log-zotac-560ti-corsair-h70
http://www.overclock.net/t/1198510/build-log-amd-6970-lightning-antec-kuhler-920-mod-56k-warning
Looks like stock has picked up! Ugh, I just can't bring myself to spend that much on something I don't really need for 1920x1200 occasional gaming. I'll probably pick up a used 580 if I can get one for $350-ish.
Links:
Links:
Why didn't I think of this before?You're awesome.
Zarathustra[H];1038314805 said:Second that.
I'm definitely considering this now.
One question, once you do this mod, what do you trigger the fan speeds off of? Have you just set them manually to a fixed rpm?
I know the Kuhler 920 has software built in that allows you to control the RPM's based on loop temp, but the corsair ones don't seem to.
Is there any way to trigger the fans off of the pwm from the video card? Has anyone tried this?
Thanks,
Matt
Sounds like a great idea indeed. Though without a custom block for your card, wouldn't this leave your VRRMs (and basically everything other than the GPU itself) without proper cooling?
Robbie where did you order your block from? I keep seeing them out of stock.
I'll wait till Nvidia has an equivalent card out. Been burned twice on shitty ATI drivers, never again.
Well saidCan you go thread crap somewhere else asshat!
This thread is for people looking to purchase this card go to nvidia.com and cry.
Asus 7970 DCII for pre-order on directron with eta of 2/3/2012
http://www.directron.com/hd7970dc2t3gd5.html
