7970, or a second GTX570?
No single GPU at the moment can handle BF3 at 1080p ALL maxed to be above 60fps 100% of the time.
I made a thread about this before about my experience going from SLI 570s to a single 7970. It was an upgrade indeed. With my 570s, I could play at 2xMSAA, but not at 4xMSAA because of the stuttering with the limited VRAM. At 2xMSAA and SLI 570s, during the most intense firefights, it would stutter but not as much as 4xMSAA where it would stutter every fight, sometimes randomly. $700 video cards couldn't handle BF3 so I got rid of it since my main purpose of my comp was to run BF3 maxed.
Got a single 7970. Great improvement, albeit the average FPS is lower because the 570s did have more power so I went from an average of about 85s down to 60s on the 7970. The 7970 was able to play 4xMSAA, all Ultra, 90 FOV no problem at all. No stutter, no hiccup. The only problem is that it lacks the GPU power and at certain times, it WILL dip into 40s, but it's a smooth transition. The single 7970's 40fps is purely, 40fps. The 570's 40fps was stutter, stagger, jerky 40fps. The 40fps from the 7970 is very playable.
Surely, of course I turned MSAA down from 4x down to 2x down to 0xMSAA just to test it out, to see if it would still dip under 60fps since I would like it to stay above 60fps. Even with 2xMSAA, it did drop down to 40s because simply, the 7970 doesn't have enough OOMPH in the GPU area to push it out of the 40s even with the 3GB VRAM and lowered MSAA.
Note: This strictly depends on the map and size of games.
The Karkand maps are the most taxing. These are the maps where a single 7970 would dip into 40s-50s. Caspian Border, etc. will stay above 60fps+ 99% of the time, and will average 70-80fps with 4xMSAA all maxed.
I missed my high average FPS from my 570s, so shortly after.....
I added a second 7970.
I'm sorry but that is bullshit. I have zero stuttering in BF3 maxed with 4x MSAA. Something must have been wrong with your setup.
Any benchmark will clearly tell you that 570 SLI is faster than one 7970, period.
Just wanted to throw in that a single 7970 will get you a consistent 60 fps (maybe dipping down to 55) in BF3 MP with everything maxed except MSAA but if you just use high post process AA you will get the same visual quality with almost 0 performance hit.
Nice.....you coming from experience here?
Hmm I think I stepped into a strange alternate universe, i'm not sure whats going on here
Maybe he plays with vsync off. All dual GPU setups have major microstutter when playing with vsync off, if you are under 60fps.
That's not true, either. Vsync or no I'm not getting microstutter, and I regularly play ArmA2 which is CPU-bound and can drop below 40 FPS often. Have Vsync off for that.
It's not entirely clear why wringer people get microstutter and some don't, but it's not ALL multi GPU setups.
All I know is that if GTX 570 SLI is comparable to 6970 xfire you will be in good shape with the SLI setup. My xfire unlocked 6950s beast BF3.
Looks how the 590 and 6990 stack up against the 7970 to get an idea of it compared to SLI/xfire setups.
I'd take the performance hit any day considering you can still get enough for the 570 if you sell immediately. Once the next gen nvidias hit, your 570 SLI won't be worth much (or likely a lot less anyway) but the 7970 should take less of a hit on resell value.
It's a toss up, but for forward thinking the 7970 is definitely going to be better. The 570 will give you some more frames but you have no upgrade path and will need to take a hit selling them and going to gtx 6XX or hd 79xx or the following version. Either way, 1.25 GB is almost certainly a limit and will be even worse once the new games come out.
Actually, make the a HD 7950 with a good cooler.
I think I'm just going to start with a 7970, and if it's not enough, I'll get another one. LOL
I'd go with the 7970 since dual cards also bring along higher power consumption,more heat and noise.
2 570s is a step backwards. 2 gpus just suck compared to single unless they are at least 580s or 7970s
The 7970 oced gets 50-79% better performance than a single 580 oced so I think it might be better than 2 570s
is AMDrocks getting deleted in every thread lol
I tHiNk hE MiGhT bE a fAnBoY lol
He already got banned awhile back for spamming a bunch of anti-nVidia propaganda.
And no, one 7970 is not faster than 2 570s...not even close, really. We've already addressed that in the thread so stop saying it.
Plus, the OP already made up his mind so just let the thread die.
