75 instant EUEs within an hour
jebo_4jc
[H]ard|DCer of the Month - April 2011
I just EUEd on approx 75 Wus in a row on my sr2 rig due to testing smp -19. Is that going to screw up my eligibility for bonus points?
It depends on what you've submitted thus far for all your rigs under your username.
It's possible though if it took you below the 80% mark in regards to all your bonus based SMP work units.
If it sent back 75 partial results, yes.. you are going to be screwed.
is the 80% standard calculated over the entire history of my passkey?
If so, 75 might not put me under that limit.
I hope not.
I hope not.
I was under the impression it was, but I would go ask over in the Folding Forums to be sure...I really hope for the team's sake that isn't the case:(
Im gonna say no as it probably eue'd the same unite. hopefully
i wish. it's not the case
Code:
[14:56:14] + Attempting to get work packet
[14:56:14] Passkey found
[14:56:14] - Will indicate memory of 12279 MB
[14:56:14] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 12, Stepping: 2
[14:56:14] - Connecting to assignment server
[14:56:14] Connecting to http://assign.stanford.edu:8080/
[14:56:15] Posted data.
[14:56:15] Initial: 40AB; - Successful: assigned to (171.64.65.54).
[14:56:15] + News From Folding@Home: Welcome to Folding@Home
[14:56:15] Loaded queue successfully.
[14:56:15] Sent data
[14:56:15] Connecting to http://171.64.65.54:8080/
[14:56:16] Initial: 0000; - Receiving payload (expected size: 1765772)
[14:56:19] - Downloaded at ~574 kB/s
[14:56:19] - Averaged speed for that direction ~504 kB/s
[14:56:19] + Received work.
[14:56:19] Trying to send all finished work units
[14:56:19] + No unsent completed units remaining.
[14:56:19] + Closed connections
[14:56:19]
[14:56:19] + Processing work unit
[14:56:19] Core required: FahCore_a3.exe
[14:56:19] Core found.
[14:56:19] Working on queue slot 01 [October 5 14:56:19 UTC]
[14:56:19] + Working ...
[14:56:19] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 01 -np 19 -checkpoint 15 -verbose -lifeline 5836 -version 630'
[14:56:19]
[14:56:19] *------------------------------*
[14:56:19] Folding@Home Gromacs SMP Core
[14:56:19] Version 2.22 (Mar 12, 2010)
[14:56:19]
[14:56:19] Preparing to commence simulation
[14:56:19] - Looking at optimizations...
[14:56:19] - Created dyn
[14:56:19] - Files status OK
[14:56:19] - Expanded 1765260 -> 2254597 (decompressed 127.7 percent)
[14:56:19] Called DecompressByteArray: compressed_data_size=1765260 data_size=2254597, decompressed_data_size=2254597 diff=0
[14:56:19] - Digital signature verified
[14:56:19]
[14:56:19] Project: 6075 (Run 0, Clone 142, Gen 157)
[14:56:19]
[14:56:19] Assembly optimizations on if available.
[14:56:19] Entering M.D.
[14:56:25] mdrun returned 255
[14:56:25] Going to send back what have done -- stepsTotalG=500000
[14:56:25] Work fraction=0.0000 steps=500000.
[14:56:29] logfile size=0 infoLength=0 edr=0 trr=25
[14:56:29] logfile size: 0 info=0 bed=0 hdr=25
[14:56:29] - Writing 642 bytes of core data to disk...
[14:56:29]   ... Done.
[14:56:29]
[14:56:29] Folding@home Core Shutdown: EARLY_UNIT_END
[14:56:33] CoreStatus = 72 (114)
[14:56:33] Sending work to server
[14:56:33] Project: 6075 (Run 0, Clone 142, Gen 157)
[14:56:33] + Attempting to send results [October 5 14:56:33 UTC]
[14:56:33] - Reading file work/wuresults_01.dat from core
[14:56:33]   (Read 642 bytes from disk)
[14:56:33] Connecting to http://171.64.65.54:8080/
[14:56:34] Posted data.
[14:56:34] Initial: 0000; - Uploaded at ~1 kB/s
[14:56:34] - Averaged speed for that direction ~32 kB/s
[14:56:34] + Results successfully sent
[14:56:34] Thank you for your contribution to Folding@Home.
[14:56:38] Trying to send all finished work units
[14:56:38] + No unsent completed units remaining.
[14:56:38] - Preparing to get new work unit...
[14:56:38] Cleaning up work directory
[14:56:38] + Attempting to get work packet
[14:56:38] Passkey found
[14:56:38] - Will indicate memory of 12279 MB
[14:56:38] - Connecting to assignment server
[14:56:38] Connecting to http://assign.stanford.edu:8080/
[14:56:38] Posted data.
[14:56:38] Initial: 40AB; - Successful: assigned to (171.64.65.54).
[14:56:38] + News From Folding@Home: Welcome to Folding@Home
[14:56:38] Loaded queue successfully.
[14:56:38] Sent data
[14:56:38] Connecting to http://171.64.65.54:8080/
[14:56:39] Posted data.
[14:56:39] Initial: 0000; - Receiving payload (expected size: 1764849)
[14:56:42] - Downloaded at ~574 kB/s
[14:56:42] - Averaged speed for that direction ~518 kB/s
[14:56:42] + Received work.
[14:56:42] Trying to send all finished work units
[14:56:42] + No unsent completed units remaining.
[14:56:42] + Closed connections
[14:56:47]
[14:56:47] + Processing work unit
[14:56:47] Core required: FahCore_a3.exe
[14:56:47] Core found.
[14:56:47] Working on queue slot 02 [October 5 14:56:47 UTC]
[14:56:47] + Working ...
[14:56:47] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 02 -np 19 -checkpoint 15 -verbose -lifeline 5836 -version 630'
[14:56:47]
[14:56:47] *------------------------------*
[14:56:47] Folding@Home Gromacs SMP Core
[14:56:47] Version 2.22 (Mar 12, 2010)
[14:56:47]
[14:56:47] Preparing to commence simulation
[14:56:47] - Looking at optimizations...
[14:56:47] - Created dyn
[14:56:47] - Files status OK
[14:56:48] - Expanded 1764337 -> 2253505 (decompressed 127.7 percent)
[14:56:48] Called DecompressByteArray: compressed_data_size=1764337 data_size=2253505, decompressed_data_size=2253505 diff=0
[14:56:48] - Digital signature verified
[14:56:48]
[14:56:48] Project: 6050 (Run 0, Clone 170, Gen 208)
[14:57:17] Project: 6057 (Run 0, Clone 10, Gen 175)
[14:57:46] Project: 6062 (Run 0, Clone 194, Gen 74)
[14:58:16] Project: 6067 (Run 1, Clone 177, Gen 47)
[14:58:45] Project: 6023 (Run 0, Clone 61, Gen 314)
[14:59:13] Project: 6024 (Run 0, Clone 55, Gen 283)
[14:59:42] Project: 6053 (Run 1, Clone 101, Gen 45)
[15:00:11] Project: 6060 (Run 0, Clone 79, Gen 169)
[15:00:41] Project: 6065 (Run 0, Clone 39, Gen 148)
[15:01:10] Project: 6056 (Run 1, Clone 2, Gen 32)
[15:01:39] Project: 6057 (Run 0, Clone 109, Gen 44)
[15:02:08] Project: 6061 (Run 0, Clone 178, Gen 186)
[15:02:37] Project: 6070 (Run 0, Clone 172, Gen 117)
[15:03:06] Project: 6024 (Run 0, Clone 110, Gen 289)
[15:03:47] Project: 6040 (Run 0, Clone 186, Gen 70)
[15:04:15] Project: 6052 (Run 0, Clone 90, Gen 68)
[15:04:47] Project: 6053 (Run 1, Clone 179, Gen 57)
[15:05:16] Project: 6072 (Run 1, Clone 18, Gen 39)
[15:05:48] Project: 6059 (Run 0, Clone 197, Gen 64)
[15:06:17] Project: 6060 (Run 1, Clone 40, Gen 45)
[15:06:47] Project: 6063 (Run 0, Clone 90, Gen 145)
[15:07:16] Project: 6074 (Run 0, Clone 5, Gen 183)
[15:07:45] Project: 6023 (Run 1, Clone 109, Gen 296)
[15:08:14] Project: 6052 (Run 0, Clone 99, Gen 109)
[15:08:55] Project: 6041 (Run 0, Clone 196, Gen 51)
[15:09:23] Project: 6071 (Run 0, Clone 145, Gen 83)
[15:09:52] Project: 6055 (Run 1, Clone 30, Gen 29)
[15:10:21] Project: 6060 (Run 1, Clone 26, Gen 43)
[16:07:45]
[16:07:45] Project: 2686 (Run 1, Clone 9, Gen 28)
[16:07:45]
[16:07:46] Assembly optimizations on if available.
[16:07:46] Entering M.D.
[16:07:54] Completed 0 out of 250000 steps  (0%)
Dude, please stop testing we need [H]ard stability right now. :p
it might have actually been more than 75.......
I turned in 150 WUs last update
I think its for every SMP(bonus) workunit you've turned in under your passkey. If my math is right, that'd be 375.
Sorry wasn't clear, but 375 SMP work units. 20% of that(failures) would be the 75 WU that EUE'd on you.
If you've done more than 375 WU, you're probably ok. I'm guessing you've done quite a bit more than that.
Probably, with one bigadv rig and two or three smp rigs running.
However, if the number is closer to 150, my threshold to stay above 80% is closer to 750 WUs. That might be pushing it.
If I were you I'd run a few days with standard WUs just to keep my averages up even if I didn't drop below the 80% threshold. That's a ton EUEs man! :eek:
Yup, can't run -smp X with X as a prime number. That'll instant-EUE non-bigadv SMP units.
This is not true, and I am not exactly sure where it comes from. 2, 3 and 5 (and I believe 7) are primes, and work fine. 15 and 22 (and probably 21) are not primes and causes the same issue. So there is more to this mystery than just being or not being a prime number.
it works with 20.
i'm going to try 18 now, but I'm afraid
I'd stick to regular SMPs and monitor EOC to see if you are still getting the bonus, then go from there
Did Stanford ever clarify where the 80% comes from?
It still isn't a prime numbers thing. Ask jebo how well -smp 15 works....
Love how you are getting jerked around on FF jebo....
its par for the course over there
7im's PMS, Bruce's unwavering inflexibility. I usually just try to tread water long enough for Kasson to notice.
Judging by my stats so far I can't figure out if I'm getting bonus points or not.
I typed my passkey into the stats page at stanford.edu and it says i've turned in 1523 WUs under this passkey, so I have my fingers crossed that I'll be ok.
I'm going to drop a bigadv in about 12 hours, so I'll know for sure by then.
