$700 Gaming Desktop
Gaming.
700 USD maximum, tax and shipping included.
3) Where do you live?
California, USA.
Case, PSU, motherboard, CPU & heatsink, GPU, memory, HDD, CD/DVD-RW drive
USB 2.0 keyboard. USB 2.0 mouse. Sennheiser HD280 Pro headphones
:cool:
6) Will you be overclocking?
No.
I already have a Sceptre X270W-1080P (27").
As soon as I get some opinions and advice.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
USB 3.0 and SATA 6Gb/s.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
No.
XFX ATI Radeon HD 5670 1 GB DDR5
AMD Phenom II X4 840 Edition Deneb 3.2 GHz
Cooler Master CM 690 II Advance ATX Mid-Tower Case
Samsung 1 TB Spinpoint 7200 RPM 32MB Cache
Cooler Master eXtreme Power Series 460W Power Supply
ASUS M4A87TD EVO Motherboard
Cooler Master Hyper 212 Plus Universal Direct Contact Heat-Pipe 120mm Fan CPU Cooler
Windows 7 Home Premium 64 Bit System Builder
ASUS Black 18X DVD-ROM 48X CD-ROM
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
All told, including tax & shipping:
698.55 USD
Thoughts?
You'll need a better video card than that Radeon HD 5670. Also, the power supply needs to be changed
That PSU is a piece of shit. For $5 more, you can get a PSU that's of significantly better quality:
$45 - Antec Earthwatts Green EA-430D 430W PSU
Go for this DVD burner since that DVD ROM drive is completely overpriced:
http://www.amazon.com/Liteon-24X-DV...DWLK/ref=sr_1_5?ie=UTF8&qid=1300499465&sr=8-5
Since you're not overclocking, zero reason to get that DDR3 1600 RAM. So save yourself $15 and get this RAM set:
$40 - Patriot PSD32G13332 2GB DDR3 1333 RAM
Also, since you're not overclocking, you really don't need that Coolermaster HSF. Unless it gets ridiculously hot where you are or if you're extremely sensitive to noise. Otherwise stick with the stock HSF.
That HD 5670 1GB card is overpriced. Not to mention way too slow for your resolution. For $35 more, you can get a significant boost in performance:
$135 - XFX HD-577A-ZNFC Radeon HD 5770 1GB PCI-E Video Card
CPU wise, that "Phenom II X4 840 CPU" is essentially a fake Phenom II CPU due to the fact that it lacks an L3 cache. It's basically a higher clocked Athlon II X4 CPU. So due to your budget, you might be better off just saving $10 and going with an actual Athlon II X4 CPU:
$100 - AMD Athlon II X4 640 CPU
ach, I got within a cosmic mole of Danny's awesomeness, I'll be happy with that!! -.-
Go with this. But, upgrade the PSU to the Antec EA650 for $70. This should give you more headroom down the road.
Stick with the ASUS Mobo you selected for $100 and the 1TB Samsung drive for $60. But, drop the cpu heatsink.
Cases, you can consider the one that Jeremyshaw listed for $50 on NewEgg. You pay tax but, it's only $5. Or, Consider the Coolermaster Elite 330 for $53.49 w/free shipping from Amazon. Or, the Coolermaster Elite 430 for $50 w/free shipping $10 MIR
Total on all of this would be around $683.00
