"way faster" That's quite arguable. An increase? Possibly but definitely not "way" faster.Another difference is with the speed of using 64-bit values in programs. Take the same exact program that uses 64-bit values, compile it for both 32-bit and 64-bit use, and the one running in 64-bit will be way faster in the areas it uses the 64-bit values... if it is coded properly that is.
Anyways, a lot of native 64 bit apps I don't believe benefit much from 'being' 64 bit compared to their 32 bit counterparts. Simply compiling it as 64 bit and actually using true 64 bit word value programming (using the entire 64 integer as code rather than zeros) in the coding are completely different. You could have a 32 bit word value with 32 zeros and be 64 bit and there won't be any benefit to performance.
Anyways, OP, 64-bit OSes are used to allow over 4GB of ram as the second poster suggested. With a modern computer and GPU you're going to have over 4GB of ram, especially with SLI and CrossFireX.
I doubt you're going to notice any difference with a CPU that old. As for advantages of 64bit OSes / processors, the main one these days is the ability to address more RAM. A 32bit OS can only handle around 4GB of addressable memory -- that being RAM, GPU memory, soundcard memory, and addresses allocated by the motherboard components themselves (NB/SB, etc). This leads to as little as 3GB of RAM being usable. A 64bit OS can handle a lot more than that; namely, 16 Terrabytes in current 64bit versions of Windows (and a far larger amount possible).
Machines with 4, 6, or even 12GB are not uncommon today, and more RAM is a given in the future. That, and operations with large data sets like un-RARing/un-ZIPing are a good bit faster.
I look forward to the day that all software is finally caught up, although somehow I get the feeling they will always be behind![]()
By then, we'll have x86(?) 128bit architecture floating around![]()
Pentium Pros could address a max of 64GB of memory in 1995, This is a limitation of the OS only because the OS limited it, not because the OS is 32bit.
That has nothing to do with the OS, and everything to do with the formatting of the hard drive.In the same step, you can also have file sizes larger then 4GB (on the harddrive, not memory).
This was an issue I ran into where I wanted to store "dd" images of harddrives as one single file. Had to get a 64 bit Linux OS.
for such an old processor I'd suggest upgrading both cpu, system and to W7 x64. Practical benefits are more memory as stated, but even more importantly the system is more resistant to viruses and trojans. For example I enjoying seeing pop-under windows that come up blank. As for the whole "properly coded" thingy, I believe the x64 instruction set is available to all 32 bit apps, just not the memory addressing.
address space has nothing to do with cpu being 32 or 64bit even the old 8086s could address 1Mbyte (up 16 if you decoded the status pins) and they were 16bit processors. The maximum address space for a 32bit value is 4GB f you do not use software tricks like PAE
