Web browsing and general gaming.
$600-$630 total (including shipping and tax).
3) Where do you live?
Utah. So, Newegg or Amazon. Have Amazon Prime.
Motherboard, GPU, RAM, optical drive, CPU, HDD, case, and a monitor. Basically everything but a PSU -- I have a new OCZ 600W StealthXStream 2 I can use for this build.
Power supply: OCZ 600W StealthXStream 2.
6) Will you be overclocking?
If the hardware supports it, yes.
Around 22"-24" would be nice.
Immediately.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
None of these features are needed. Basic will work at this budget.
Yes. I have a Windows 7 64-bit license I can use.
Thank you in advance. You guys have helped me in the past and I've been very satisfied with the results. Your help is greatly appreciated.
The computer this is replacing has an AMD Athlon X2 2.8GHz, 2 GB of RAM, and a dead nVidia 9800 GT. I would like to exceed the performance of this computer if possible.
Immediately.
