It does. Those 6+2Pins and 6Pins the OP is talking are PCI-E connections.
i know that but if he is going to get 4 4870's then he will need 8 pci-e power cables
so i need 8 6pins then or just four?
You can also go PC Power & Cooling. I don't know what connectors they have stock, but they will do the wiring however you like if you order from them.
that would only support two cards
the 4850 should come with a molex to pcie adapter
