5V line running at 4.1V
jinx083464
My 1000w ultra X3 PSU was reading at 4.1volts on the 5V line, the 12v and 3.3v were not too far off though. I only realized this after my computer couldn't access my hard drives any more. I thought the problem was with the hard drives at first until I swapped them into other computers and they ran fine. I don't even know if the hard drives run off the 5v line but I was wondering if this is the obvious cause or not. If so should I expect any damage to my other hardware if my PSU has been off by such a large % for extended periods of time?
I have had a lot of problems with my computer of the past month or two, and I'm thinking the problems are from the PSU and or the mobo. I'll list off a few of the problems
- screen will flash black sometimes, through process of elimination I have determined that its not caused by software/drivers, the GPU, monitor, BIOS.
- mic stops picking up sound sometimes, usually triggered after coming out of sleep mode, or just not functioning when I start the computer up. If I boot windows and it works, as long as I don't go into sleep mode then its reliable.
- Hard drives not booting.
- Computer seems to lock up whenever it needs to access hard drive or cd drive making simple processes take literally 10x longer than they normally do. This problem is intermittent. When it has the problem it has it constantly, and when the problem goes away everything runs smooth.
- starting just today when booting up my system I got a "Bad or Missing command Interpreter. Enter the full shell command line: Command.com /P /E:256" message
Hard drives do run off the 5v line, as well as USB and some PCI devices. It should be between 4.75v and 5.25v to be considered good. So if it's running at 4.1v (~15% outside of spec) then you will get random errors whenever you try to use the devices that work off that rail.
Couple things... Does the failure for the drives to boot have after the screen blank? If so, I had the same problem and fixed it. Also how are you measuring that 4.1V? You really gotta check that with a multimeter to see what the power supply is putting out on that rail.
Posting out your specs might help too...
I'm fairly comfortable saying your PSU is fine. IIRC, more than just your drives run off the 5V rail (like USB), so hard drives wouldn't be the only problem.
Let me add to that- I'm guessing you have an Asus motherboard, and the 4.1V reading is coming from the bundled monitoring software? If so, ignore it- it's crap.
motherboard: Asus P5N-D
CPU: intel core 2 duo E8400
GPU: KFA2 9600GT running in SLI
RAM: 2 X 2 gig sticks of ddr800
PSU: Ultra X3 1000w
Ryan_975 says the USB runs off the 5v rail as well, I have not had an issue with my USB devices.
The repeating black screen seems to have no connection to hard drive problems, either one of these probems does not seem to trigger the other problem to occur or stop occurring.
Mavalpha would be right, it is a ASUS board, and I recently have installed the software bundled with the mobo called PCprobe 2, it will read my voltage levels, fan speeds and a few temperature readings. I installed it after I had swapped out my suspect power supply for my old one, so I got the 4.1v reading from my BIOS and not a multimeter.
There is not a piece of software around that will accurately read your system voltages - same for the BIOS readings. They are distant approximations at best and should not be trusted.
Break out a digital multimeter and measure.
Take your multimeter and a standard 4-pin molex connector from your PSU. The 'probes' that come with most multimeters just happen to fit perfectly in the female connection pins of a 4-pin molex connector... so plug the negative lead of your multimeter into one of the two black wires (makes no difference which) and take the positive lead and plug it into the RED wire connector on the molex cable. Set the multimeter to read DC voltage in the 12V range and then power on your PC. You should get an accurate reading of the actual voltage your PSU is putting out on the +5 rail.
Move that positive lead from the multimeter to the YELLOW wire connector and you'll get a reading of the +12 rail.
If your PSU has multiple +12v rails you can usually identify each one by a different colored 'stripe' on the yellow wire.
I didn't have a multimeter lying around so I went out and purchased a cheap one. Turns out that it wont work on the PSU because the psu puts out too much current for the multimeter I got to handle.
I ended up buying a new motherboard, and unfortunately It did not solve the problem, so I went out and got a new power supply as well and it that fixed the problem.
Your psu wattage has nothing to do with it. You need to set the DMM (assuming you bought a digital one) to measure DC if it's an auto ranging or 20V DC if it's manual. Sears and Radio Shack sell some for <$20
