its silly to run 5870 crossfire at that low res. not only is the performance overkill you will have tons of extra cpu overhead dealing with crossfire at such a low res. that means you will never get all the performance a 5870 crossfire setup is even capable of anyway. just get a fast single gpu and then upgrade when necessary. personally I don't see the point in having a high end gaming machine to play games on a tiny 19 inch monitor in the first place.
future proofing by going overkill on gpus is silly. just buy what you need for the resolution you plan to game at and then upgrade when necessary. by the time you need to upgrade there will be faster cards with newer features for less money.
yep a single 5870 is still VERY strong at 1920x1080. a single 5870 at just 1440x900 will tear through games with room to spare.
IMO yesWow this thread is making me laugh! Forum contributors pulling one way and then the other xD
Let's get down to bare bones here. If what GORANKAR says is true, then I should be set with a single 5870 2GB and just save up for a new monitor and next gen GPU combo in the future, yes?
Yes. However if your sig is up to date, I highly recommend getting a new PSU: Coolermaster doesn't brand a single good quality 500W PSU. As such, you will definitely increase the chances of system instability or straight hardware death with such a crappy PSU. Something like these should be fine:Let's get down to bare bones here. If what GORANKAR says is true, then I should be set with a single 5870 2GB and just save up for a new monitor and next gen GPU combo in the future, yes?
who cares about the min framerate in a fly through benchmark? no matter what system you have it will dip down in the type of benchmark. play the REAL games and you will see your performance is just fine. and stop staring at the framerates, praying it does not dip below 60fps and you will likely enjoy your game much more.This statement is not as correct as many think. Just got a second 6870 for myself and installed it today. Still can't max out Metro 2033 and get a minimum frame rate of greater than 15fps in the benchmark (avg 77fps though). Also can't average 60fps in Lost Planet 2 benchmark (53fps avg). Sure, these are benchmarks that push things beyond what the game itself normally demands, but these are 2 solid examples with many to follow as DX11 is adopted by more devs.
Also currently running 1440x900, a 1920x1080 monitor is in my sights for Black Friday.
$70 - Antec NEO ECO 620C 620W PSU
$70 - Antec High Current Gamer Series HCG-620 620W PSU
No worries, I am upgrading my PSU before I even install the new 5870. I'm looking towards an XFX XXX Edition semi modular 80 Silver 750watt to handle all my power needs for a little while for just 40 bucks more.
I am planning on running two 5870's with 2GB of DDR5 apiece under a 1440x900 resolution and with a 4.0ghz cpu. How long do you guys think this setup would last under the weight of new games before I have to look into getting better GPU's?
Dude at the resolution you're fine with your 5870. Your system is really designed for a 1920x1200 resolution to be honest. The only big question is Battlefield 3. Most of the people in the Alpha are saying their FPS is great with their last generation hardware. But it is an ALPHA. So they could have disabled advanced options and such. But it runs great for their system. My advice is wait for the hardware to be actually "slow" before you upgrade. I was about to get a 6990+6970 combo this year. But I waited and my "old" 5970 is handling everything just fine at 1920x1200. If this system can handle retail Battle Field 3 fine at 1920x1200, there will be no reason for me to upgrade. But knowing me, I will probabl be getting a southern island this christmasSeeing how I waited for the 6990 and could have purchased it before the insane prices you see today. Makes me want to buy it at day one
I have a single 5870, and it runs everything fine at 1920x1200. It even copes decently with a lot of games in Eyefinity 5760x1200. I don't think you need a second card, especially not at 1440x900. Better to save that money for a new single high-end card when the next generation hits.
