first of all, you need a monitor that get to 144Hz![]()
IPS display?
Need bigger monitors than 24' for it to be really impressive IMO.![]()
all the gpu power in the world will not maintain 144 fps in many games. its laughable how many games are cpu limited for one reason or another well before that point.
TN.
If you can find a 144Hz IPS display, my hat's off to you. I think I would still prefer the TN though.
You would? Why?
Because chances are a 144Hz "IPS" is a scam panel.
144fps is smoother than 120fps, which is smoother than 90, which is smoother than 60
less visual lag/more precise control of your aim (you're seeing more frames between cursor movement, giving you higher aim precision)
watching a friend of mine play BF4 on his 120hz made me super jelly, even with it being TN
Yeah, but why 144 and not 150 or 180 or 143 or 145?
After about 100 fps i cant see any smoother, even on a 120Hz screen. and 100fps is only when im spinning around with 110 fov, otherwise my vision seems to cap out at 85.
my ping never seems to drop below 30ms, i couldnt use the extra precision even if i wanted to.![]()
Errrr, no. Not at all. Have you followed monitor news at all the past year or more? Originally there were a good number of Catleaps/overlords doing 120hz+ IPS oc's for a very long time, now for ~8+ months the new favored panel is a samsung PLS present in Qnix/X-Star models that oc very well for $300/less shipped, glossy or semi-gloss matte.
