such hyperbole lol...love it.
Its an issue for everyone who relies on overriding fan curves for OC for cooling and also to lower noise levels. JayzTwoCents mentioned in a video about those that have GPUs in a waterloop.Like I said before I actually love this bug as it has flat-lined my voltage/clock curve by completely disabling the auto-throttling feature.
It has improved my stability, not made it worse. It's like how things were pre-10 series.
I understand how it could be an issue for normies though (re: overheating GPUs).
edit: Worth mentioning his clocks went from 2400 to 2900 in Furmark.
Nice!Hotfix 576.15.
Fixes sensor and idle clocks.
https://www.reddit.com/r/nvidia/comments/1k4kkx8/geforce_hotfix_display_driver_version_57615/
- [RTX 50 series] Some games may display shadow flicker/corruption after updating to GRD 576.02 [5231537]
- Lumion 2024 crashes on GeForce RTX 50 series graphics card when entering render mode [5232345]
- GPU monitoring utilities may stop reporting the GPU temperature after PC wakes from sleep [5231307]
- [RTX 50 series] Some games may crash while compiling shaders after updating to GRD 576.02 [5230492]
- [GeForce RTX 50 series notebook] Resume from Modern Standy can result in black screen [5204385]
- [RTX 50 series] SteamVR may display random V-SYNC micro-stutters when using multiple displays [5152246]
- [RTX 50 series] Lower idle GPU clock speeds after updating to GRD 576.02 [5232414]
they can just flag that driver as invalid.You know what's funny, people are going to use 572.06 to "cheat" in 3dmark forever.
Hotfix 576.15.
So far this driver (576.15) fixed all the issues I was having including the white flashing on my desktop when HDR was enabled.Hotfix 576.15.
These hotfix drivers are the first ones in months that didn't leave me with a blank screen after install. Pretty much every driver install this year has required me to hard reset my machine. No amount of swapping inputs, toggling HDR, plugging/unplugging would bring it back - powering it off was the only way. Sometimes I even had to reinstall. That's on a 4090. Random occasional flashing textures in Dragon Age Veilguard also seem to be gone. Hopefully they're starting to get a handle on these things. My issues have been minor compared to some, but that's after years of bulletproof drivers.
This might be 5000 series only affected by temperature sensor issue. I am running 4090 and Afterburner shows correct temps.That comes at a cost it seems. Unwinder (creator of MSI Afterburner) posted about this on reddit:
https://www.reddit.com/r/nvidia/com...utm_medium=web3x&utm_name=web3xcss&utm_term=1
https://forums.guru3d.com/threads/n...l-driver-download.456063/page-12#post-6326425
I am staying clear of those drivers, since it would be on a "4070" laptop I also use for work. Dont want to cook it.![]()
I never saw it with my 3 50 series cards. I think you have to use sleep which most enthusiasts don’t use lol.This might be 5000 series only affected by temperature sensor issue. I am running 4090 and Afterburner shows correct temps.
try the new oneDang after 3 nights of stable gaming - got a Fortnite crash with this driver. It’s far more stable but I would not say this is “fixed” - RTX 5080.
It’s crazy - I can’t ever recall a single crash across all my cards in the 40 series with Fortnite.
Definitely will now! Didn’t want to mess with anything when I was crash less - but now that I’ve been messed with it’s on. Hehtry the new one
I think most of the performance gains people reported were due to the boost algorithm working more aggressively due to to wrongly reported "low" temps. So yeah with sensors working properly you'll have lower performance.new hotfix 576.15 are quite a bit slower than the latest WHQL for me
Did you ever DDU?These hotfix drivers are the first ones in months that didn't leave me with a blank screen after install. Pretty much every driver install this year has required me to hard reset my machine. No amount of swapping inputs, toggling HDR, plugging/unplugging would bring it back - powering it off was the only way. Sometimes I even had to reinstall. That's on a 4090. Random occasional flashing textures in Dragon Age Veilguard also seem to be gone. Hopefully they're starting to get a handle on these things. My issues have been minor compared to some, but that's after years of bulletproof drivers.
My boost algorithm and sensors worked as advertised. It was boosting higher because of lower power consumption (thereby lower heat at same boost). This is same thing I have noticed in games as well.I think most of the performance gains people reported were due to the boost algorithm working more aggressively due to to wrongly reported "low" temps. So yeah with with sensors working properly you'll have lower performance.
Did you ever DDU?
my temps went upI think most of the performance gains people reported were due to the boost algorithm working more aggressively due to to wrongly reported "low" temps. So yeah with sensors working properly you'll have lower performance.
Yeah looks like there was some sensor issues with the last patch which is why the hotfix was sent out.my temps went up
hit 80C for the first time with them
Yeah. I think the general sentiment is those engineers are working on AI stuff and not gaming stuff. We get the cowboy interns.Yeah looks like there was some sensor issues with the last patch which is why the hotfix was sent out.
Boy, Nvidia just cant catch a break when it comes to their drivers. Its been what 4 months now with bad 5000 series drivers. Nvidia should take some of those billions they have on cash and make a good GPU driver department!
That's a good point! Thanks!In Fortnite it's probably because it will take time to recompile all the shaders again. The stutters will go away if you stick with one driver version for long enough.
then stick with the old ones i guessMadVR video renderer playback is broken as well on Win11 24H2 with 576.15 hotfix drivers. Press Ctrl + J and check top line "display" Hz, which should stay about the same when G-Sync is disabled, but after 5 minutes or so those stats start fluctuating (even through actual Hz don't) +/- 5-8 Hz . That results in presentation glitches accumulating into 100's... This is nuts. NVidia sends a strong message "We say NO to gaming AND to video playback".
FYI, it is NOT cool for forums to display which users have 2FA enabled. That's just as bad as posting someone's password length...
No issues on my 4090.nofix
NfinityBL
1h ago
Can confirm I am still getting black screen on one display on my 5080 with the new driver. Had hoped this would fix it but really not sure if its a me problem at this point.
Eglaerinion
42m ago
Black screen during install. Great. Luckily a restart fixed it.
u/Gigaguy777 avatar
Gigaguy777
2h ago
Still getting the crazy flickering and horizontal movement with static back and forth when trying to set my monitor to 160hz again, already tried DDU, using a DP80 cable, swapping to HDMI, toggling monitor OC off and on and changing PCIE gen in BIOS. Here's hoping the next driver fixes it.
kondorarpi
11m ago
I have still 0.5 sec black screen / signal cut when i start or close a game with with a 240 hz Display.
