5700 work with Afterburner/Riva Tuner
lightsout
I read a while ago that this combo doesn't work. Is this still the case. It seems like
whenever I am forced to use something besides AB I have a bad experience.
Also would like to use Riva OSD so I can stare at the numbers while I game :)
kirbyrj
It works with afterburner as long as you have the most recent version. I'm running 4.6.2 beta 2, and it doesn't have any issues.
Don't know about Riva OSD though. Never tried it.
lightsout
Thanks, anyone using Riva?
viivo
Do you mean RTSS? It works fine on its own as a frame limiter, or along with Afterburner which is required for the OSD.
lightsout
Yes that's what I meant. I had read earlier that it didn't work with Rx 57xx cards. Glad to hear that it does now. Thank you.
oldmanbal
afterburner was giving me issues in some game with stuttering so I disabled it. Just using the built in amd softwear in catalyst now.
lightsout
My card doesn't come in until Friday. I'll update everything and check it out then. If I can just use what I am used to I would prefer it.
oldmanbal
Yeah, that was my issue, I didn't have afterburner updated for like 2 years XD. I'll prolly go back to it, it's been my go to for years, and I always use RTSS for frame caps.
oldmanbal
Just keep an eye out for games that hate overlays and will have negative performance / crashing with it enabled.
