~$500 wow build
cicatriz63
Hey guys im lookin for some advice on a gaming build for a buddy.
Its mostly gonna be used for playing wow along with normal day to day browsing.
He is looking to spend about 500-600 on it.
What he needs:
Case, PSU, CPU, mobo, ram, hdd, video card
reusing 1920x1080 monitor, keyboard/mouse, dvd drive
do not have a windows license will be going with win7 x64 so thats $100 off the bat so id like to keep it around 500 for the hardware.
as far as hardware goes im thinking its going to have to be an AMD to stay within budget, but i have absolutely no experience with AMD cpus at all.
as far as parts go im thinking it will probably be a radeon 5770, antec 520c psu, 4gb of ram, and a 500gb hdd.
hopin to get some advice on some cpu/mobo combos that will be good for wow. thanks in advance!
forgot a few things, will be ordering within the next 2 weeks, live in PA prefer to order everything from newegg.
Tehre is a sticky at the top of the forum that would make helping alot easier
Just answer these last three questions and we can start helping:
6) Will you be overclocking?
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? Multiple PCI-E x16 slots? etc.
sorry missed the OC part.
No, do not plan on overclocking.
Dont require anything special with the mobo, will be a single video card, single hdd so no raid, usb3 would be nice for a future standpoint but by no means required.
I recommend this mobo over mikeroq's setup:
$152 - AMD Athlon II X3 445 CPU + Biostar TA890GXB HD AMD 890GX mATX MOtherboard
$41 - G.Skill Ripjaw Series F3-10666CL9S-4GBRL 4GB DDR3 1333 RAM
$120 - PowerColor AX5770 1GBD5-H Radeon HD 5770 1GB PCI-E Video Card
$65 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
$64 - Antec NEO ECO 520C 520W PSU
$50 - Cooler Master Elite 430 RC-430-KWN1 ATX Case
Total: $492 shipped
Key advantages over mikeroq's build:
- Faster video card
- Better PSU
- Longer warranty on the motherboard (3 years VS 1 one year on that Biostar)
- Faster hard drive
Try this..
130 AMD Athlon II X3 450 Rana 3.2GHz + BIOSTAR A880G+ AM3 AMD 880G HDMI Micro ATX
40 G.SKILL Value Series 4GB 240-Pin DDR3 SDRAM DDR3 1333
40 COOLER MASTER Elite 341
60 Antec NEO ECO 520C 520W
50 SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM
180 XFX HD-685X-ZNFC Radeon HD 6850 1GB
516.70 Shipped..
Edit: Didnt see danny's before I posted, but its solid also.. Bigger HDD then mine, & about 24 bucks cheaper.. But the extra power of the 6850 is worth the 24 bucks for sure if the HDD difference doesn't matter.
how does this mobo compare to the one danny linked?
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.592418
the only difference i can see is the one danny linked has sata 6gbs and this one doesnt, and the onboard is better but there will be a dedicated gpu anyways. but that combo has the slightly faster cpu and is slightly cheaper.
i think i can go without the sata 6gbs and slower onboard if thats the only major difference.
thanks again!
thanks again!
Other big difference is the number of ram slots. But starting with a single 4gb stock that's not an issue.
Posted via Mobile Device
don't they both have 4 ram slots? would probably go with 2 2gb sticks for dual channel and its about the same price as 1 4gb stick
They do. You pretty much listed all the differences
I wouldn't recommend it since it would limit your RAM upgrade path. Plus Dual channel only provides a 5% performance increase under the most ideal of conditions.
Oops on my phone and I thought he linked the same combo I did which only has 2 slots.
Try this..
516.70 Shipped..
im a little confused as to why you would recommend a 6850, an on board card or at the very least a super cheap discrete gpu would get the job done for a lot less money. the guy isnt looking to play games, he wants this pc or business, those extra coins should be spent on cpu, ram, or HDDs, imo.
You're looking at the wrong thread or you didn't read. Look at the title of the thread and the second sentence of the OP.
wow.. you would think that the title being "~$500 wow build" would have given some clue that maybe the OP wanted to play wow. But yeah.. What Danny Said.
