5 grand on gaming pc
Eshelmen
Yeah i got about 5 or 6 grand to play around with..
so as u can see my shite computer on my sig is preety much worthless now adays with all these advanced games like fear,oblivion, etc...
so i want of course sli
nvidia graphics
amd of course
and asus mboard
i think i need a new case anywaysa
and can any one recommend a kickass 19 or 20 inch lcd monitor
thanks alot
oh btw 2 gigs ram minimum :D
My only question is why. After a day you won't notice the graphics difference and there are plenty of great things to do with 4k or you could invest it and it would be worth quite a lot in the fture. Just get something like:
DFI NF4 ultra-d
Opteron 165 and overclock it
Scythe Ninja with quiet fan
2G memory
74G raptor for OS and apps
2x300Gb sata drives for raid storage
ATI 1800xt (unlike nVidia it will do HDR and aa)
Antec Sonata II
Dell 20 inch monitor
Logitech speakers with digital input so you wont have to buy a sound card.
That should cost much less than 2 grand and it will perform close to a more expensive machine. Take the other 4 grand and find a girl to take out, go on vacation and save some money. It's summer. Enjoy it.
I think even if you threw on triple headed 24" LCDs, you would have a tough time spending 5 grand.
By the way, by limiting yourself to brand names, you will end up with inferior products.
wish I had that much expendable for my rig that I am going to build
Athlon 64 x2 4400+
2GB DDR400 RAM (2x 1GB sticks)
2x nvidia 7800GTX 256MB in SLI (not sure on manufacturer yet and will be one for now and the second sometime down the road)
SB Audigy2 ZS (using it from my current system)
2x200GB HDD in raid 0 for games and video rendering
2x300GB HDD in raid 1 for system partition and data
Asus A8N32-SLI Deluxe
AEGIA based Physx card (will be waiting for a new version with less bugs then the current ones)
that is what I am going to be doing and it will come in well below the 5 grand mark
as far as monitors go I currently have a BenQ 19 lcd that has been flawless for me not sure on others opinions on them, you could reasonably set it up with 2 19s though and still keep it well in your price range
BenQ FP93GX is one of the ones I have been looking at to replace my current one as it is a lower response rate and would work very well for gaming
With DX10 around the corner I'd get the most current socket and get a 7900gt or something like that then wait for DX10 cards to come out. 5-6g's is a lot to throw around on computer parts.
No way I'd get s939 with AM2 out. There just isn't a point. Get a SLI 590 board. A pair of 7900GTX's. A 30" Dell and an FX-62 and 2GB of some fast memory. It starts to add up to around 3-4 Grand with those kind of parts.
SilentScope said:
Too bad it isn't 64-bit.
Yes Conroe is 64bit. The Yonah cores out now for the mobile line is 64bit.
If you are buying now I would go AM2 processor, wait until after the 1st so there be a alot more to choose from. Get a Nforce 590 based motherboard. 2 gigs of some OCZ or XMS ram and I would personally got X1900XTX with a Zalman VF900, but if you want Nvidia the 7900GTX would be the choose. If you are playing at really high resolutions, you might want to go SLI or Crossfire. I would wait on a Ageia card until something actually utilizes it. Get a XFI soundcard.
SilentScope said:
Is the desktop line 64-bit?
Conroe is 64bit and will be out in July. Conroe is the Desktop line of the new processors.
Merom is 64bit and will be out in August. Merom is the Mobile line of the new processors.
Right now there Yonah and is out now. Its the mobile line of processors, and there is like one motherboard that supports it for a desktop
Then there are the Pentium 4's and you probably dont want one of those, so I wont go through all those cores as that is a lesson all by itself.
Well, if the OP can wait, he should go with the Conroe, but the AM2 is the best choice right now.
SilentScope said:
Well, if the OP can wait, he should go with the COnroe, but the AM2 is the best choice right now.
QFT. It all depends on how much he would be willing to wait. If he wanted to though, the Conroe ready motherboards should start popping out in June. He can get all the parts minus the Conroe processor then. Put in a cheap Intel 630 in it, and when the Conroe's hit the market, buy one.
Vista will be released at earliest january of 2007. So Around the corner is 7 months away.
Based on our last rig, i'd say your spending far too much. You'll save money and have greater enjoyment by spending 1-1.5k now and upgrading in 18-24 months. No matter how much you spend now yo'll barely notice a difference when going for the extreme top end in comparison to comparing it to a new processor/gph 18 months out. Spend hundreds going from a 3800+ to a 4600+ or go toa brand new generation of cpu's period.
454Casull said:
Spending $5000 on a gaming system is simply nonsense.
True but it also depends what you are spending it on. 1500-2000 should be the max spend on a computer. Then maybe about 500 for a monitor and 100 in mouse and keyboard. Then if you want a good sound system and build it yourself that can get pricey and maybe you would reach 5 grand. All depends on what you want to spend this 5 grand on.
5 grand for just a computer is ridicolous. Computers dont hold there value that long anymore and would depreciate in value so fast.
Well, it certainly makes sense to spend *enough* on speakers, since they hold their value the longest. If I had to choose between a great video card and great speakers, I would go for the speakers every single time.
nForce 590 Motherboard - $200
Intel Core 2 E6600 - $320
Scythe Ninja - $40
2GB of DDR2-667 - $150
Two 7900GTX - $1000
Antec P180 - $120
Lots of good 120mm fans - $40
PC P&C 510SLI - $200
DVD+RW - $40
150GB Raptor X - $350
750GB "Parallel Recording" Drive - $500
Dell 2407FPW - $800
Speakers - $100
Keyboard and Mouse - $50
Total - around $4k, way better than any AMD machine you can buy. Coming July, 2006.
i would get a 30" LCD or a projector.. you can't go wrong when ur playing HL2 on a 110" screen
I'd up the budget a little bit and get 2 Dell 30" screens and a nice 4G system..
yif you get dual 30" then thats already 4 grand and to get a 4 gb system you'll need
4 gb ram-400
motherboard-300
sli or cf to power the dual monitors-1000
case-100
psu-200
cpu-600
2,600 right there + 4 grand
a little over his budget. Build a 1500 $ pc right now and just upgrade it through out hte years. If you spend 1 grand one upgrading it each yeat it'll last you 3.5 years
Well i just thought for top of the line shit maybe i need 5 grand
I want like max out on everything
incredible graphics and sound for top of the line games like hl2,oblivion,cod2, etc...
I was looking at those dell monitors... those are quite nice
any speakers in mind ?
do i need 7.1 or stick to 2.1 or 5.1
Edit:
Also.. one monitor will do...
I thought about it guys.. your right 5 k is alot.. i even knew it but i just thought mayeb it`ll run for quite a while
i`ll save half of it for extra shit and some other stuff i need"Club Card" cough cough
and gas
5.1 sound is what you want. Game are hardly coded for 7.1. I would get a XFI soundcard. As for speakers, there are 2 options. Get yourself a nice Logitech 5.1 system or build a set but can get costly but will provide really good sound.
If I were you, I'd wait. The only reason I spent 3 grand was because the money would not be availible (invested and non-liquid) if I waited around for Conroe etc.
i don't get it.. people want a sick ass system, then they play it on a crappy monitor and/or speaker system...
I'll rather have a $1500 pc and have projector and decent home theater... CS players are almost life size on a projector
"No way I'd get s939 with AM2 out. There just isn't a point. Get a SLI 590 board. A pair of 7900GTX's. A 30" Dell and an FX-62 and 2GB of some fast memory. It starts to add up to around 3-4 Grand with those kind of parts."
So you'd spend extra money on your motherboard, ram and processor for no extra performance? Hardware companies must love you. You do realize that the announced AM2 processors are all coming out in 939 format. There will be a time to migrate to AM2, but that time really isn't now. There's no benefit.
There's no benefit to migrate... but neither is there benefit in buying obsolete hardware.
Better to buy into the present than the past though.
5 or 6 grand on a pc? all that is going to do is enlarge your e-penis dude, i say spend about 4 grand and save the other 2 for something else like a good tv or something like that
guys i have plenty of things... i need
5 or 6 grand isnt all i`m going to have...
i`m getting a 20k+ check for my ssi:)
i`m putting the other money towards bills and shit
this 4or 5 grand will be a treat for me...
its not a waste if spend it on good software and games...
along with the monitor being 30 inches if it is, will be my only tv in my room
so it will have to do
well then........i say fx-62, 4gb DDR2, some raptors, 7900gtx sli, solid gold case, 2 30in dells =P
Seriously..
I only mentioned that because that's my next setup. I have a 21" CRT (Sony F520R - best CRT on the planet when I bought it) next to my Samsung 19" LCD ( 2 years later- makes the CRT fan in me cry- speed, clarity, sharpness, contrast, everything is better by a huge margin)
Sums it up:
http://www.quepublishing.com/articles/article.asp?p=442343&rl=1
Dual screens is the only thing I will run now- it's what you look at, it's THE interface from the computer to you. And arguably, the other way around doesn't matter worth a shit, we can't react fast enough anyway to slow down the computer. It makes the difference between an acceptable machine and a phoenominal machine. I mean- an AMD and Intel machine side-by-side +/- $1000 will perform approximately imperceptably the same.
Set a system with an old 15" CRT next to the same one with 2 30" Dells and vid cards, and it's a life-changing experience.
