Peteman100
- Oct 7, 2007
Can't wait for that to hit the $99 price point. $100 is the max I pay for drives nowadays.
will wait to see the failure rate on these suckers.....
Am I too paranoid?
This is going to make the 10TB+ thread even less impressive. Hi, I have three HDDs! :-/
Why would home users need 4TB at all? As was mentioned, watch out for failure rate and putting too much unto these suckers. There have been debates over using 32GB flash cards in photography forums out of fear of loss, deletion, failure, etc. Is it still better to use 4 8gb cards instead of one 32GB? I would rather get 4 1TB external HDDs than 1 4TB internal.
I honestly would consider buying one if hard drives generally had a more reasonable life expectancy.
They do have a reasonable life expectancy of 5 to 7 years... I am seeing annual failure rates of > 1% to around 7% at work over the last 15 years of using 100 to 300 hard drives 24/7/365.
I find hard drives have become less reliable over the years. You hear a lot about DOAs and premature failures it's not even funny.
I have some <1GB drives (don't know why I keep these) and they STILL work if I plug them in. They are like 15 years old. They don't make stuff like they used to.
Every time the next bigger HDD is released, SOMEBODY says this. My guess is if you say it enough times, eventually somebody will get it right.
With raid, is where such big drives shine.
Imagine 3 of these in raid 5. You are safe from a failure, and have 8TB of data (well less, because they are not truly 4TB but let's not go there). But you still need backups.... lol
I actually only have 1TB drives at home. I find it more cost effective for me to buy a 1TB drive for under 100 bucks and add to my raid array, then buy a bigger drive as I'd have to buy at least 3 so I can rebuild the array properly. I will probably eventually jump to 3TB drives when the need comes.
your worse off in raid with these large drives because rebuild times take so long and stress the other drives your more likely to have a 2nd drive die during a rebuild and then your screwed.
You have obviously never ripped a DVD or BD, you need much more than 4 TB for a media server.Why would home users need 4TB at all? As was mentioned, watch out for failure rate and putting too much unto these suckers. There have been debates over using 32GB flash cards in photography forums out of fear of loss, deletion, failure, etc. Is it still better to use 4 8gb cards instead of one 32GB? I would rather get 4 1TB external HDDs than 1 4TB internal.
Samsung Denies Demonstration of 4TB Hard Drive.
A spokeswoman for Samsung Electronics said Wednesday that the consumer and IT company did not unveil a 4TB hard disk drive (HDD) at CeBIT trade-show earlier this month. The representative for the firm said that the firm only revealed technical possibility to make such a drive.
Because large drives = more density more possibility for errors, alignment issues et cetera.
So you are saying that nothing else improves other than density? Serioulsy? Every single time the next bigger drive is released, somebody says this. When has somebody been right on a density increase being "bad". Next thing you know somebody will be telling me a "die shrink" is bad too.
Can somebody link me a study that shows a direct correlation between platter density and failure rates? I mean, if this is such a big deal..it should be easy.
If you can't..stop FUD'ing.
